Urgent help! 04 CTS key stuck in ignition! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Like Tree2Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Urgent help! 04 CTS key stuck in ignition! in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; yeah, as I suspected (in post #2) either ecm or battery glad you got it fixed and thanks for the ...
  1. #16
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Urgent help! 04 CTS key stuck in ignition!
    glad you got it fixed and thanks for the follow-up
  2. #17
    AsiaRedbone is offline Cadillac Owners Member
    Mar 2012
    8
    Thanks everyone. Now all I need, is to replace the timing chain. They say it's loose. Yipes!
  3. #18
    DreDre760 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS
    Feb 2013
    36
    1
    Hello, My Brother is having the same issue with his 2004 Cadillac CTS, with the key getting stuck inside the ignition to where i got on this forum and searched to find out how to get it out, now the cluster is not lighting up T/C lights up, i can't tell how much gas that I have in the car, Car symbol with the lock pops up. I think its either the Battery or the ECM/PCM, please help!
  5. #19
    Tlorenzen is offline Cadillac Owners Connoisseur
    Automobile(s): 03 CTS (Dead), 06 3.6 CTS(Sold), 07 CTS-V
    Jan 2011
    Melbourne, FL
    1,504
    I had this problem a while back. Drove the car a little ways, turned it off then restarted and problem was fixed. In my case, I know its my battery, just don't want to replace it until I have to.
  6. #20
    cameronusa is offline Cadillac Owners Member
    Automobile(s): 02 deville and 04 cts
    Aug 2013
    81
    1
    Quote Originally Posted by dkozloski View Post
    The stuck key is addressed in the owner's manual. There is a hole in the bottom side of the steering column that you can stick something in and release the key. A battery with a bad cell will still start the car but the key will be stuck. What does battery voltage read on the DIC key-on-engine-off?
    Thank you dkosloski.. what a great tip.. found in the owners manual and solved a very tricky problem.. much appreciated.. Joe Cameron, Pittsford, NY
  7. #21
    beavers is offline Cadillac Owners Member
    Automobile(s): 2004 Cts
    Feb 2015
    1
  8. #22
    jennscts04 is offline Cadillac Owners Member
    Automobile(s): cts
    Aug 2015
    1
    my key is getting stuck quiet often and I have to use the fallback method of pushing the button under the steering column. However when I place the key back in the ignition It doesn't start and my key gets stuck again. I would wait a bit and it would start. Then when that no longer worked I disconnected the battery cable and reset it and that worked for a little while too. Now I am having it ^Jumped Off*to get it started. What could the problem be. One estimate was totaled over 1200.00 dollars.. Is this the normal cost for my car to start?.
  9. #23
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,252
    So you had it jump started and it worked...
    Can't imagine what it could be.
    Battery perhaps?
    KOT
    Argent1 likes this.
  10. #24
    RussellBoulding is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Eldorado Biarritz
    Nov 2014
    St. Petersburg, Fl
    418
    Quote Originally Posted by jennscts04 View Post
    What was getting done for $1200. I suspect you have a battery issue. But, as a professional I would be hesitant to argue with another professional that has seen the car in person and done the testing. Any more details on the $1200 diagnosis?
  11. Remove Advertisements
