Help CTS Grille - Page 2
Results 16 to 30 of 43
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Help CTS Grille in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I like the real V grille over the E&G one and it is cheeper. I would love to put the ...
  1. #16
    JoeEXT's Avatar
    JoeEXT is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS4
    Oct 2003
    Boston, MA
    103
    Re: Help CTS Grille
    I like the real V grille over the E&G one and it is cheeper. I would love to put the CTS-V front end on my SRX, do you know if that will work. I would need to check on cost too.
    Thanks
  2. #17
    60 special is offline Cadillac Owners Fanatic
    Oct 2004
    199
    Re: Help CTS Grille
    Quote Originally Posted by JoeEXT
    Thanks
    The CTS front fascia is smaller than the SRX. From looking at the picture link that was shown on the other post, it looks like there are mesh inserts on the lower section of the SRX. Hope you find what you need.
  3. #18
    RobertCTS's Avatar
    RobertCTS is offline Cadillac Owners 10000+ Posts
    Automobile(s): Black the Darkside
    May 2004
    Central Ohio
    22,418
    Re: Help CTS Grille
    Thanks
    I know from experience that the SRX grill is larger and will not fit the CTS
  5. #19
    ErikHoff is offline Cadillac Owners Member
    Dec 2004
    28
    Re: Help CTS Grille
    Will this same grille from gmpartsdirect #15147586 fit the 05 model as well? I heard their may be some installation issues with them.
  6. #20
    ctvw's Avatar
    ctvw is offline Cadillac Owners Member
    Automobile(s): 05 ESV, 06 DTS
    Dec 2004
    CT
    19
    Re: Help CTS Grille
    the lower grill is larger on the v than on the standard cts because of the brake cooling ducts bElow the foglamps, so the lower v grill won't fit the cts
  7. #21
    Dec 2004
    28
    Re: Help CTS Grille
    But the top grille will fit on the 05 CTS right?
  8. #22
    msheri01 is offline Cadillac Owners Enthusiast
    Feb 2004
    527
    Re: Help CTS Grille
    Quote Originally Posted by 60 special
    The aftermarket grille does come with the lower mesh section. I don't know if the factory offers the lower mesh or not.
    No, it does not, because the lower grille area is not the same on the base CTS. If you want the lower grille, you have to go aftermarket. This is due to difference in lower fascia on the V.
  9. #23
    Dec 2004
    28
    Re: Help CTS Grille
    Is the top grille easy to install? Do the screws just pop off on the old ones?
  10. #24
    RobertCTS's Avatar
    May 2004
    Central Ohio
    22,418
    Re: Help CTS Grille
    Quote Originally Posted by ErikHoff
    About a dozen retainers. Most of us that has done this by clipping the old retainers with side cutters and replace with new ones. Pop the new ones in from the top side, its easier. Side retainers a bit difficult to reach
  11. #25
    Oct 2004
    199
    Re: Help CTS Grille
    The grille available from vogue tire mounts the same way the factory one does. Also, the lower mesh installs quickly and easily.
  12. #26
    Dec 2004
    28
    Re: Help CTS Grille
    I have an 05 CTS. And they have about 4 black retainers (I guess thats what you call them) holding in the factory grille. I can't pop those damn things off though.
  13. #27
    crockone's Avatar
    crockone is offline Cadillac Owners Connoisseur
    Sep 2004
    nj
    38
    1,240
    Re: Help CTS Grille
    I WANT JUST THE BOTTOM.. WHERE CAN I GET JUST THE BOTTOM GRILL??? MESH.
  14. #28
    RobertCTS's Avatar
    May 2004
    Central Ohio
    22,418
    Re: Help CTS Grille
    I'M BETTING YOU GOT 12 RETAINERS. FOUR ARE AT THE TOP. THE THINGS ARE CHEAP. GET'EM AT YOUR PARTS DEPARTMENT. SIDE CUTTER WORK FINE. THEIR ALL ACCESSIBLE FROM THE BACK OFF THE GRILL. THE ONE ON THE SIDE ARE A LITTLE TOUGHER. YOU'LL NOTICE THE RETAINERS ARE INSTALLED FROM THE BACK SIDE. WHEN YOU REINSTALL, INSERT THEM FROM THE TOP AT THE REAR OF THE GRILL. THAT'S A MUST! NO FRIGIN' WAY CAN YOU INSTALL LIKE AT THE FACTORY. IT DOESN'T MATTER SINCE EITHER SIDE HOLD THE GRILL IN PLACE. THIS IS THE WAY THE REST OF US HAVE DONE IT. GOOD LUCK. SORRY FOR THE CAP LOCK
  15. #29
    Dec 2004
    28
    Re: Help CTS Grille
    Robert, Thanks bro!
  16. #30
    RobertCTS's Avatar
    May 2004
    Central Ohio
    22,418
    Re: Help CTS Grille
    Quote Originally Posted by crockone
    http://www.egclassic.com/cadgrille25.htm
  17. Remove Advertisements
