Running Wires Through Firewall
Results 1 to 3 of 3
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Running Wires Through Firewall in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Does anyone know the best spot to run wires through the firewall on the drivers side?...
    FIERCE4203 is offline Cadillac Owners Member
    Oct 2004
    15
    crockone's Avatar
    crockone is offline Cadillac Owners Connoisseur
    Sep 2004
    nj
    39
    1,240
    Re: Running Wires Through Firewall
    Quote Originally Posted by FIERCE4203
    yea ummm. run it through the search button.. wen you get there run it through the search for amp wire... sory had to do it.. this is like the oldest question... its all gravy man...
    510ctsV's Avatar
    510ctsV is offline Cadillac Owners Member
    Automobile(s): 05cts-V
    Oct 2004
    Bay Area Cali
    51
    check cadillacfaq.com......i asked the same q on there. NE how theres a boot on the drivers side. I pulled it out as much as i can an took a screw driver and stuck it through the hole where the wires are already running through. then i poked upwards and busted a hole (reason: im using 4 gauge wire and it wouldnt fit through the existing hole with the other wires.)......and ran the wires through. feed as much as you can until u can pull it from the engine bay.
    note: the boot may be hard to put back.
    some people i know use soap and water......but i used a lil bit of lotion and rubbed it over the boot and shoved it in more easily.....
    oh, i did it for the power to slide thru easier also.....
    Im not saying its right .....but thats what i did and it worked .
