License Plate and Reverse Light replacement
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, License Plate and Reverse Light replacement in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I did this on my 2005 CTS I didn't realize how much of a pain it would be to replace ...
    drolfo is offline Cadillac Owners Member
    Automobile(s): 2005 CTS 3.6
    Nov 2011
    I didn't realize how much of a pain it would be to replace my license plate lights until I put hands on and figured it out myself. Here is the step by step for you:
    What you will need:
    -10mm deep socket/ratchet
    (if you don't have the deep socket, which I didn't, a crescent wrench and needle nose pliers will work)
    -Flat head screwdriver (for plastic clips)
    -Sylvania bulb Part Number 2825 (License Plate)
    and/or
    -Sylvania bulb Part Number 3157 (Reverse Lights)
    1. Open trunk and locate 8 plastic clips.
    2. Remove a 8 clips
    3. Remove the 8 nuts from the inside of the trunk
    4. Pop out license plate/reverse light section from the outside of the car
    5. Which ever light you need to change, turn that socket a 1/4 to the left and replace bulb
    6. Repeat step in reverse to put together
    The reverse lights are noted by the blue arrows in my pictures
    BenzCTS's Avatar
    BenzCTS is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS
    Jun 2008
    Maryland
    33
    258
    Re: License Plate and Reverse Light replacement
    Very good write up!
    Nov 2011
    thanks
  5. #4
    Argent1's Avatar
    Argent1 is online now Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,726
    Just replaced my LP LED's today. One was flashing.
    It wasn"t too bad this time but if you have a spoiler you have to loosen it to get the panel off, bit of a PITA.
    Plus it was about 0* C.
  6. #5
    TunixComplex is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2 5M
    Jan 2010
    Springfeild, MO
    23
    558
    For some reason my LP LEDS go out once a month so I went back to standard halogen style and havent had a problem. Also there are 4 extra bolts to take off the rear fascia on the 05 verses the 03? Weird.
  7. #6
    Argent1's Avatar
    Nov 2010
    2,726
    I replaced mine with SMD style as recommended by Superbright.
    I used the WLED-WHP5's. They seem to have a resistor built into them. If they are too bright for my liking I may change them in the spring.
    I like the colour of Cool Blue but these only came in Natural White.
  8. #7
    carrnuttdave is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS
    Aug 2010
    Layton, Utah
    49
    1,575
    I just took out the bulbs in my license plate lights and got one of those stick on LED strips that has a row of LEDS. I had to drill a small hole on the under side of where the license plate goes but so far I haven't had any trouble with it. been there over a year
  • You may not post replies
Read about Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
