*** FAQ - DIY - Guides - How-To - Manuals ***
226K views 41 replies 21 participants last post by  hdhart
#1 · (Edited by Moderator)
Owners Manual
2007 - 2007_cadillac_cts_owners.pdf (Although this is a 2007 manual, most of the content should be the same for all 2003-2007 cars.)
FAQ
(2.8 and 3.6 are similar and certain guides could be used for both engines.)
Common Issues and recalls
Transmission Cooler Line failures - Primary Issue #1
Timing Chain on 3.6 / 2.8 - Primary Issue #2
Wiper/sprayer motor failure - COMMON ISSUE: Windshield wipers won't turn off
Rusted brake hard lines - Brake Issue - hard line failure / rusted brake hard lines
Front frame rail rust - CTS frame rust????
Sail panel / C-pillar interior trim panel comes loose - Rear interior sail panel fix?
Significant Recalls / TSBs
Brake hose recall for cold / winter states / countries (rusty brake lines may fail)
Steering Recall
Passenger seat airbag recall
Differential pinion seal recall
ECM reprogram for fuel delivery recall
3.2L PCV valve TSB
Exterior and Appearance Modifications
How to determine whether you have HIDs or halogen lights
HID installation on stock Halogen (refer to bumper guide as well for extra assistance)
HID ballast replacement without stock ballast
Clear Fog light tutorial
STS-V Fogs in CTS installation
Front Bumper Removal
Rear Bumper Removal
How to fix 3rd Brake Light
How to convert 3rd brake light to LED
How to disable DRL
How to debadge
How to remove Side mirrors
How to install Side mirrors
How to remove the grill
How to drill and install a spoiler
How to install spoiler with 3m double sided tape
How to plug up holes from Front plate holder removal
2-item DIY Outside mirror and dash cover removal
How to replace Trunk Support
Interior Modifications
How to do suede door inserts
How to suede your headliner
How to change LED lights on interior lights
How to freshen up leather seats
How to switch outlets from constant on, to on only when car is on
Dash cluster removal
Alarm, Security and Audio
How to program keys
How to change Door Speakers
How to remove rear deck lid to access subwoofer
How to change DIC color
How to install iPod into your radio
How to Unjam CD from Radio
How to change stock radio into NAV system
How to retain DIC with Aftermarket Radio 1
How to retain DIC with Aftermarket Radio 2
USA-SPEC Direct iPod Interface install
CARPUTER
CARPUTER GUIDE
More double din install info
The complete guide to 1st gen CTS Navigation unit installation
How to add an auxiliary switch input
Double DIN LED light fix
Maintenance and Fixes
3.2L V6:
How to change the alternator on a 3.2L / 2.6 V6
How to change Spark Plugs on the 3.2L
How to change Serpentine belt in 3.2 engine
How to check OBDII codes on '03 CTS
3.2L PCV Service Bulletin How-To
2.8 / 3.6L V6:
How to change Spark Plugs on the 2.8L and 3.6L
How to change the alternator on a 2.8L / 3.6L V6
How to change oil in 3.6 / 2.8 engine
3.6L Timing Chain Repair Guide 1
3.6L Timing Chain Repair Guide 2
3.6L Timing Chain Repair Guide 3 off an SRX
Timing chain replacement - 2005 3.6L
Cylinder / Coil Pack Numbers on 3.6 / 2.8 system
Drivetrain:
How to change automatic transmission fluid in 5L40E
How to remove differential
"No Reverse" fix for Aisin 6 speed manual (3.6L) - (Shifter bushing)
Transmission Cooler Install - Documented
Transmission line failure & external tranny cooler install
General maintenance:
How to replace Cabin Air Filter
How to Seafoam your car
How to perform the Throttle Position Relearn procedure
Reprogram TPMS system (Tire pressure monitoring system)
The Bushing Thread
Intake, Exhaust and Performance
3.2L Dyno Results from Various Intakes
3.6L Dyno Results from Various Intakes
Swaybar Diameter List
From Single to Dual Exhaust Installation
TonyA Intake - DIY "ram air"
Ghettano Intake - DIY "ram air" / cold air intake
How to add V-Max iceolater
RX Oil Catch Can DIY
#4 · (Edited by Moderator)
#5 · (Edited by Moderator)
Hey,
Would you please add the carputer diy guide link: CARPUTER and/or link: CARPUTER GUIDE Thanks!!! added 2/25/11 -JH
#7 · (Edited by Moderator)
Here is a copy&paste from cadillacfaq.com
How to Relearn the ETC (electronic Throttle Control)
If the battery is disconnected, the electronic throttle control (ETC) may forget the zero throttle position too. If you find that your CTS runs poorly, you will have to have the re-learn the position.
To do this, turn the key to the run position with the engine off for atleast three minutes. Then turn the key to the off position. Start the engine and let it idle for 30 seconds. Turn the engine off and restart.
#8 · (Edited)
January 31, 2005
#05-08-44-002
2004-2005 Cadillac CTS and SRX with level 1 U2R or level 1.5 U2S radio
• The Driver Information Center trip odometer, timer, or fuel used displays may intermittently reset to zero
• The six disc CD changer may randomly shuffle or reinitialize
• The radio may display lines with no alphanumeric characters
• The audio volume of external sources (XM Radio and Rear Seat Entertainment) may be lower than internal sources (AM/FM/CD)
THIS CONDITION MAY BE CAUSED BY SOFTWARE ANOMALIES. Replace the unit.
U.S. Dealers : Obtain the exchange unit from Specmo Enterprises, Madison Heights, Michigan (800) 545-7911 or (248) 307-2570.
Canadian Dealers : Obtain the exchange unit from an authorized ACDelco Radio Centre.
Follow the radio replacement procedure described in SI document #702067
Perform the radio setup procedure described in SI document #1420146 (CTS) or #1470416 (SRX)
#11 ·
The filter is under the car about where the driver's door is. If the fittings are rusty use some penetrating oil/rust remover product first, let that sit for a day if its real rusty and you aren't in a rush. I think you're supposed to release the pressure first for best results, but I'm not sure.
#16 · (Edited)
Trying something currently see how this goes will update once more have uploaded and see how long this lasts, let me know how the links work out for you some of them allow online reading and some may have to be downloaded (guess its the mass amount of pages!):
Service Repair PDFs
Generic Trouble Codes
GM Trouble Codes
2.8L Engines
2005:
Engine: 1 2 3 4 5
2006:
Introduction
Troubleshooting
Engine: 1 2 3 4 5
3.2L Engines:
Engine
Drive Belt
Oil Pan
Timing Belt
Timing Belt Replacement
Engine Exhaust
Engine Cooling
3.6L Engines:
2005:
Engine: 1 2 3 4 5
2006:
Introduction
Engine: 1 2 3 4 5
Engine cooling
Engine electrical
2003 related PDF's:
Drive belt routing
Computer relearn
Owners Manual
Cooling fans
Starter
Wiring diagrams
2004 related PDF's:
Hydraulic brakes
Sunroof
Steering column
Power steering
Wiring diagrams
2005 related PDF's:
Maintenance
Cabin air filter
Keyless entry
Variable effort steering
Horns
Drive axle limited slip
HVAC 1 2
Automatic transmission: overhaul | troubleshooting
Wheel drive shafts
Universal joint
Front suspension
Navigation system
Electric components
Frame underbody
Cruise control
Defogger
Interior trim
Parking brake
Rear suspension
Clutch
Wiring diagrams
Manual transmission ay6
Entertainment
Wiper washer
Disc brakes
Exterior lighting
Manual transmission tremec 6 speed
Antilock brakes
Seats
Instrument panel
Engine electrical
Airbags
Doors
2006 related PDF's:
Wheel driveshafts
Windows
Wiper washer
Wiring diagrams
Seats
Sunroof
Suspension general diagnosis
Steering column
Rear suspension
Rear drive axle
Programming and setup
Power steering
Tyre pressure monitor
Maintenance and lube
Navigation
Parking brakes
Manual trans ay6
Manual trans tremec 6 speed
Maintenance light reset
Limited slip diff
Interior trim
Horns
Hydraulic brakes
Instrument panel
HVAC 1 2
Front suspension
Exterior trim
Lighting systems troubleshooting
Entertainment
Exhaust
Electrical component locations
Driveshaft
Disc brakes
Doors
Cruise Control
Clutch
Cabin air filter
Bumpers
Body front end
Antilock brakes
Owners manual
Computer integrating system
Auto trans troubleshooting
If anyone has the 2007's to add let me know ive all of 2003-2006 mostly
Here is the owners manual though:
2007 CTS owners manual
#19 ·
I didn't look at all 7 pages to see if someone had listed a DIY for this, but it wasn't in the first page.
Is there any way we could get a DIY for removing the rear trunk bezel?
I'm thinking of taking mine off to clean the inside of it, as it looks very water spotted and dirty on the inside. (I have an 03 CTS with the greyish clear plastic bezel).
Not only would this DIY help people with my type of bezel to clean it, it would also assist someone of you wished to replace the old style bezel with the new one.
Like say you had this...
Land vehicle Vehicle Car Executive car Motor vehicle
And wanted this....
Land vehicle Vehicle Car Luxury vehicle Executive car
#20 ·
Rear bezel removal is relatively simple.
Remove your trunk lid carpet liner, most of it will pull off and the panel clips will come with it if not use needle nose pliers or a panel pin removal tool.
once you have that off there will be some 10mm nuts to remove (you will see the thread for the bolt sticking out of the holes with like a star type head to it) that are sunk into holes you will need a deep 10mm socket for these, remove all of them and the panel will then come loose, after that you need to disconnect the wiring harness and then you have a panel free from the body.
Could have done a guide last week lol as I was fitting a reverse camera to my CTS and had to remove that panel.
#21 ·
Thank you! That's helpful. You probably have the metal bezel, so I guess I'd have to figure out a way to get inside the plastic housing to clean the clearish grey plastic.
And I have to ask, do have the nav system and were you able to hook it up to that monitor or did you install another monitor?
#22 ·
My filler panel is plastic not metal, only the bootlid part is metal, as for getting within the inside it might require a little heat to separate them possibly but without seeing one in the flesh i wouldn't like to say all the euro ones come without that as standard, never know there might be some more things to unscrew inside as most of the lights are held in by hex screws.
must separate though as they sell them on ebay! http://www.ebay.com/itm/2003-up-Cad...Parts_Accessories&hash=item2574a7be88&vxp=mtr
#23 ·
I would agree they must separate somehow...seeing as water gets inside it anytime I wash my car or it rains. It slowly drains out but that is what primarily leaves the ugly, grimy, water spotted look. It's not noticeable from more than 3 feet, but it IS the trunk and you DO notice it when you are lifting the trunk open.
I would assume a seal is broken but can't see it from simply looking at it. I would also assume this issue is one of the reasons Cadillac switched to the metal bezels. Looks cleaner, more high quality.
Personally I like the look of the darker bezel though...it nicely contrasts my white diamond paint. I wish the plastic was a blackish color rather than brownish clearish grey, actually.
#25 ·
this is the best online parts catalog that i've found so far (at least for the illustrations and part numbers)
it's basically GM's official parts catalog for dealers to set up and use as an online store
the relevant page you're looking for is: http://parts.nalleygmc.com/showAssembly.aspx?ukey_assembly=376168&ukey_make=1023&ukey_model=14463&modelYear=2006&ukey_category=19512
looks like they don't sell the mufflers separately from the whole exhaust assembly (which is pretty expensive!)
the three differences look to be with or without NDB and with V92
i'd guess that you have NDB since it is a dual exhaust RPO code and it's more expensive (as you would expect the dual to be more expensive than the single)
