wheel upgrade question
Results 1 to 8 of 8
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, wheel upgrade question in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I am considering 18" X 7.5" wheels that have a 42 mm offset. My concern is will 42mm be good. ...
    okiwont is offline Cadillac Owners Member
    Oct 2004
    nor-cal
    76
    I am considering 18" X 7.5" wheels that have a 42 mm offset. My concern is will 42mm be good. I definitely don't want to have them to rub or contact the inside wheelwell. Thanks for your attention to my first post!
    Mbai2's Avatar
    Mbai2 is offline Cadillac Owners Connoisseur
    Automobile(s): '08 CTS DI 6 Speed Manual Black/Black w/ FE3 Fully Loaded
    Aug 2003
    1,653
    Re: wheel upgrade question
    That should fit fine. Just make sure the tires are 225/45-18.
    MikeyVSeries's Avatar
    MikeyVSeries is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Cadillac CTS-V (White Diamond)
    Oct 2004
    North/Central NJ
    262
    i thought the best set up for a cts is: 245/35/20 20x8.5 40mmoffset and 5x115 bolt pattern.. anyone comment?\
    EDIT: if your using a 20" rim
    S10xGN's Avatar
    S10xGN is offline Cadillac Owners Fanatic
    Automobile(s): 2016 CTS VSport
    Feb 2004
    Port Neches, TX
    63
    250
    Quote Originally Posted by okiwont
    Same exact dimensions of my Exel Radius wheels. No rubbing anywhere, even with four adults and a trunk full of luggage. Perfect fit with 245-40x18 tires.
    miscreant's Avatar
    miscreant is offline GM Connection
    Feb 2004
    Norman, OK
    44
    1,286
    Quote Originally Posted by CTSXtreme
    I think that's too agressive. with an 8" wide wheel, yes (as in 40mm offset), but with an 8.5" wheel, 45mm offset range would be much better.
    2004 Cadillac CTS (**SOLD** ): http://www.ctsowners.com
    2004 Pontiac GTO: http://www.myyellowgto.com
    miscreant's Avatar
    Feb 2004
    Norman, OK
    44
    1,286
    Quote Originally Posted by Mbai2
    Agreed. For best performance, don't got any wider than 225/45.
    CTS Orlando's Avatar
    CTS Orlando is offline Cadillac Owners Enthusiast
    Automobile(s): CTS
    Aug 2004
    Hollywood, FL
    39
    753
    On the subject of does it fit: we've had this post before, but how many of you have wheels with a 114.3 lug spacing and not have a single problem with it? Most of the wheels that I've found I like have a 114.3 spacing, im just reluctant to do that.
    S10xGN's Avatar
    Feb 2004
    Port Neches, TX
    63
    250
    Quote Originally Posted by CTS Orlando
    Me!
  11. Remove Advertisements
