when I turn on the right-turn signal lights, it will also turn on the high-beams
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 8 of 8
Like Tree2Likes
  • 2 Post By TunixComplex
  • 1 Post By 2007CTS
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, when I turn on the right-turn signal lights, it will also turn on the high-beams in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hi guys. I have a problem for my 2007 cts. It happened for most of time, not every time: when ...
    2007CTS is offline Cadillac Owners Member
    Automobile(s): 2007CTS3.6L and 2011 SRX 3.0 lux.
    Aug 2010
    23
    Hi guys. I have a problem for my 2007 cts. It happened for most of time, not every time: when I turn on the right-turn signal lights, the high-beams also are lighted on at the same time. but for left-turn, always normal. What's the problem?any ideas? many thanks.
    TunixComplex is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2 5M
    Jan 2010
    Springfeild, MO
    25
    615
    Re: when I turn on the right-turn signal lights, it will also turn on the high-beams
    I know it is a stupid question but I have to ask, are you sure you are not bumping it forward just a tad when you hit the signal?
    Next time you are in the car gently jiggle the turn signal/brights controls in all directions, see if any lights accidentally flip on, this would rule out the possibility of mechanical failure in the switch. The next thing I would do was make sure all light fuses are in working condition and cables were securely in place.
    ghettomike and ghettomike like this.
    Aug 2010
    23
    I tried in different ways. I found only when I turn on the right-turn signals, most of time it can also light on the high-beams, not every time. but when I turn on the left-turn signals, the problem never happened. I know the regular way to turn on the high-beams. I didn't bumper the lever forward when I turn on the right-turn signals.
    Quote Originally Posted by TunixComplex View Post
  5. #4
    jmwatgmi is offline Cadillac Owners Member
    Automobile(s): 2007 SRX4
    Apr 2011
    31
    3
    I have an 07 SRX that starting doing that last week too. Happened 2 or 3 times since. At first, I thought I did bump the switch forward, but when I pulled the switch, my brights actually came on. I realized that at first only the bright light dash indicator came on, not the lights themselves. So I'm thinking either a short on the dash lights, or the multifunction switch is going bad.
  6. #5
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    35
    7,793
    Quote Originally Posted by jmwatgmi
    If this helps... When you push the multi function lever forward. It turns on the high beams as well as the dash indicator. In this position the high beams stay ON. The same happens when you pull towards you, however once you let the lever go. It will go back to the OFF position. So the high beams and indicator does come on when you pull towards you.
    KOT
  7. #6
    coffeeandcadis is offline Cadillac Owners Member
    Automobile(s): 2007 CTS, previous owner of a 2001 Catera
    May 2014
    Mine does this also, every day. I've had other people drive and try it also and the high beams always come on. I've also pulled the multi function lever forward and backward to turn the high beams off while using my right turn signal and nothing helps but disengaging the turn signal.
    Not a huge issue but quite annoying, especially when people think I'm hurting their eyes on purpose!
  8. #7
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Fanatic
    Automobile(s): 2001 GTP / 2005 CTS / 2008 DTS
    Jul 2012
    Ontario, Canada
    474
    The switch needs replacing not fun. It is a common problem.
    Search old threads on the subject if I recall someone found a quicker and easier way then removing the steering wheel?
  9. #8
    Aug 2010
    23
    Oops, this old poster got pushed up again. I replaced a new switch lever and fixed the problem a few years ago. I remember I searched and followed a guy's procedures and successfully replaced it.
    Tom's Caddy likes this.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
