Cts stalls and wont start back up!!! Please help!!
Results 1 to 12 of 12
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Cts stalls and wont start back up!!! Please help!! in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; OK, car just had valve covers replaced, and I replaced the tensioner pulley. Before doing so the car unexplained stalled ...
    twotonius is offline Cadillac Owners Member
    Apr 2011
    4
    Before doing so the car unexplained stalled a about 8 times, until the last three stalls it started right back up, the last three it hasn't. First two times the car was towed and immediately started upon arrival. I got the car back from the shop a few days ago from the valve cover replacement and everything seemed fine. Tonight I was cleaning it and decided to drive it around my street to see if I could get it to stall so I could pull the codes, just when I was giving up I pulled it in to my garage and sure enough it stalled, and wont start back up. I checked the codes and was pulling:
    U1000 h Loss of Seriel communications for class 2/ class 2 malfunction etc.
    P0335c Crankshaft Position [CKP] Sensor A Circuit
    P0700 Transmission Control System (MIL Request)
    I am concerned with all three but my assumptions are that the U1000 is my starting issue.
    I want to get this fixed and go back to enjoying my CTS, Any insight and help is Welcome....Thank You in advance
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxcatch Guest
    Re: Cts stalls and wont start back up!!! Please help!!
    crank position sensor?
    Sounds like it
    Apr 2011
    4
    I have been reading some other threads and that is one of my best options. I am going to clean some wiring connections tomorrow and attempt replacing the Cps and see if that fixes it, any info on replacing the cps would be helpful for I have never changed it on this before
    Sammy Z's Avatar
    Sammy Z is offline Cadillac Owners Connoisseur
    Automobile(s): CTS 03
    Jan 2008
    Chicago, IL
    1,765
    They are about $60. Its locatated by the oil filter. You will neeed a torx socket to remove it. there are a few zip ties holding the wire, clip those. Tie a string to the CPS to pull the new connector through. For the connector, its at the top of the engine in the rear on the fire wall. Lay on the engine with a flash light and you will see it back there. it took me about 40 min to replace, I didn't run the wire exactly like the factory did, just keep it away from the hot manifold.
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    What year / engine?
    03? If so, its most likely CPS
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    you will get much more help if you state what year and engine...if it isnt an 03, then you have other issues
    Apr 2011
    4
    Yes it is a 2003 cts 3.2v6
    Does anyone have any pictures or any more advice? I think I can probably figure it out. Also, you said to clip the zip ties, did you replace them when you were done? And just so I am not assuming wrong the best way to get the cps is from underneath correct?
    Apr 2011
    4
    Also what size torx socket?
    And it is the luxury sport model if makes any difference.
    Both my Snow mode and sport mode stopped working about 6 months ago also, anybody have repair ideas?
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    ive had that U1000 code before, pop the cover on your fuse box and make sure they are all good. one of mine blew.
    also the stalling is likely the CPS.
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,149
    Consider your self lucky to get a crank shaft position sensor code. 95% of the 3.2 CTS don't produce a code for the CPS. So people/dealers start to replace high dollar items when it's actually a $60 item.
    KOT
    Sammy Z's Avatar
    Jan 2008
    Chicago, IL
    1,765
    Quote Originally Posted by twotonius View Post
    Yes, I zip tied the new wire, but not exactly like the factory. It helps if the engine is not hot. Yes, you have to get under the car to change the actual sensor. The Torx socket is about 10mm, I can't remember the number on it, I had to buy a full set when I needed it.
    ericaabadie is offline Cadillac Owners Member
    Sep 2013
    1
    Re: Cts stalls and wont start back up!!! Please help!! we just replase the serpentine
  15. Remove Advertisements
