Results 1 to 10 of 10
Thread: Suspension question.
    headcase650 is offline Cadillac Owners Member
    Automobile(s): 2007 CTS Sport 18" Wheels
    Feb 2010
    43
    57
    07 FE5. I thought the front was struts with a strut brace running over the top of the engine. On the rear is self leveling shocks. The reason I'm asking is my GMPP Major guard extended warranty is not wanting to replace my front struts. They claim they are by definition shocks. The dealer called them struts. I would like to know what it has. The dealer said they were gonna work it out with GMPP and I didn't have to eat the cost. ???
    carrnuttdave is offline Cadillac Owners Connoisseur
    Aug 2010
    Layton, Utah
    53
    1,572
    Re: Suspension question.
    Because the car actually has both upper and lower control arms they are technically not struts they are shocks! Kinda like coilovers.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,463
    Quote Originally Posted by headcase650 View Post
    They are wrong. A strut carries load, a shock simply acts as a damper. If I jack up the live rear axle of a pickup truck, remove the dampers (shocks), and then put it back on the ground, the truck will sit there perfectly happy; the springs are what carry the weight of the rear of the truck, and removing the dampers doesn't change that.
    If you remove the dampers (struts) from the front of your CTS, then try to put the car back on the ground, the front suspension will collapse because the load is carried by the coil-over strut assembly (the damper and spring).
    Quote Originally Posted by carrnuttdave View Post
    That logic doesn't make any sense to me.
    A coil-over is almost always a strut. Actually, I don't see how it would be possible to have a coil-over that is not a strut. Since a coil-over incorporates the spring perches, it has to be loaded, thus it is a strut.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  5. #4
    Aug 2010
    Layton, Utah
    53
    1,572
    If you where to take the front shocks off of a CTS and set it on the ground it would stay.At least the wheels will stay on the car. If you take the struts off of a car with struts the wheels will come off too. Thats the easiest way I can think to explain it
  6. #5
    AAIIIC's Avatar
    Aug 2007
    6,463
    Unfortunately, that easy way to explain it is not correct.
    The easiest way to explain it is that a strut is a load-bearing component of the suspension, while a shock is simply a damper, as I said above.
  7. #6
    UberCaddy's Avatar
    UberCaddy is offline Cadillac Owners Member
    Nov 2011
    Phoenix, AZ
    63
    Interesting discussion, how many miles on your car? Let us know how this works out.
    This is one of the reasons I dislike warranty companies, they kind of make up their own rules when it comes to things like this. Whether they are called shocks or struts doesn't seem to matter, it's a component that wears out and may not be covered by a warranty, even the factory warranty?
  8. #7
    AAIIIC's Avatar
    Aug 2007
    6,463
    Upon further review, the fronts are shocks. My "easiest way to explain it" is oversimplified and is not correct. A strut doesn't just carry load, it acts as a lateral locating device. The CTS's front suspension doesn't need the damper to act as a lateral locating device, because the upper and lower control arms serve that function.
    Basically, carnutdave's first response was correct. (Although coilovers can be both struts and shocks.)
  9. #8
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    either way GMPP is being dumb... they cant say they will cover shocks and not struts or vice versa...
  10. #9
    Feb 2010
    43
    57
    The dealer only charged me the $100 deductible. But wined about eating the cost of the shocks. I did more searching and for an absorber (as described in gm's parts book, doesnt say shock or strut) to be a strut it must be used to adjust part of the alignment. My car is an 07 with 46m miles on it.
    From dictionary.com
    MacPherson strut
    noun
    an automobile suspension-system component that consists of a strut combined with a spring and or shock absorber and connects the wheel to the frame of the vehicle.
  11. #10
    Sep 2011
    61
    4,193
    All's well that ends well and $100 beats the heck out of full price.
  • You may not post replies
