How to remove a broken oil filter cap/cover?
Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Like Tree7Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, How to remove a broken oil filter cap/cover? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey guys, I was changing my oil today and when I went to unscrew the oil filter cover, the top ...
    CTS_Newb is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac CTS
    Jan 2010
    Ohio
    29
    67
    Hey guys,
    I was changing my oil today and when I went to unscrew the oil filter cover, the top bolt sheared straight off the housing cap.
    So, how would I go about getting the damaged cover off so i can install the new one I have on order from GM? I have tried several different strap-tuype wrenches, oil filter sockets, pipe wrenches of various size, etc. Everything is either too big to rotate (pipe wrenches) or slides off the smooth and curved sides of the filter cap...
    Picture attached...
    sx54dx's Avatar
    sx54dx is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Mar 2009
    Cincinnati, Ohio
    35
    111
    http://buy1.snapon.com/catalog/item....e=&dir=catalog
    Something like that might be your best option. Autozone should have a cheaper alternative...
    It clamps tighter as you loosen/rotate the ratchet.
    That's a tough break, was it hot when you tried to remove it?
    ~Tony
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,300
    I would drill holes into the sides. But have a second person with you and a vacuum to suck up the shavings.
    KOT
    Jan 2010
    Ohio
    29
    67
    Re: How to remove a broken oil filter cap/cover?
    Quote Originally Posted by sx54dx View Post
    ~Tony
    Yeah it was about 110 when I was trying to take it off....
    Ill have to check Autozone and see if they have an equivalent tool.
    Quote Originally Posted by Kingoftypos View Post
    KOT
    I must be missing the point....drill holes into the side and then what?
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    Quote Originally Posted by CTS_Newb View Post
    Hey guys,
    Picture attached...
    Channel locks or a pipe wrench. And don't put the new one on so tight. The torque value is stamped right on it.
    Pipe wrenches come in various sizes & are adjustable.
    Argent1's Avatar
    Nov 2010
    2,937
    I think he means your engine/oil, never change cold oil.
    Apr 2009
    Ledyard, CT
    38
    9,300
    Sorry, for the lack of information. It may then be possible to insert something to give you leverage. Hopefully you'll be able to go all the way to the other side to give you better leverage. Just something along those lines is what I was thinking.
    KOT
    Jim's 06 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2006
    196
    Kind of like in the old days with a cartidge filter: drill a hole big enough for a large/long Philips screwdriver all the way through the filter and cap and through the other side. Insert screwdriver and turn counterclockwise. Clean out ALL the debris before refilling etc. By the way, did some commercial oil change outfit do this?
    Argent1's Avatar
    Nov 2010
    2,937
    Did you rember........Lefty, Loosey...........Righty, Tighty ?
    goose CTS is offline Cadillac Owners Member
    Automobile(s): 2005 CTS, 2004 Chev Tahoe
    Oct 2011
    Minneapolis, MN
    5
    How did you end up resolving this?
    I just did the same thing, cant get a channel locks or pipe wrench of any size to hold on.
    redhammer is offline Cadillac Owners Member
    Feb 2012
    73
    Can you try to punch a hole instead of drill so no shavings fall in? Like us a small metal punch?
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    try a normal oil filter band wrench, or filter pliers.
    if you use the pliers you can line up where the teeth are and put notches in the cap so you can get a grip
    Red Dwarf is offline Cadillac Owners Fanatic
    Automobile(s): 2014 SRX
    Feb 2005
    Sonoma, Calif
    136
    I would try filing some slots on the sides to give your wrench something to grip?
  16. #14
    johnys customs's Avatar
    johnys customs is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cts 3.6 Auto
    Aug 2011
    South Loop Chicago
    472
    one of them old school filter puller will do the trick in a heart beat
  17. #15
    Lzr
    Lzr is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS - 3.6L, perf pkg, RX catch can, Vmax Ice, Volant CAI
    Oct 2011
    Montreal, Qc
    353
    Quote Originally Posted by Jim's 06 View Post
    that is what 1st came to mind, and that is what i would do, the old one is ruined anyways so no point in buying more tools that won't work, when that would do it right away
  18. Remove Advertisements
