Help! Engine making bad clicking noise. With Video.
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
Like Tree3Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Help! Engine making bad clicking noise. With Video. in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey guys, I had my first oil change, the free one from the dealership, about 100 miles ago and this ...
    Invisible@Night's Avatar
    Invisible@Night is offline Cadillac Owners Member
    Automobile(s): 06 CTS Black on Black
    Nov 2011
    Denver,CO
    35
    46
    Hey guys,
    I had my first oil change, the free one from the dealership, about 100 miles ago and this noise started about 20 miles ago very soft. Today I drover it about 30 blocks and pulled into my garage and it sounded like this. I checked the oil both cold and hot and the level is within the acceptable range. I thought it might be that Selenoid I always hear you guys talking about but it is coming from both sides so I assume lifters/ low oil. Please help! Is there a certain type of oil that should go into a 2006 cts 2.8l? I'm sure they used the cheapest stuff they had and I am wondering if that could have caused it. Also, I hear about the recall for 3.2l that burn oil. Is this applicable for the 2.8 also? I am not leaking oil enough to drip from my engine cover underneath onto my garage floor so I am curious how this could have gotten so bad with so little driving. Thank in advance for your help and the video link from today is http://www.youtube.com/watch?v=8NXeP...&feature=g-upl
    X Rolls-Royce is offline Cadillac Owners Connoisseur
    Sep 2011
    60
    4,193
    Re: Help! Engine making bad clicking noise. With Video.
    i listened four times and the one tick is the purge solenoid clicking its little heart out and the rest is fairly normal noise, heavier oil might quiet it down. Mobil 1 5W-30 is the factory oil recomendation.
    Nov 2011
    Denver,CO
    35
    46
    Quote Originally Posted by X Rolls-Royce View Post
    Thank you for the quick response. As per usual, X-RR you are my hero. Would you say the aftermarket replacement is good or should I spend almost double and get the factory. Either way i am doing the work so no labor cost.
    Sep 2011
    60
    4,193
    You can get the same AC/Delco as the dealer for $25 at any parts store. I'd stick to that. You might save a couple of bucks with an off brand that's probably just the same but why risk it ? I'm glad to help.
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,156
    How about this...
    Since you have the 2006, unplug the damn thing. Drive around until the engine light turns on. Plug it back it, go to a parts store to have the code scanned for free. Come back here and list the code(s). Hopefully it will be with in the range of P0440 to P0449. Then call the dealer and tell them that your check engine light turned on.
    Total cost to you? Just your time, because 2006 model year had a "recall" for that problem. Had mine replaced a few months, Rolls had his replaced a few months before mine.
    KOT
    Sep 2011
    60
    4,193
    If he wants to avoid getting stuck at the gas station and struggling to get the engine to run and running down his battery and then getting the code...its worth the $25 to change it now and leave the dealer out of it.
    Nov 2011
    Denver,CO
    35
    46
    Thanks for the advise but I'm with Rolls on this one. Advance is 1 mile away and has the AC Delco Part for $25. Caddy is 25 miles away and if I can't start my car it makes for way more than a $25 drive. Well worth the cash to just do it and also I can verify it gets done if I do it too. Thanks again guys for the help. 7am now time to go to Advance.
    Nov 2011
    Denver,CO
    35
    46
    OK, so instead of sleeping like I should have today here is what I got done today. Went to Advance and got one part for $25 and it only had one electrical connector where mine has 2. drove across Denver to the only Advance that had the only other part number listed for my car for P.S. and it also only had one electrical connector. I spent the next few hours trying to get a hold of a service adviser at Rickenbaugh Caddy and set up an appointment for Tuesday at 7am when I get out. Man, looks like I will be unplugging it this weekend and using my Matco scanner to bring you guys some codes before I waste time and possibly money on Tuesday. so 2 hours of sleep and now I am back at work for the next 11. Looking forward to sleep tomorrow for sure.
    Nov 2011
    Denver,CO
    35
    46
    Anyone have a AC Delco part number for this? Or am I just really dumb and am looking at the wrong part. By looking at it this is the Purge for the intake manifold and when it warms up and it starts clicking when you touch this it is definitively coming from inside. Attachment 90710
    Apr 2009
    Ledyard, CT
    37
    9,156
    That us the part.
    But apparently you need more sleep, because it has only one electrical connection and two tubular connections. :-)
    KOT
    Nov 2011
    Denver,CO
    35
    46
    Quote Originally Posted by Kingoftypos View Post
    That us the part.
    KOT
    I agree. I meant one tubular and one electrical on the wrong piece. It was a long tube with one tubular and a right angle electrical plug on the other end.
    Sep 2011
    60
    4,193
    The part number is 12611801.
    It this what they tried to sell you ?
    Attachment 90719
    Nov 2011
    Denver,CO
    35
    46
    Thank you for the part number, that looks just like mine! The part below is the one that they tried to sell me twice with 2 different part numbers according to them. Part #214-2230
    Attachment 90720
  16. #14
    Sep 2011
    60
    4,193
    That part number does not go with that picture !!!!!
    The part number is for the 3.6 liter.
    That purge valve assembly in the picture is from a 2003 is how I have it marked.
    The valve in your picture might be the vent valve. You want the EVAP cannister purge solenoid/valve. The walnut sized one is 12611801
  17. #15
    Nov 2011
    Denver,CO
    35
    46
    That's crazy, that was the part number on my return receipt and this was definitely the part I got twice. 12611801 looks like the right part, I just have to find one in town for not $90. Maybe there wont be too much sleep in my future after all. Thanks again for your helps Rolls and KOT. I will keep you posted on my battle.
  18. Remove Advertisements
