Remove steering wheel trim covers to get to ignition switch?
Results 1 to 9 of 9
Like Tree1Likes
  • 2 Post By GR-CTS
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Remove steering wheel trim covers to get to ignition switch? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I'm struggling with getting the upper and lower trim covers off from around the steering wheel. The right side by ...
    GR-CTS is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac CTS
    May 2008
    21
    I'm struggling with getting the upper and lower trim covers off from around the steering wheel. The right side by the key doesn't seem to want to separate as easily as the snapped other sides. Does anyone have some help to offer? I'm trying to get at replacing the ignition switch. Thanks.
    May 2008
    21
    Re: Remove steering wheel trim covers to get to ignition switch?
    I figured it out. There's an access hole under the key switch. When you stick a stiff point through that hole you can pull the key cylinder out and then remove the lower trim cover. You need the inverted torx wrenches in order to remove the ignition switch. On a side note, I swapped the ignition switch but that didn't do it. I have that common problem of key stuck, certain lights on, certain lights off, etc. I'm moving on now to the ECM.
    rgvcts and rgvcts like this.
    arturogm13's Avatar
    arturogm13 is offline Cadillac Owners Member
    Automobile(s): Silver Cadillac cts 2003
    Jul 2010
    Houston, Texas, United States,
    26
    69
    You did the right thing, now you gotta go to the dealership so they can program the key to the new switch.. They told me 400 dollars
    ham4864 is offline Cadillac Owners Fanatic
    Feb 2012
    41
    286
    thats not true.you don't program the key to the switch,you program it to the transponder thing,you can program the key yourself.just google it.
    These programming procedures are only good for USA built vehicles.
    The first digit of your 17 digit VIN number must start with the number 1 or 4.
    If your VIN number starts with a 2 or 3 or a letter these procedures WILL NOT WORK.
    1. Insert an existing programmed working key into the ignition cylinder.
    2. Turn ignition to the ON position for 5 seconds, then back to OFF position.
    3. Remove the existing key and within 5 seconds insert new key and turn
    it to the ON position for 5 seconds.
    4. Turn key OFF then back to ON. The key is now programmed.
    Start vehicle to test key.
    kilrcady is offline Cadillac Owners Member
    Automobile(s): 2007 srx 1977 coupe deville
    Jan 2011
    22
    strange I tried to sticK SOMETHING IN THERE AND IT DID NOTHING
    Jan 2011
    22
    sorry cap lock stuck
    I still cant get my ing cylinder out
    Jan 2011
    22
    anyone?anyone? I cant figure this thing out
    hbelton is offline Cadillac Owners Member
    Jan 2014
    1
    I have the issue with the wiper switch and need to remove the column covers to replace it but can't get the covers off without removing the key cylinder
    tegampure is offline Cadillac Owners Member
    Automobile(s): CTS
    Jan 2016
    Hello,
    Kindly let me know which access hole as I can see 4 holes there (please see the picture attached and kindly identify the access hole you are referring to). key.pdfkey.jpg
  12. Remove Advertisements
