2003 CTS base - Tranny doesn't shift out of 1st gear until RPM's get up to 2800
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By X Rolls-Royce
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2003 CTS base - Tranny doesn't shift out of 1st gear until RPM's get up to 2800 in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Just replaced my radiator as the transmission line blew. The tranny was only refilled with Dexron III, no filter change. ...
    simkofab is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2006
    Northwest Indiana
    50
    Just replaced my radiator as the transmission line blew. The tranny was only refilled with Dexron III, no filter change. This shifting problem happened right after the work was done. It does shift but only after the RPM's are way up and it doesn't have the power it should. It felt bogged down. I only drove it a few miles, gingerly home. It has been sitting since. I'm tight on funds so an idea of what I'm in for would help. Thanks.
    Tim
    X Rolls-Royce is offline Cadillac Owners Connoisseur
    Sep 2011
    60
    4,193
    Re: 2003 CTS base - Tranny doesn't shift out of 1st gear until RPM's get up to 2800
    Number one, depending on who filled the transmission, it may not be completely full. Its not as simple as pouring in the fluid.
    If a Cadillac dealer filled it using the proper proceedure, the outlook is bleak to dismal.
    It does sound like the fluid hasn't been correctly filled and is low.
    How far did you drive after the line blew off ?
    Ikera likes this.
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    i agree with the above post...sounds like the fluid is not filled completely or they didnt shift through the gears and let the torque converter fill up then top it off again
    carrnuttdave is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS
    Aug 2010
    Layton, Utah
    53
    1,572
    Are you saying even if you let off on the gas it won't shift? cause shifting & 2800 sounds about right but if you were to let off and coast it should shift sooner
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    2800 rpm sounds about right... mine idles i thinnk just below 1000 rpm
    ill pay attention to my shift patterns on the way home from work tomorrow.
    and very important question.
    are you in sport mode?
    Teedoe's Avatar
    Teedoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Base and 2014 Cadillac CTS VSport Premium
    Dec 2009
    Central Florida
    525
    My tranny just started shifting very rough. My mechanic couldn't change the fluid so Ima reach out to a GM Tech in the morning. Wish me luck.
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    Try disconnecting the battery and reconnecting. I had a similar issue when I changed out the lines and ran an external trans cooler. I had to disconnect and reconnect battery and it somehow relearned it.
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
    Dec 2006
    Northwest Indiana
    50
    Thanks everyone. I has been driven about 10 miles. All under 40 mph. I'm going to have the fluid level checked & try the battery disconnect / reconnect. Fingers crossed. I'll let you know how things went.
    Teedoe's Avatar
    Dec 2009
    Central Florida
    525
    No luck on my end. I will try disconnecting the battery and if that doesn't work Stealership it is.
    Aug 2010
    Layton, Utah
    53
    1,572
    I paid attention to mine on the way in today and under normal acceleration 2800 to 3000 is just about right for when it shifts from 1st gear!
    People just have to realize these engines are not your old school V8's they are built to rev higher than, say a small block chevy.
    sergeyka7hotmailcom's Avatar
    sergeyka7hotmailcom is offline Cadillac Owners Member
    May 2013
    37
    6
    thanks guys, disconnecting helps!!!!!!!
    luvinMYcaddycts is offline Cadillac Owners Member
    Automobile(s): 05 CTS with an 08 3.6 VVT
    Apr 2014
    lake Jackson TX,
    1
    I wrecked my 05 CTS on beach only body damage but put new fenders an bumper on how tranny not shifting properly so dropped pan an everything clean but filter popped out an air bubbles all over valve body ...so replaced filter an added fluid twice I got little over 5 quarts back in it an shifts better but still full throttle first to second is crazy ?? Dunno what to do now maybe run it jacked up through the gears with T/C off??
    There was a plastic ring on bottom of factory filter neck an not on O'Riley's filter I installed just two rubber o rings an seemed to fit pretty snug but dunno if correct???
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    You have to take that ring off the old one, and put it on the new filter before install. Idk what a difference it makes. Could be the problem.
  16. #14
    Ikera's Avatar
    Ikera is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS 3.2, 1990 Nissan 240sx Turbocharged
    Apr 2013
    Vancouver, BC
    30
    383
    Quote Originally Posted by luvinMYcaddycts View Post
    did you add fluid second time with the engine running? because that's what you need to do.
    First fill the transmission thru the fill hole until it over flows
    Start the engine in Park
    Apply brakes and keep you foot on the brakes
    Shift into Reverse for 10 second
    Shift into Neutral for 10 second
    Shift into Drive for 10 second
    Shift into park, release the brakes, but keep the engine running
    Get under the car with the engine running and start pumping ATF into the transmission.
    try not to get your hand burned by the exhaust
    Once the transmission overflows, close the fill plug before shutting off the engine.
    turn off the engine
  17. Remove Advertisements
