How hard is it to replace a fuel pump on an 04 cts
Results 1 to 11 of 11
Like Tree1Likes
  • 2 Post By Bosnian
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, How hard is it to replace a fuel pump on an 04 cts in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I went in today to get my oil changed. Boy was I in for a surprise, supposedly during the oil ...
    Bosnian's Avatar
    Bosnian is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.6L
    Sep 2008
    30
    151
    Change the fuel pump died according to them. They said
    They tried everything and it was definitely in need of a
    Fuel pump once again according to them. They quoted me
    At 1159.00 after taxes and labor the fuel pump was 349.00
    and their labor costs were 750, for 5 hours of labor
    They said they would need to take the whole end off in
    Order to replace the fuel pump. In my mind I thought someone
    Was lying so I was very skeptical.
    Anyways after all this I told them let me go try to start the car
    As I did not believe their story. The car started after I kept my
    Foot on the gas for about a minute so the fuel could flow inside.
    Sure enough the car started. I am sure they were trying to rip me off.
    How often do fuel pumps fail on these cars and are they really a hard
    To replace as they claimed to make it. I am definitely not going back
    To this dealership.
    X Rolls-Royce is offline Cadillac Owners Connoisseur
    Sep 2011
    60
    4,193
    Re: How hard is it to replace a fuel pump on an 04 cts
    Bosnian, have you replaced the EVAP cannister purge solenoid valve ? It sounds to me that this is your problem.
    Fuel pumps DO NOT fail on the CTS.
    Were the fuel pump to fail, access may be gained by cutting a hole at the proper place underneath the backseat. There is a thread concerning this proceedure by a German man who likely did not need the repair.
    Bosnian's Avatar
    Sep 2008
    30
    151
    Quote Originally Posted by X Rolls-Royce View Post
    I have not, that's good to know. Confirms my earlier suspicions of them trying to rip me off.
    I will take it to the Cadillac Dealer, because apparently Chevy dealers have no clue about Cadillac's as evident by my experience today.
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,221
    No need to take it to a dealer. The EVAP can be replaced by you in less than 5 minutes.
    Remove the engine cover, just remove the oil fill cap and pull up on the cover. Once removed, put the oil cap back on so debris won't fall down.
    Then remove the 10mm bolt that is holding the EVAP on, and unplug the wire harness as well as the two tubes.
    Install the new and replace the engine cover. Your done.
    Part cost about $30 to $50, depending on where you go. They have them at the auto parts store and dealers.
    KOT
    Bosnian's Avatar
    Sep 2008
    30
    151
    Also, it was not having any of these problems, until they took it over.
    Sep 2011
    60
    4,193
    Quote Originally Posted by Bosnian View Post
    The car was running right, you took it to a Chevy dealer for an oil change, and what problems does it have now ? I was just shooting from the hip on the EVAP solenoid. It can cause hard starting that requires pushing the accelerator to the floor to keep the engine running untll it straightens itself out.
    Was it getting a little hard to start sometimes ? You make it sound like they broke something intentionally, no too likely at a GM dealer. There must be another explanation. Fuel pump failure is virtually non-existant judging by things around here. It would definately be in that price range but its hard to imagine that the fuel pump failed. They don't make it easy to work on since its so reliable. You can shortcut through the floor pan to get to it. We have pictures of where to cut.
    Bosnian's Avatar
    Sep 2008
    30
    151
    I got no idea what they did, first they had told me that the battery
    Was dead, so then thu attempted to jump start it, according to them
    Then they told me the fuel pump died because it had ran out of fuel
    Which was weird to me because when I got in the car it did not even
    Flash the low fuel warning. Then the tech told me he tested it and it
    Was not throwing up any codes. I am sure if it was a fuel pump it would
    Throw codes.
    Like I said I got no idea what actually happened I just know I had to step
    On the gas before it started again almost like to lubricate it
    Which they said they also tried. I drove it yesterday afterward
    It started all 5 times with no problem. Once I started the car they said,
    Oh there must have been a lot of air in your fuel line.
    It's so hard to believe all of them right now, no one had a
    Solid explanation on why the car started when I tried
    it.
    Sep 2011
    60
    4,193
    Its your EVAP cannister purge valve solenoid. If you fill the car with gasoline and it won't start, its the purge valve and it does what you described. It won't start, it runs down the battery, it barely starts and you have to work the gas pedal to smooth it out. The engine is starving for fuel because it can't get any gas-rich fumes from the cannister.
    You might have a loud constant ticking from under the engine cover near the battery. That would be the solenoid trying to open the valve. Sometimes the solenoid burns out, sometimes the linkage breaks and it ticks. The instructions are up above. I suggest you give it a shot.
    Bosnian's Avatar
    Sep 2008
    30
    151
    I will give it a shot thanks
    art_1519 is offline Cadillac Owners Member
    Nov 2013
    6
    Hi, new to the forum here. I had kind of the same problem. Car had been running fine and one of this rainy days it didnt start. I went to work, came back and read this thread and i did the 1 min on the gas proc. And it started. Next day rain again, no go. Had to use the gas pedal to get it to start. Next day sunny worked just fine. Does the evap purge solenoid is affected by the humidity? I'm sorry maybe a stupid question but any help will be greatly appreciated. Its a 03 CTS 140000 miles. Should i replace it? And what is the part number? Thanks in advance for your help.
    Cady2004cts is offline Cadillac Owners Member
    Automobile(s): 2004 cts 3.6L v6
    May 2016
    20
    I have a 2004 cts 3.6 l I read this and changed the purge valve. Unfortunately it didn't work I recently changed my alternator cause the car completely died and wouldn't do anything. Now as soon as I turn the key it revs once then completely died and doesn't stay on. Any answers I can fix most things myself I just really can have it be the fuel pump.
  14. Remove Advertisements
