Transmission Lines
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Like Tree1Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Transmission Lines in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; So I've been in the works of replacing the lines and also soon installing a PCV oil catch as well ...
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    Transmission Lines
    So I've been in the works of replacing the lines and also soon installing a PCV oil catch as well as a external trans cooler. The trans cooler is taking a backseat for now, I'm going to do the lines first off. However, when the line was being removed from the rad, seems like something happened, because now I can't thread it back in. Anyone got any suggestions besides a larger thread, teflon/loctite combo? Thats my first thought, but figured maybe someone knew a little better on this.
    blatant blue is offline Cadillac Owners Member
    Automobile(s): '07 Thunder Gray CTS 3.6L
    Oct 2010
    Alpena, MI
    31
    69
    Re: Transmission Lines
    This probably won't help, but I had the dealership flush/fill my tranny.. When they removed the lines from the radiator, they stripped the threads and had to REPLACE the radiator.
    I was shocked, but apparently you're not supposed to remove the lines or something.
    Pft, what a joke.
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    Quote Originally Posted by blatant blue View Post
    Pft, what a joke.
    I had gone for a trans flush / fill about 2 months ago. But thats definitely a good idea for people who may need a trans flush anyway. Kinda like knockin two birds with one stone.
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    ya the stripped lines is the main reason for the line blowing off.
    sorry to say but it looks like you need a new rad at a price tage of 350 i think or a aftermarket external cooler to the tune of 40-150
    anyone see these ones? they look kinda cool, but will they work??
    http://cgi.ebay.com/ebaymotors/18-FI...Q5fAccessories
    this design is more common but those fittings are going to need some adapters.
    http://cgi.ebay.com/ebaymotors/UNIVE...Q5fAccessories
    i like the look of this one with all the parts.
    http://cgi.ebay.com/ebaymotors/Flex-...Q5fAccessories
    someone else has one with a ballbering that stopper the flow till the tranny was at pooerating temp.. i think it was txbest... ide like to know the model of it.
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    http://www.cadillacforums.com/forums...ose-leads.html
    or more specifically
    http://www.cadillacforums.com/forums...ml#post2438937
    What do you think? Think retapping isn't worth it? If I have to get a new rad, then I'm definitely not going for the external cooler. I think I might go the route of doing the ext cooler and tapping into this rad though.
    ghettomike's Avatar
    Apr 2008
    off the grid.
    33
    7,872
    That post was about a plastic tube on the top of the rad, he broke the plastic.
    Re-tapping...I dunno man, its weak metal to begin with...your call.
    The point of running a external cooler is to bypass the rad and its faulty fittings, its not to add more cooling to the tranny.
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    New lines + external cooler = done.
    Now I'm off to home depot for the other parts for the PCV oil catch can. Thanks for the heads up on the whole setup. I'll hopefully have some pics of the PCV setup very soon.
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    od...sorry to say it, but you either need to do the external cooler now or replace the rad. as far as a new rad for $350+ seems a little crazy to me, i bought an aftermarket one off of ebay two years ago for $154 shipped to my door, so shop around. as you know i added the external cooler on my CTS when i had it, and out of the ones mike listed a few post up, i used one very similar to the third one he posted and got it from autozone
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    External cooler and the new trans lines are both done. I'll take some pics of how its mounted.
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    This is the external cooler for the trans. I have it mounted behind the grill. Underneath the car would have been a bad idea here in NYC. It would have been damaged, cracked, lost, etc
    MIKAR is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac CTS
    Aug 2011
    Livonia, MI
    37
    20
    QUESTION: When you (whomever has done it) installed the ext. cooler did you just cut the trans line and add the extra length? or did you replace the whole thing with a different kind of connection set up? (not sure if I understand my own second question)
    I guess what I ment to say was did you just use a hose with clamps at both ends? oh heck ...... can someone just tell me how they did it and if possiable show a couple pics of how you connected the trans lines both at the cooler and at the point where it attaches to the whatever its called (long day and frustrated that I didnt get it finished in one day !!!)
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    Cut and add, barbs and clamps.
    Aug 2011
    Livonia, MI
    37
    20
    Quote Originally Posted by odthetruth View Post
    Thank You !!!! Forgot to ask though .... what do you suggest I cap off the radiator with?
  16. #14
    johnys customs's Avatar
    johnys customs is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cts 3.6 Auto
    Aug 2011
    South Loop Chicago
    472
    ^ FYI Autozone, Oreillys etc all sell the fittings, couplers, plugs for this project. alot of times they dont know what your asking them for so they tell you know....Just tell em Show me the large box with the plumbing supplies. it's all there and low cost
    odthetruth and odthetruth like this.
  17. #15
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    Yup. Home Depot also has it in the plumbing dept, which is where I got mine at.
  18. Remove Advertisements
