Six quik reference steps on how to replace you 3.6 spark plugs and coil over plugs
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 59
Like Tree18Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Six quik reference steps on how to replace you 3.6 spark plugs and coil over plugs in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; First I removed my 3.6 engine cover, and unplugged battery cables... Second, I remove air filter coupler, all vaccum hoses, ...
    rgvcts's Avatar
    rgvcts is offline Cadillac Owners Fanatic
    Automobile(s): 2005 3.6 CTS Luxury Sport
    Mar 2011
    McAllen, TX
    147
    Second, I remove air filter coupler, all vaccum hoses, brackets and bolts, easy to do. Most, if not all were 10mm and 13mm sockets...
    Third, *to remove the bolt on the intake in the back passenger side, I found it easiest to remove the cabin air filter cover, then removed the plastic tray bolted to the fire wall. 2 nuts, 1 screw, and its off...
    Still Third, and its off, once off, the bolt is easy to remove and pull out...
    Fourth, once all the hoses brackets and bolts are off the upper intake should pull right off (slowly) exposing all coil over plugs...
    Fifth, in order to remove the coil over plugs I used a flat head screw driver to pop out the lock on the side, loosened the screw that holds then down and they pulled right out...(slowly)
    Still fifth, coil over plug removed...
    Sixth, I then replaced the spark plug (Autolite double platinum part: APP 5263) and reinserted the coil over plug and proceeded with the other five S plugs. An extension and 3/8th spark plug socket helps ; )...
    Once I replaced all my spark plugs and coil overs I cleaned up, replaced the upper intake , hoses, brackets and bolts, cabin air fitler covers... and re hooked up my battery... Just some pics to help those thinking about doing so they dont feel its hard to do...
    Y3E, Y3E, rexilus and 13 others like this.
    neurotictim is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V mostly stock
    Jun 2011
    Virginia Beach, VA
    459
    Just did this a week or two ago, and I was actually going to do a write-up, but you pretty much nailed it in six steps. Really nothing to it.
    All I would add is that you need to be pretty careful pulling up the intake so you don't damage the gasket(s) like I did.
    +1 on pulling the cabin air box, also - makes getting to that back bolt MUCH easier.
    Firewalker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS 3.6l
    Jan 2012
    Beavercreek, Ohio
    185
    Re: Six quik reference steps on how to replace you 3.6 spark plugs and coil over plug
    Awesome write up, saving this one for future reference! Thank You.
  5. #4
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    34
    718
    Great write up, can it be made a sticky or put somewhere notable for newbs, just got a cts myself so plenty of questions to ask
  6. #5
    ham4864 is offline Cadillac Owners Fanatic
    Feb 2012
    40
    286
    great job,looks easy my other v6 is hard because its a front wheel drive car and its hand to reach the three rear plugs,my long arms helped a lot but my big hands don't.
    saving this for the future.
  7. #6
    Lzr
    Lzr is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS - 3.6L, perf pkg, RX catch can, Vmax Ice, Volant CAI
    Oct 2011
    Montreal, Qc
    353
    Good job
    this is a 2 in 1 also gonna be usefull for the VMax Iceolator
    will probly combine the 2
  8. #7
    rgvcts's Avatar
    Mar 2011
    McAllen, TX
    147
    Yeap, I actually was surprised how easy it was to get to the spark plugs on this motor, its awesome that they are on top... any questions just ask or PM...
    Quote Originally Posted by Lzr View Post
    Good job
    Soooo What is a VMAX Iceolator????????? sounds very interesting
  9. #8
    Lzr
    Oct 2011
    Montreal, Qc
    353
    Quote Originally Posted by rgvcts View Post
    hehe
    i'm on the fence, do i wait for some guinea pigs or do i pull the trigger...
    http://www.cadillacforums.com/forums...available.html
  10. #9
    74chvy glasshouse is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.6 , 74 chevy caprice
    Jan 2012
    California, desert empire
    395
    wat order do u tighten intake bolts ? how hard
  11. #10
    rgvcts's Avatar
    Mar 2011
    McAllen, TX
    147
    Whoa, 20hp for only $150 and DIY install, BEST DEAL EVER!
    I would pay the $150 right away for it not because i want to go faster quiker, but to improve fuel economy, Will or has any heard if this space hurts or improves fuel economy???
  12. #11
    Lzr
    Oct 2011
    Montreal, Qc
    353
    that's why i still haven't jumped in, not much info on it, but it's been used on camaros and they seem to like it...
    i'm doing the plugs in the coming months so i will most likely put that in at the same time
  13. #12
    rgvcts's Avatar
    Mar 2011
    McAllen, TX
    147
    Quote Originally Posted by 74chvy glasshouse View Post
    I am sure there is a specific torque to tighten the bolts to and a specific sequence on which ones to tighten first...
    But since at the time i did not know, I noticed that to remove them it did not require more effort than one arms strengh with a standard ratchet and thats because they have never been removed, to retighten them I tightened them as much as I could with that same arm if you know what im trying to say.
    As far as in which order i retightened them did I a standard criss cross and from the rear of the intake then the front and back to the rear again. Kinda like what you would do with lug nuts on a tire.
    as soon as I find the correct schematics I may go back and re do it, its fairly quick
  14. #13
    Jim's 06 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2006
    167
    My GM shop manual says 17 lb/ft for the intake manifold bolts, and 13-15 lb/ft for the spark plugs. Also, don't use anti-seize on the spark plugs; just check the gap, clean the threads, and torque 'em down.
    neurotictim and neurotictim like this.
  15. #14
    rgvcts's Avatar
    Mar 2011
    McAllen, TX
    147
    Quote Originally Posted by Jim's 06 View Post
    I put anti seize on my spark plug threads before i put them back in... It was a special little squeeze packet that was labeled Spark plug anti-seize from Autozone it was a silver metalic looking liquid/paste. Should i remove them and clean it out? or why should we not use anti-seize ont them?
    Thank you for the torque specs!
  16. #15
    AmericanMuscle is offline Cadillac Owners Fanatic
    Mar 2005
    260
    Anytime you are threading bolts or spark plugs into an aluminum block or heads, you should always put anti-seize on the threads. Aluminum is soft and you need the anti-seize to ensure the bolt or plug threads properly and can be released again later.
    2005CTSGUY likes this.
  17. Remove Advertisements
Gear in this thread - Powered by O'Reilly Auto Parts
