trans cooler failure issue break down. all true gear heads report in.
Page 1 of 10 12345678910 LastLast
Results 1 to 15 of 144
Like Tree7Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, trans cooler failure issue break down. all true gear heads report in. in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I don't know about you, but it seems where as timing chains were chapter 1, trans-cooler failure is becoming chapter ...
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    974
    Exclamationtrans cooler failure issue break down. all true gear heads report in.
    I don't know about you, but it seems where as timing chains were chapter 1, trans-cooler failure is becoming chapter 2.
    I would like to get the minds together to figure out this problem, what it is, it's cause and come up with an official fix. I've seen several threads here and there regarding this. If anyone has any pictures, diagrams drawings etc please post them.
    Also if your aware of any upgraded parts, radiators hoses please also post them. In my recent tear down I had to remove the radiator which gave me a good look at the connector. I can definitely see why this is a failure point. Basically a cheap aluminum pressure fitting which connects to the trans cooler which is free floating in the bottom of the radiator. I'll post a diagram later.
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    Re: trans cooler failure issue break down. all true gear heads report in.
    briggy...the trans cooler is actually #1 and has happened a lot more often than what you just see on here. but anyways, the radiator's and fittings are crap like you mentioned in your post, no matter if you change hoses, double clamp or go after market. it is all crap. I have been that this road a time or too. what finally got my car right, was adding an external cooler and just bypassing tha radiator. now granted, this isnt for everybody, because i know some of you live in cold weather states and use your cars in the winter. but it is an option...
    briggy's Avatar
    Dec 2009
    Southern California
    41
    974
    Quote Originally Posted by txbest1980 View Post
    you have any pictures ? which after market cooler did you use. I'm also guessing you got a new radiator or found a way to plug the oem one. I think I remember reading somewhere that the new oem radiator has a different fitting. yes no ?
    txbest1980's Avatar
    Dec 2008
    36
    6,414
    chevyhighperformance and I both did this a little while ago. i dont have any pictures with me, but i just got your basic cooler from AutoZone and installed it. very quick and simple job...as for the new radiator, i am told that they do have new fittings that will not match I know my car. if i was to put this new style on my car, then I was going to have to run all new hoses according to my mechanic and the parts guy (but I havent personally seen the fitting and all that to verify for myself)
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    the design is junk, i replaced mine with new OEM lines and aftermarket OEM replacement rad.
    do i trust it? i guess to a extent but if i were to re-do it i would get a aftermarket external cooler, probably a small one, have the OEM hose fitting cut off, aftermarket fitting to go into the new cooler with deeper threads, use thread lock, and have a extra long tube on the other end of the fitting with 2 flanges or maybe even 3 so you can put clamps between them in 2 sections. better than just 2 clamps behind 1 flange.
    you can buy or rent a flange tool and getting a fitting that description may take a little effort but it shouldn't be impossible.
    tool rentals like the flange tool are free in canada. you only need 1cm between the flanges so you are looking to find one that is 2-4cm long.
    WickedGoat's Avatar
    WickedGoat is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS 3.2/2004 GTO/2004 GMC Yukon
    Mar 2009
    Columbus, NJ
    42
    324
    Briggy, I think I read somewhere on here that the replacement radiator has different fittings on it compared to stock. I've never experienced this problem but have read the threads and saw the posted pictures of lines that have popped off the radiator and tranny fluid puked everywhere. It is a stupid design and for some odd reason, the root cause appears to be the factory fittings on the radiator like to rust out, causing the fiting to break off from the rad. It seems that most failures have happened when someone was driving the car and smoke started pouring from the hood and the car starts to rev but go nowhere. I think it is a combination of the fitting rusting and the vibration of the cooler inside the radiator that causes the fittings to break off. The lines attach to the fittings like a fuel line.... a quick connect. Unfortunately, if you don't pull the car off the road almost immediately, the tranny could suck coolant into it and ruin that in the process. So this failure has the potential to cost a fortune and it to me feels like it is one that just should not happen. Of course most dealer service shops will act like they have never heard of it happening while handing you a $3000 repair bill.
    As far as a fix, I'd like to see a radiator with a typical trans cooler setup with flared style line fittings that screw into the radiator. Whatever the fix, it has to be something that will not rust out, break off, and cost a shit ton of money because the tranny is now farked.
    1of5 is offline Cadillac Owners Member
    Automobile(s): '07 CTS Sport; Blk Rvn; FE5/P40 handling pkg.
    Aug 2010
    Way, way East USA
    99
    #1 My biggest fear .
    #2 the freaking timing chain .
    Any way to check if the connection is deteriorating and take defensive action ?
    Replace connections ?
    Or is it just like being sucker punched; you never know when it will happen ??
    ghettomike's Avatar
    Apr 2008
    off the grid.
    33
    7,872
    1of5
    kinda both...
    check the fittings that attach to the rad, both are known to break, there is a fluid in and a fluid out hose.
    when mine blew i had actually just read someone elses thread within a week or so prior.
    i was on the highway, hit the gas, no power, tapped it again saw the rpm go up but was like neutral.
    slapped it out of gear hit the 4 ways and pulled over.
    towed it home.
    i had a big repair bill but not as big as some , but i went all out to have it done properly.
    i pulled it all apart at home changed the rad and cleaned it up, there is a crap load of things in the way on the 3.2
    towed it to the dealer using my free CAA, they dropped the pan, changed the filter, gasket and lines.
    also the tech filled and flushed it a couple times to make sure all the fluid has been in and out so there was as little old fluid in there as possible, if any.
    i think with towing it cost me 1100 or so, i have a thread on how it went with the actual costs in it for the parts and i think some part numbers too.
    WickedGoat's Avatar
    Mar 2009
    Columbus, NJ
    42
    324
    Quote Originally Posted by 1of5 View Post
    All you can do is pull down the plastic belly pan that covers the bottom of the rad and then take a look at the fittings. If the radiator connections are rusting then you may have to say a prayer or 2. You can lightly grab the connection and shake a little and make sure it feels secure. The only real preventative thing to do would be to replace the radiator now before it potentially happens. You could also replace the trans cooler lines. I think I have read on here where people have suggested painting the fittings to further prevent rust?? Could be worth a shot I guess.
    erdoc48 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 SRX Performance FWD, Platinum Ice
    Dec 2005
    Westampton, NJ
    218
    This is interesting (and scary)- is there any way to visually check the fittings from above (without taking the belly pan off)? Also, is the radiator the same in the older cars with the 3.2L engine vs. the newer ones with the 3.6L? Has anyone with a 3.6L motor had this problem?
    rb0757 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2006
    74
    I ended up putting a external cooler on, it was easy and it will save the transission, as we all know the heat is the number one killer of transmission, it breaks down the fluid and it's all down hill from there, I'm thinking of putting a external engine oil cooler next
    BadAV is offline Cadillac Owners Fanatic
    Automobile(s): NONE - was 2006 CTS. Now 2012 4LT Centennial GS Corvette
    Jun 2009
    St. Louis, MO
    386
    If you choose to do away with the internal tranny oil cooler and go with an auxiliary external unit I would suggest you go with either a Tru-Cool unit or a B&M Supercooler. Both of these units are stacked-plate design and therefore very strong. You should get the unit that has the bypass valve in it that keeps the tranny fluid from running through the cooler until the fluid warms up. This will assure the fluid gets to a proper operating temperature first; the fluid can also remain too cold and that's bad for the transmission also. I've got a 24k btu Tru-Cool unit on my Avalanche, plumbed in after the radiator cooler, then returning back to the transmission.
    ghettomike's Avatar
    Apr 2008
    off the grid.
    33
    7,872
    Quote Originally Posted by erdoc48 View Post
    different rads, but same problem.
    the 3.2 has more coolant hoses that attach here and there for whatever reason, but the tranny lines are the same and so are the fittings.
  16. #14
    briggy's Avatar
    Dec 2009
    Southern California
    41
    974
    Quote Originally Posted by BadAV View Post
    good information. I'm curious how you guy patch up the radiator after removing the cooler lines. Just plug i with the appropriate sized bolt ? When I pulled mine I did a full inspection and it looked fine. I maybe mistaken but I thought the connectors were aluminum, which shouldn't rest. I'll take some pictures of mine after thanks giving i still have to reinstall the lower engine cover.
  17. #15
    ghettomike's Avatar
    Apr 2008
    off the grid.
    33
    7,872
    I would just use the old fitting off the rad and pack it with jb weld
  18. Remove Advertisements
