Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: 2003 3.2L - radiator hose that leads to reservoir
    Coke_O is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS 3.2L V6
    Jun 2009
    Houston, TX
    275
    Hey guys, I was attempting to replace my tensioner pulley and accidently broke some part on my radiator. Its the brass connector that connects the top of the radiator to a hose that leads to the reservoir. Do any of you know if this is something that i can just remove w/ an extractor and replace? Or, do i need a whole new radiator? I've attached some photos.
    Jun 2009
    Houston, TX
    275
    Re: 2003 3.2L - radiator hose that leads to reservoir
    Anyone?
    Jun 2009
    Houston, TX
    275
    what about removing the whole top piece off? does it come off?
  5. #4
    Jun 2005
    465
    I checked a few '03 CTS radiator schematics and it seems that the broken part is not available separately. Sorry, I know it's not what you wanted to hear...
  6. #5
    WickedGoat's Avatar
    WickedGoat is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS 3.2/2004 GTO/2004 GMC Yukon
    Mar 2009
    Columbus, NJ
    42
    324
    Rippy can probably confirm that, but I think CT Essense is right.... you are probably on the hook for a new rad. Shit happens but look at it this way... Now you can avoid the whole "transmission cooling line popping off the radiator because the fitting broke" debacle and save yourself a potential headache
  7. #6
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    wicked ghost is right...the cooler line always blows off and this is a opportunity to fix it before it breaks.. i forget the price of the rad but its 250 or 350 i think..check with rippy, but then you still need your tranny lines attached and i dont know how to do that, i had the dealer attach the lines.
    other option if you really want to save that rad is drill it out, tap it with threads and have a fitting made you can screw in there then attach that line back on... i think that is just the overflow return hose or something like that.
    i think you are better off changing out the rad tho.
  8. #7
    Jun 2005
    465
    ...Or you can take it to a Radiator Shop and have them repair the nipple. Prolly an easy, fast, cost effective fix.
  9. #8
    Jun 2009
    Houston, TX
    275
    Thanks for all of the replies guys. I am going with a new one. a couple of other connections broke as I was trying to remove the hoses. They pretty much broke into pieces as i was trying to remove the hoses. I think it was going to mess up soon anyway so it was probably best that it happened this way rather than leaving me stranded somewhere.
    @ghettomike Is attaching the transmission cooling lines not something i can do myself?
  10. #9
    Jun 2009
    Houston, TX
    275
    Quote Originally Posted by CT ESSENCE View Post
    it would have been nice to do this but i ended up breaking it more.
  11. #10
    Jun 2009
    Houston, TX
    275
    @WickedGoat is this something i can do myself?
  12. #11
    Jun 2005
    465
    This happened to me as I was installing the Throttle Body after cleaning.
    The repair job is not hard at all. You have to reem out the broken piece that was left on the tank. I used a drill bit about the same size diameter as the plastic nipple. I slowly turned the drill bit with a pair of pliers, applying a little force. The area where the nipple attaches to the tank is plastic, so it doesn't take long to reem out.
    BTW, take the remaining nipple piece out of the hose,..and dont lose it. You'll need it to insert it back into the tank after youn reem the broken piece out. The new hole has to be a little larger in diameter than the nipple for insertion. Insert it to the tank about 1/4" and use JB Weld to bond the nipple in place. Dab the outside of the nipple with a little JB Weld to bond within the hole and then around the nipple where it attaches to the hole. Let it cure well. Reattach the coolant hose, start the car and make sure it doesn"t leak.
    I hope this works for you as well as it worked for me.
  13. #12
    Jun 2009
    Houston, TX
    275
    BTW, take the remaining nipple piece out of the hose,..and dont lose it. You'll need it to insert it back into the tank after youn reem the broken piece out. The new hole has to be a little larger in diameter than the nipple for insertion. iInsert about 1/4 inck and use JB Weld to bond the nipple in place. Dab the outside of the nipple with a little JB Weld to bond within the hole and then around the nipple where it attaches to the hole. Let it cure well.
    I hope this works for you as it worked for me.
    Thanks for the info. I ended up breaking it more as i tried removing it to take it to get fixed. I can't beleive I didn't event think about doing what you did. Let me know how it holds up.
  14. #13
    Jun 2005
    465
    Sorry to hear that. Wish I would've thought about it sooner when it first happened to you.
    I can't believe the damn think is made of plastic, including the upper tank. Anyway, Good luck with yours.
  15. #14
    ghettomike's Avatar
    Apr 2008
    off the grid.
    33
    7,872
    Quote Originally Posted by Coke_O View Post
    i didnt attach mine for a couple reasons, i needed to have my tranny filled and i was getting a pan and filter service done on it, also there is a tool that is needed to attach the line and i didnt have it. i had it towed to the dealer for it.
  16. #15
    Jun 2009
    Houston, TX
    275
    Quote Originally Posted by ghettomike View Post
    Did it cost you much to get the lines connected?
  • You may not post replies
