Key stuck...Service theft system...temp/fuel gauges not working...no traction control
Results 1 to 12 of 12
Like Tree3Likes
  • 2 Post By packattack12
  • 2 Post By X Rolls-Royce
  • 1 Post By X Rolls-Royce
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Key stuck...Service theft system...temp/fuel gauges not working...no traction control in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey guys, It's been awhile...which is a good thing. This morning I went to go start my car and everything ...
    packattack12 is offline Cadillac Owners Member
    Automobile(s): Black '07 CTS
    Nov 2010
    68
    Hey guys,
    This morning I went to go start my car and everything started good, but the service theft system warning popped up, the car with the lock next to it on the dash is lit up, traction control is turned off and can't turn it back on, the locks aren't automatically unlocking when I put it in park, my temp and fuel gauges aren't working and lastly when I put the car in park my key won't turn back all the way and is stuck so I can't get it out. Also, when I was driving all my interior lights and radio flashed on and off. It turns on a and drives fine though. My battery isn't even a year old. I got it replaced about 8 months ago.
    I found the little hole under the steering wheel to release the key so at least I can get the key out. And it really sucks the traction control isn't working because its snowing pretty good here today.
    At lunch I will try to disconnect the battery and see if that helps. I also read that it could be a number of things, such as bad grounding, bad ECM...etc. Is there any other things I can try before I have to bring it in?
    I really appreciate any responses.
    Nov 2010
    68
    Re: Key stuck...Service theft system...temp/fuel gauges not working...no traction con
    So I disconnected the battery for about 15-20 minutes and the same thing is happening. I forgot I have an extended warranty through Zurich and my deducible is $100. I need an oil change anyways so I'm just bringing it in to the local dealer tomorrow morning. I'll let you know what they find. Until then - You can find me whippin shittys in the snow
    X Rolls-Royce is offline Cadillac Owners Connoisseur
    Sep 2011
    61
    4,193
    I'm going to make a guess on the ECM crapping out. I'd eliminate the ignition switch first as cost effective troubleshooting. And I'd check the battery connections, that's free too. I try to eliminate the free stuff first. Why spend money if you don't have to.
    It'll be fun to find out when you come back. I hope you can keep the sled from hitting any trees.
    Nov 2010
    68
    So guys just picked up the caddy and it was the ECM. Thanks God I have the extended warranty...
    cgibbs and cgibbs like this.
    Sep 2011
    61
    4,193
    Yay for me, I nailed it !!!
    Sep 2011
    61
    4,193
    http://www.cadillacforums.com/forums...vice-anti.html
    Post number 8 is an accumulation of links discussing these symptoms.
    http://www.cadillacforums.com/forums...ml#post2827190
    sashasmith325 likes this.
    mtshu is offline Cadillac Owners Member
    Automobile(s): 2006 CTS
    Aug 2013
    1
    Turn key to start position but do not start. I keeped the windows down just in case the doors locked on me. Wait 10 min. Open the fuse box under the hood - front passenger side. Remove fuse labled "ECU" (10v). Inspect fuse and put back in if good. You will here the doors and other things clicking for a few seconds. Now Remove fuse that says "theft" (7.5v). Do not turn car to off position just start. Let run and check gauges and TC and Security. All should be off. Pull key out.
    kealey123 is offline Cadillac Owners Member
    Automobile(s): 2005 CTS
    Apr 2015
    29
    3
    after pulling the "theft" fuse out.... Do i put it back in, if all the lights are off?
    Rbeisaw's Avatar
    Rbeisaw is offline Cadillac Owners Member
    Automobile(s): 2006 3.6L Blackberry
    Jul 2012
    Lewiston, Maine
    33
    26
    Gonna put this thread to rest and let you all know what I went through and the fix. Had the same issue for 1.5 years now. Service theft system, theftlock, no traction control, no gas gauge, no temp gauge, key stuck in ignition. STILL WOULD START AND DRIVE. it went from happening intermittently over 1.5 years until last week when it didn't go away. Finally took it to cadillac dealer and it came down to a FAULTY PCM. dealer replaced and $850 later it runs like a champ all over again. Best of luck to all, but after multiple thread reads and google searches and many many different solutions, I thought it was time to have the professionals look at it.
    Cady2004cts is offline Cadillac Owners Member
    Automobile(s): 2004 cts 3.6L v6
    May 2016
    20
    My traction control light is on but I can't turn it off and my car keeps beeping it goes beep.....beep.....beep. my seat belt is on the doors are closed any tips?
    Shvwone is offline Cadillac Owners Member
    Jun 2016
    1
    U check ur parking brake? I set my brake one evening and forgot the next morning. There were no indicator lights showing that my brake was engaged. I had to deal with a persistent annoying beep for about an hour til I remembered.
    Quote Originally Posted by Cady2004cts View Post
    Static1120 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS 3.6
    Feb 2014
    21
    354
    all these threads comming up seems all the ecms start crapping out at around the same time.
  15. Remove Advertisements
