How to remove a broken oil filter cap/cover? - Page 2
Results 16 to 30 of 33
Like Tree7Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, How to remove a broken oil filter cap/cover? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Call me Jeremy Clarkson...my first thought was a hammer or a stick of dynamite....
  1. #16
    concorso is offline Cadillac Owners Master
    Dec 2007
    5,630
    Re: How to remove a broken oil filter cap/cover?
    AirborneMechanic and CTSM like this.
  2. #17
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    Actually, a hammer & centre punch could have been the answer.
    Did he ever come back & tell how he resolved it ? Or even how he did that in the first place ?
  3. #18
    goose CTS is offline Cadillac Owners Member
    Automobile(s): 2005 CTS, 2004 Chev Tahoe
    Oct 2011
    Minneapolis, MN
    5
    Quote Originally Posted by Argent1 View Post
    Just got the bugger off. The hammer and punch method worked for me...about 3 minutes of good 'ol mid-evil impact maintenance did the trick.
    thanks everyone...we're all in this together
    CTSM likes this.
  4. #19
    redhammer is offline Cadillac Owners Member
    Feb 2012
    73
    Excellent nothing like going neanderthal for 3 mins.
    CTSM likes this.
  5. #20
    sampson is offline Cadillac Owners Member
    Automobile(s): none
    Jan 2009
    52
    13
    Same problem yesterday. My solution was an old wood chisel and a claw hammer to turn the broken cap until I got it unseated. $55 for the new cap from the local dealer. Hope this one holds up better
  6. #21
    Argent1's Avatar
    Nov 2010
    2,937
    What are you guys torqueing these things to ?
    I believe the proper value is stamped right on it. I have never used a torque wrench on mine, just common sense, and never had a problem.
  7. #22
    meestayenkins is offline Cadillac Owners Member
    Automobile(s): 2006 SRX
    Sep 2012
    30
    1
    Just happened to me. I have made all of the oil changes on my SRX since I bought it (22k miles now 66k miles) except for ONCE. This past time I had the dealership do it because my car was eating oil. They torqued the damn thing on so hard. My damage looks identical to the OPs. After close inspection of the bolt that broke off, the dealership obviously used an impact wrench when they did the oil change. I worked erecting steel for about a year and nothing makes marks on a bolt head quite like an impact wrench. Mine sheared off under normal pressure from an 8" socket wrench.
  8. #23
    Cadillac ryder is offline Cadillac Owners Member
    Apr 2013
    1
    same thing happened to my 06 cts 3.6l, does anybody happen to know the part number of hand? thanks
  9. #24
    AirborneMechanic is offline Cadillac Owners Member
    Automobile(s): 08 CTS AWD
    Jul 2011
    33
    12
    http://www.gmpartseast.com/Page_Prod...Code=6D1&Year= You are looking at item number 450 and the seal is 451. Still working on getting my cap off. No luck so far, punch and hammer, large pipe wrench and a little blood. All unsuccessful so far.
  10. #25
    Muhammad's Avatar
    Muhammad is offline Cadillac Owners Fanatic
    Automobile(s): CTS 2005 Sports Luxury 2.8 V6
    Feb 2011
    London, England
    137
    My last resort would be, (depending on the clearance on the side) I would drill a hole on the side of the broken oil cap and across (through the old oil filter), insert a hard metal rod through and twist. PLEASE BE VERY CAREFUL I feel that the surface of metal oil cap is very slippery and you may end of damaging other things.
    BTW what is the part number for the oil cap so I can order one for myself too.
  11. #26
    Jul 2011
    33
    12
    Quote Originally Posted by Muhammad View Post
    Part number is 12583470. This is evidently a frequent occurrence as they are stocked local to me here in Omaha for $39, I did find them cheaper online but I do not have the luxury of waiting.
  12. #27
    Jim's 06 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2006
    191
    I have a filter remover that will really work on this: it's a gear-driven device that when attached to a 3/8" drive ratchet, tightens harder and harder as you turn it counterclockwise. I got it at Sears. I can't wait to use it on my own eventually-busted filter cap!
  13. #28
    454Casull is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS 2.8L 6MT
    Apr 2010
    406
    The filter cap will last indefinitely if you apply the rated torque to it. It's actually a very light touch.
    Argent1 likes this.
  14. #29
    juang7 is offline Cadillac Owners Member
    Automobile(s): CTS
    Jan 2011
    Hi..first time posting. This hit me this weekend. I went through several trips to store, and tools. Finally...my new favorite tool...air hammer did the trick. Also note, a lot of torque wrenches are in kilogram-force meter not newton meter which is 10x nm.
  15. #30
    Pete(UK)'s Avatar
    Pete(UK) is offline Cadillac Owners Fanatic
    Automobile(s): CTS 2007 Sport Luxury
    Mar 2013
    London, England.
    126
    Torque settings should be 18 ft lbs/25 nm for the filter cap
    $24 on amazon.
    http://www.amazon.com/ACDelco-125834.../dp/B007Q13M2Y
  16. Remove Advertisements
