Questions about O2 sensor codes P0160 & P0161 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Questions about O2 sensor codes P0160 & P0161 in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Replacing the ECM didn't work. The codes came right back. Also, the car did need the anti-theft relearn after swapping ...
  1. #16
    vwguy is offline Cadillac Owners Member
    Aug 2010
    39
    10
    Re: Questions about O2 sensor codes P0160 & P0161
    Also, the car did need the anti-theft relearn after swapping out the ECM. Also the crank angle sensor does need to be replaced as the car shut down while my mom was driving it yesterday. Luckily it was close to home and the insurance company towed it for free.
  2. #17
    akeinc is offline Cadillac Owners Member
    Automobile(s): CTS
    Mar 2007
    Phh-O-Nee-X
    35
    Quote Originally Posted by vwguy View Post
    Man that's a bummer. Well at least you got a backup ecm ready to plug and play. Did ya check for an open heater circuit at the O2 sensor itself (both white wires)?
    My B2S2 heater broke on at least two other sensors - I don't know why but I'm guessing it may have had something to do with jump starting the car (we do that a lot here in the desert) which may also have broken my ECM.
  3. #18
    thoed.essay is offline Cadillac Owners Member
    Automobile(s): 03 Diamond White CTS Lux/Sports PKG
    Jul 2010
    West TX
    69
    haha sounds like we have the exact same car cuz i have these problems as well
    i dont remember if those were my codes but i know it had to do with the same o2 sensors because the other day i had a diagnostic test ran it said bank 2 sensor 1 & 2 were bad , catalytic converter bank 2 bad it showed nothing wrong with the crank shaft position sensor but he told me to try and change that to see if that was the problem with my car having trouble starting and turning off. i asked my mechanic who i always take my car to about the problems with my car starting he said more then likely it was my ignition switch and not the crank sensor but thats because my car turns off while im driving unless yours does the same i would try the crank sensor first and see how it does after that.
  5. #19
    Jul 2010
    West TX
    69
    just read your car turned off while your mother was driving
    if its your ignition switch try wiggling it after you turn on the car
    if your cts is like mine it has a mind of its on and sometimes moving the ignition switch will cause it to turn off and other times it wont
  6. #20
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    vwguy...that is interesting that the ECM didnt fix the proble. i wonder if you have the same problem chevyhighperformance had. he had the same codes and i believe he had two wires that ended up shorting out, and he replaced his wiring harness. and if i am correct, that cost him like $134, but i may be wrong. hopefully he logs in and reads this thread
  7. #21
    jbf28 is offline Cadillac Owners Member
    Automobile(s): 2003 cts sport
    Nov 2008
    north jersey
    51
    im having this same problem replacd ecm and codes still there, so did you ever fix this problem and if so how
  8. #22
    jermainmarley is offline Cadillac Owners Member
    Automobile(s): 2003 cadillac cts sport luxury
    Apr 2013
    I'm getting the same codes the car is misfiring like crazy in all 6 cylinders and now I'm losing reverse sometimes the transmission is not giving any codes and reading as working properly could the ecm cause the loss or reverse or if i replace the oxygen sensors will that do the trick? PLEASE HELP ASAP
  9. #23
    temo93 is offline Cadillac Owners Member
    Automobile(s): cts
    Jun 2013
    23
    1
    hey i have the same problem on my car ..but is there any way i can buy the ECM flashed to my vin?
  10. #24
    Aug 2010
    39
    10
    Sorry that I never came back with any answers. My mom ended up selling the car shortly after it started stalling out.
    I really want to say that it had something to do with the engine harness. The valve cover gasket was leaking oil all into the harness loom all the way down to the O2 sensors. All of the wiring was saturated with oil. I really didn't feel like wrestling with the harness and she was done with all of the little issues that the car had given her so it was sold.
    Wish I could have been more helpful. I really hate those common codes that don't have a definite fix. Good luck to all that have it.
  11. #25
    Beatdown Z is offline Cadillac Owners Member
    Automobile(s): 03 CTS
    Mar 2013
    3
    I had the p0160/p0161 codes and the ECM did NOT fix the problem. I wound up running new wires from the PCM to the sensor and now all is well.
  12. #26
    RickyBobby is offline Cadillac Owners Member
    Automobile(s): CTS 2003
    Oct 2011
    1
    I've got the 0160/0161 after changing out all the O2 sensors so I was wondering what the rewire process was like. I've got the oil problem too. I'll be cleaning that up also.
  13. #27
    jmullan99 is offline Cadillac Owners Member
    Mar 2015
    Ontario, Canada
    25
    For those that have checked, could somebody tell me what wires/pins are used, at the ECM, to measure when checking O2 sensor B2S2 voltage/resistance?
  14. #28
    Elemtz96 is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac CTS 3.6L
    Nov 2014
    21
    31
    Where did you get the ecm and where did you get it flashed to your vin. Also I just replaced the engine and tranny. The tranny and engine came of different vehicles. which vin do I have my ecm flashed to
  15. #29
    dentjd is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac CTS 3.2L
    Jun 2015
    Dallas/Ft. Worth, TX
    28
    I am having the same problem. I changed the o2 sensor and that did not fix the codes. I suspect my wiring harness is bad for the bank 2 sensor 2. Can someone please tell me what the proper readings are supposed to be for shooting the wires? Thank you in advance!
  16. Remove Advertisements
