*** FAQ - DIY - Guides - How-To - Manuals *** - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Like Tree34Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, *** FAQ - DIY - Guides - How-To - Manuals *** in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; http://helminc.com for the GM factory service manual...
  1. #31
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    Re: *** FAQ - DIY - Guides - How-To - Manuals ***
  2. #32
    ynothd is offline Cadillac Owners Member
    Automobile(s): CTS
    Mar 2014
    McDaniels, Ky.
    52
    35
    2003 3.2 timing belt replacement info, here are some pics of the timing marks and "I didnt have to buy the $120 timing tool" i just set the cams one at a time by hand. when tearing down set the crank pulley at about 11:00 o'clock so there is adequate room in the cylinders for the cams to move without touching the valves on the pistons. then remove the belt, when installing the new belt use the lines on the new belt to help line up your marks. before you remove the crank pulley remove 1 (one) bolt and with "whiteout" paint the bolt hole all the way threw it so you know where the pulley was originally this is very important later. I had to remove both heads and install all the intake valves my self because no machine shop in my rural area wanted to touch them. and the theory that the lifters must go back in the same holes is false. I went and got a set of used lifters and installed them so witch hole did they belong in???? and all is fine. but when you are at the end of your repair and you had the heads off you must make a tool to pump oil in the oil galleys from the oil sending unit or you will have a lifter tick you cant get rid of!!!!! its not such a bad job to do but you must have the patients of god, just take your time work with a positive attitude and it will be ok. here is the timing mark on the crank everyone says is not there, notice the pointer on the oil pump? and the lines on the crank pulley? if you didnt paint the bolt hole you will not know witch place to put the crank pulley on at. therefore making the timing mark useless unless you know that the straight like on the timing belt crank gear points straight down. like i said i didnt buy the tool for this and it was no trouble to set the timing for me but if you are taking off the cam pulleys they can be 180 out of time so with your whiteout mark the sides of the cam gears on the side the pin in the end of the cams are. i wish i had taken more photos but these are the most important so you can make it through this with no troubles good luck anyone who is doing this can call me for info 270-617-8258 Tony..... also i bought my timing kit $77.35 from http://www.partsgeek.com/catalog/200...ming_belt.html quality stuff and my head gasket kit $163.35 http://www.partsgeek.com/catalog/200...ad_gasket.html , valves from ebay $77.88 http://www.ebay.com/itm/Cadillac-Sat...4c6467&vxp=mtr waterpump and thermostat/with housing from autozone. dont break the tube coming from the thermostat housing to the side of the head out of production from caddy, EXTREMELY HARD TO FIND !!!!!!! also notice that i numbered my cams and cam caps and kept them together at all times, i layed everything out in order of removal from the front of car to the rear so i knew how to do it in reverse order when going back together. B&M Oil/Trans cooler $71.67 http://www.amazon.com/s/ref=nb_sb_no...20oil%20cooler
    I RESEARCHED ALL THESE PRICES FOR 2 WEEKS AND THIS IS THE BEST PARTS FOR THE BEST PRICES and i bought my oil cooler lines at a semi truck parts house the were air-o-quip fittings and they were somewhat worried that the fittings were a lil big for my original trans rubber hoses but they worked 100% fine they also sold me the hose to make the extensions to the cooler i bought 3' but used about 2.5 ft, a lil extra is better than not enough.
    i spent about $850 in parts
  3. #33
    Automobile(s): CTS
    Mar 2014
    McDaniels, Ky.
    52
    35
  5. #34
    laws224 is offline Cadillac Owners Member
    Automobile(s): CTS
    Apr 2010
    72
    1
    Hello, not sure if in correct forum location or not, computer idiot. I'm looking for help with problem with 06 CTS with 3.6 and 120k. Car has been well maintained and driven. New plugs at 100k. The major drivability problem I have with car (beside having to remove front end and adding a qt. of oil every 1000 miles). Every since 30-40k when I park the car for more than a couple of days and my first attempt to start the car it would stumble and misfire. Thinking that it was a battery problem I started putting a trickle charger on it, but the charger has not really helped beyond ruling out a battery/voltage problem. The misfire has gradually gotten worse. I just returned from a week long trip, before I left I put the car in the garage and put the trickle charger on a 2 month old battery. When I returned I checked battery voltage 12.95 volts. When I attemped to start car it started briefly but was stumblin and coughing very badly and shut off after a couple of seconds. On my next try the started did not sound normal at all and it would not start. I let it set for about 60 seconds and it fired up but with about the same results as first time, I gave it a few pats of gas and it gradually came to life, and it ran fine for the rest of the day. I replace the fuel and air intake filters about 3 months ago, and I alway turn the key on and pause a couple of seconds for the fuel pump to catch up before I hit starter. Any ideas or suggestions (except match in fuel tank) out there? Thanks Barry
  6. #35
    Bud Farrell's Avatar
    Bud Farrell is offline Cadillac Owners Member
    Automobile(s): 2004 CTS Base 3.6L
    Jun 2014
    WV
    12
    Found this tid-bit of info today. Haven't seen this in forum. Disregard if already posted somewhere
    Part Restriction on the ECM for 3.6 LY7
    http://www.cadillacfaq.com/faq/tsb/data/pip3393a.pdf
  7. #36
    Automobile(s): CTS
    Mar 2014
    McDaniels, Ky.
    52
    35
    Quote Originally Posted by PinkLisa View Post
    Is there a link to the "common issues" about wiper failure?
    if you are having wiper troubles go to a junk yard and get a used wiper motor and put it on, that is the most cost effective way to repair. mine would come on by them selves all the time
    Quote Originally Posted by laws224 View Post
    .............. have you had the coils checked?
  8. #37
    Jun 2014
    WV
    12
    Here is my contribution..
    It's that time of year again and many are finding that the drivers seat is COLD after pressing the seat heater button.
    Here are a couple of links that may help you solve this common problem.
    http://www.cadillacfaq.com/faq/tsb/d...-08-50-009.pdf
    and
    http://youtu.be/oa-yiJrAaKI
    Will be using this info to keep my butt warm.
  9. #38
    cswimc is offline Cadillac Owners Member
    Automobile(s): 2007 CTS Sports Sedan
    Feb 2011
    39
    I recently found this video on Youtube for changing spark plugs and coil packs and while there is a great write up on here already, this video does a pretty good job showing the process overall:
    Note: I did not make this video... I just found it with my googlefu skills!
  10. Remove Advertisements
