DIY: Suede (or other) your Door Inserts, With no adhesive!
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Like Tree2Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, DIY: Suede (or other) your Door Inserts, With no adhesive! in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; After wanting to do this for a while, I finally had the time so I searched the forums and couldnt ...
    Roachthetires's Avatar
    Roachthetires is offline Cadillac Owners Member
    Automobile(s): 06 3.6l Black Raven
    May 2010
    Midwest PA
    29
    28
    After wanting to do this for a while, I finally had the time so I searched the forums and couldnt find a write up on this so I figured hey, Ill try to do one.
    Here is what youll need:
    -Fabric of your choice (I went to a fabric store and got I think a 2'X1yard piece)
    -1 utility knife with new blades
    -2 screw drivers or what I used was a screw driver and a wood chisel( the sharp edge really helps get the fabric into your door)
    -Something to use as a template. I taped 2 pieces of paper together
    Ok and we're off!
    Step1: Youll need to pop off your door handle cover. I used this process from cadillacfaq. "On the bottom edge of the plastic door handle cover are two small cutouts. Insert a flat tool into that cutout about 1/2 - 3/4 inch and push up slightly to release the inside catch on the cover from the projection that holds it. It is best to do both at once to minimize stress on the door handle. Push up and out to remove the door handle cover while holding the door handle in the open position."
    Step 2: Next, Youll need to make a template for your door insert. I taped 2 pieces of paper together and traced around the edge of the door insert with my thumb nail to cut the paper and ended up with a pretty decent template.
    Step 3: Next, Youll need to transfer your template onto your fabric of choice. I used brown fake suede. I found the easiest way to accomplish this is to use a piece of cardboard and thumb tacks to hold everything tight while you cut out your piece. Be sure to leave 1/4 to 1/2" Extra around all sides. Its better to have to much than too little.
    Step 4: Here is the part that you have to be really careful doing. Take your utility knife with a fresh blade and trace around your door insert, Cutting the think piece of foam in the crack between the insert and the door. Dont worry, There is a piece of backing plastic that will prevent your insert from falling out of your door. In this pic you can see the layers of the door. Be sure to only do one pass with your blade. Ive found that multiple passes will make for a loose fit for the fabric. Note the thin plastic layer behind the foam: and here is me cutting around the insert:
    Step 5: After cutting CAREFULLY around the insert, Use your screw drive/ wood chisel to push your fabric into the slice you just created:
    Here is a close up pic of how clean it should look:
    If you run into a part where the fabric wont stay in the door tightly, What I did was cut a small strip of the fabric and used it sort of like a shim, jamming it into the slice where the fabric did not fit tightly.
    Step 6: After you have your fabric seated tightly around the perimeter of the insert, Now is the time to cut out the hole for your door handle. Be sure to leave at least an extra 1/4" when cutting out the hole. Its better to have more than less remember?
    Step 7: Reinstall your door handle cover and check that all the fabric is tight. Here is the finished product: and here is my girlfriend shooting my ar15;
    Enjoy!
    Rolex's Avatar
    Rolex is offline Super Moderator
    Automobile(s): 2008 Nissan Titan, 1996 Jeep Wrangler
    Arkansas
    41
    12,033
    Re: DIY: Suede (or other) your Door Inserts, With no adhesive!
    I altered your post to make your pics pop up. I hope you don't mind. Great thread, and the GF with the AR = I see you also refinished your AR...Duracoat?
    You get 10 internetz from me.
    The above post is my 2 cents....nothing more.
    May 2010
    Midwest PA
    29
    28
    Quote Originally Posted by Rolex View Post
    Thanks for the help! Yep its duracoat. Love that rifle
    tommy compton's Avatar
    tommy compton is offline Cadillac Owners Connoisseur
    Automobile(s): 06 CTS-V
    Mar 2007
    tha peg
    2,497
    Pretty slick idea
    nikon's Avatar
    nikon is offline Cadillac Owners Connoisseur
    Automobile(s): 05' CTS-V
    Feb 2006
    Palm Beach Gardens, FL
    31
    3,718
    looks great, good job...my next project, still may use glue though.
    agp's Avatar
    agp
    agp is offline Cadillac Owners Connoisseur
    Automobile(s): Ex-CTS owner
    Mar 2009
    SE Michigan
    1,229
    This is great, I'll be ordering some real suede in the near future and doing this project. The leftovers can be used to make straps for my watches.
    One question though - since you're not using the glue, if you rub on the suede, wouldn't it come off the door easily?
    May 2010
    Midwest PA
    29
    28
    Quote Originally Posted by agp View Post
    Its in there pretty tight. I havent had any problems with it coming out yet
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    looks good, but my friend did the same thing but on his accord, and i hate to tell you but it was peeling within 6 months, and he glued his.
    agp's Avatar
    agp
    Mar 2009
    SE Michigan
    1,229
    I'm sure some packing tape rolled into a circle won't hurt, if you one day want the original inserts again.
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    i had this done on my CTS a while ago...definitely an upgraded look...good write up
    FYI...there was this same write up over in the V section from about two or three years ago
    D-RoKK is offline Cadillac Owners Fanatic
    Nov 2012
    320
    Bringing this back to life... haha
    But.. if anyone has done this, how is it holding up? Im looking to begin the process of reupholstering and this looks awesome!
    Thanks
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    I haven't looked closely at the door in my car, but if the whole door skin was removed, is it possible to get that piece out to cover it?
    Nov 2012
    320
    I started to suede it today, couldnt wait. The door piece in which gets covered looks like it is part of that hard foam and doesnt look removable.
    My advice, cut about 1/2" extra around (you can always stuff it in), unplug your lock regulator (you will know what im talking about when you do it), and be very careful taking off the handle bezels. To get the suede in there tight, I put a sharp flat head screwdriver on it perpendicular to the cut and as I pushed I turned the screwdriver to pull it tight and mush it all in there.
  16. #14
    Nov 2012
    320
    Done! Thinking of adding a soft white glow wire as piping around the pannel sort of like a courtesy light like on the new cts v's.
  17. #15
    sandalet's Avatar
    sandalet is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-2003, 3.2 automatic
    Nov 2011
    Chechnya, Grozny-City
    39
    618
    You spoiled plastic idyll Cadillac)))
  18. Remove Advertisements
