The throttle relearn process...
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By Kingoftypos
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, The throttle relearn process... in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; How to Relearn the ETC (electronic Throttle Control) If the battery is disconnected, the electronic throttle control (ETC) may forget ...
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,156
    If the battery is disconnected, the electronic throttle control (ETC) may forget the zero throttle position too. If you find that your CTS runs poorly, you will have to have the re-learn the position.
    To do this,
    • Turn the key to the run position with the engine off for at least three minutes.
    • Then turn the key to the off position.
    • Start the engine and let it idle for 30 seconds.
    • Turn the engine off and restart. The learning process should be complete.
    I found this process on the website cadillacfaq.com Please visit that site for other answers and what not.
    KOT
    epchavez likes this.
    johnys customs's Avatar
    johnys customs is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cts 3.6 Auto
    Aug 2011
    South Loop Chicago
    472
    Re: The throttle relearn process...
    when ya say "run position" that mean turn the ignition on but not the engine right?
    thanks
    Rodney6661 is offline Cadillac Owners Member
    Automobile(s): 1983 Cadillac Deville
    Jun 2011
    Birmingham,AL
    26
    So did this work for you? I was told turn the key to the on position for 30 seconds off and then start it up. But that doesn't work. I'm sorry i have a catera.
    forumoto is offline Cadillac Owners Member
    Nov 2011
    93
    59
    kOT, i also have a file to share as to the learned procedure... please cross check, if it fits, you give go ahead for publication...
    http://www.google.com/url?sa=t&rct=j...5tvtGOpsHLbuZQ
    Apr 2009
    Ledyard, CT
    37
    9,156
    According to that page, there is no procedure for our cars. However, I had to do the procedure that I listed last year due to a certain CEL code that I received. It was something pertaining to the throttle position and what not, exact code I don't recall. After I did the procedure that I listed, no more CEL.
    KOT
    sandalet's Avatar
    sandalet is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-2003, 3.2 automatic
    Nov 2011
    Chechnya, Grozny-City
    39
    617
    Throttle training only on the cold engine. All should be disconnected. Pedals can't be touched.
    Include the engine, wait for 20 seconds and switch off it. Wait for 20 seconds. Repeat it 3 times. After the third time start the engine. Let it works before inclusion of the first speed of the fan of cooling. Smoothly press a gas pedal up to the end. Don't pay attention to a handicap. Smoothly release a gas pedal. Training is finished.
    wantboost is offline Cadillac Owners Fanatic
    Automobile(s): '06 CTS 3.6L:HID HEADLIGHT/FOGS:LED INTERIOR/PLATE/TRIANGLE:
    Oct 2010
    GTA
    337
    SO which method works??
    sandalet's Avatar
    Nov 2011
    39
    617
    It is algorithm of programming by the diagnostic scanner which is available for dealers. If scanner isn't present-it procedure completely copies this process in manual mode.
  11. Remove Advertisements
