Is my transmission finished?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Like Tree3Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Is my transmission finished? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey guys, we"ll today I was driving home on the hwy doing about 110-120 km/h, and went to go pass ...
    family-man is offline Cadillac Owners Member
    Aug 2011
    31
    66
    Hey guys, we"ll today I was driving home on the hwy doing about 110-120 km/h, and went to go pass somebody, so i pushed the gas alittle bit harder than usual, probably went into 3rd, than the usual 4th gear (i have an automatic in my '06 cts). So rite after i did that, about 5 seconds later a pure cloud white smoke is seen in my rearview and keeps travelling with my car. I knew it wasnt coming from the engine becase that was still revving, but while in Drive, the car would just rev as it would rev if you are to have it in Neutral. I managed to pull over and tried several times to shut off the car and try Drive again and still just revving. I looked under the car and no oil from the transmission but there was a clear oil spill on the ground and looks like it had come from under the engine, but couldnt really determine where it was coming from because the underside of the engine has those plastic covers. anyways does this sound like a case of a completely blown trannie or is there something i should look into. thanks
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    Re: Is my transmission finished?
    Is the lines from the transmission still connected to the radiator?
    RoyalFlush's Avatar
    RoyalFlush is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 3.6L v6 cts lux
    Jul 2005
    Queens NY
    34
    869
    I might have to bid u welcome to the broken radiator club.
    sterling is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Jun 2008
    248
    Sounds like what odthetruth said, one of the lines connecting the radiator probably busted. Same thing happened to me with the same symptoms. Probably run you around $500 for a new radiator and labor.
    hoopr50's Avatar
    hoopr50 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac Cts
    Jul 2010
    Pittsburgh, Pa
    162
    this sounds exactly like what happened to me and mine was the tranny cooler line blew out of the radiator
    X Rolls-Royce is offline Cadillac Owners Connoisseur
    Sep 2011
    60
    4,193
    Is there any way to PREVENT that cooler line from blowing out ? I'm getting antsy about this happening to me.
    Quote Originally Posted by hoopr50 View Post
    Aug 2011
    31
    66
    so if you guys have had the exact same problem with no movement, just revving in drive (same revving as if you were to be in Neutral), did you guys require and new transmission or just replaced those lines and/or the rad and/or the transmission? if just the rad and/or lines, was the trannie fine once these parts and fluid was put back inside the trannie?
    Another question I have, since the CTS-V is based on the same body/frame as our cts, is there a different setup for the cts-v considering this problem occurs once the engine/trannie is under heavier than normal load which causes higher pressure tolerances within the lines, because the cts-v is, afterall, a performance car which is meant to be driven under heavy load, so back to my question, is this pretty common with the V models (all yrs) and 08+ cts's?
    Since it seems that there is alot of us having this problem, was there any sort of "recall" or bulletin, because they (GM) have to put these cars through rigorous testing, and since its been happening alot, wouldnt they know of it? I purchased the car privately, which means i dont have warranty, so Im probaly going to have to pay for the labour and parts myself...
    RoyalFlush's Avatar
    Jul 2005
    Queens NY
    34
    869
    your trans should be fine. our tranny's will not engage unless it is pressurized with fluid. and from the looks of it we all recovered from the problem without a new trans.
    CT ESSENCE is offline Cadillac Owners Fanatic
    Jun 2005
    465
    f-m, I would rule-out the problem by first repairing the tranny hose/radiator issue, and then filing with the required amount of tranny fluid. Hopefully the tranny is not engaging at this point because of low fluid level, and not because of catastrophic damage.
    EDIT: Ooopsies,..Royal Flush beat me to it.. LOL.
    Sep 2011
    60
    4,193
    I have been trying to understand this common problem before it happens to me. I already suggested (no one answered me) that since the dealer's transmission flushing machine had a defect that was fixed later, and it connects to where the hose blows out, if the rash of blowouts is actually from damage done at the first 50,000 mile tranny flush. Anybody ?
    Quote Originally Posted by family-man View Post
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    Quote Originally Posted by X Rolls-Royce View Post
    what exactly are you trying to ask without all the extra nonsense you put in some of your post? i never answer you most of the time, because I dont understand your questions or concerns
    johnys customs's Avatar
    johnys customs is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cts 3.6 Auto
    Aug 2011
    South Loop Chicago
    472
    ^ 2
    lmfao.....i thought i was the only one who thought that.....i noticed alot of members on here do the same....i catch myself saying out "what the fuk are you asking again?"
    eh nevermind....i just go to the next one...
    Argent1 and Argent1 like this.
    txbest1980's Avatar
    Dec 2008
    36
    6,414
    Quote Originally Posted by johnys customs View Post
    ^ 2
    this actually use to be a great forum once upon a time, but now there is more nonsense talk than actual helpful information...hince a reason why a lot of the good members left or rarely come around, now granted there are a few still around
  16. #14
    Sep 2011
    60
    4,193
    Sorry guy, thanks for being blunt. The question is how can I keep my cooler lines from blowing out ? Change the hose before its too late maybe ?
    Also the tensioner for the serpentine belt wobbles. Is that normal or should I replace it ? (nobody answered me on that one either)
    Quote Originally Posted by txbest1980 View Post
  17. #15
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    Its not the hose, its the fitting, so in order to keep it from blowing out, you'd have to change the rad.
    THE BEST WAY TO STOP THE ISSUE IS TO PATCH THE RADIATOR AND RUN AN EXTERNAL TRANSMISSION COOLER
  18. Remove Advertisements
