Transmission Fluid Change - Page 8
Page 8 of 8 FirstFirst 12345678
Results 106 to 119 of 119
Like Tree12Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Transmission Fluid Change in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; same happen to me in the highway! ---------- Originally Posted by CTS-QC Same thing just happened to me last weekend. ...
  1. #106
    kaitagun's Avatar
    kaitagun is online now Cadillac Owners Fanatic
    Automobile(s): cts4 2008 DI, cts 2005 3.6(totaled)
    Jun 2012
    canada montreal
    27
    182
    Re: Transmission Fluid Change
    Quote Originally Posted by CTS-QC View Post
    Same thing just happened to me last weekend. Happened at home in the driveway and I spotted it at the gas station a mile from home. I was lucky to have made it to a nearby repair shop just in time. Really lucky it didn't happen on the highway. I did some research on this site and found that it is a common problem. No warning, nothing catastrophic like accidentally running over something to cause this, it just happened. Must be yet another design flaw, and a serious one at that. I have roughly 87k miles on it.
    same thing happened me months! I saw some outside and i stopped the car and i saw a red oil
  2. #107
    erekv2 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS 3.6
    Jan 2010
    41
    10
    Ok, this is one of those on going threads that never dies...Thank God...So I did my change with an estimated 5 quartz, but I may have to add a little more just because I don't think I got the 5 full quartz in there. However, I have a problem now with my Tranny...130Miles on the car, 1st gear is not shift smoothly like before and my engine light is on. Has anyone with High Miles experienced any of these symptoms after they change there Trans Oil?
  3. #108
    holsgo is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts
    Apr 2011
    143
    I doubt it's fluid related. My guess would be a sensor, possibly a shift sensor. But, I'm out of my league until you tell us the codes it's throwing.
  5. #109
    concorso is offline Cadillac Owners Master
    Dec 2007
    5,630
    Quote Originally Posted by erekv2 View Post
    Did you reset the TCM?
  6. #110
    aviatordave is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS, 1976 Seville (sold)
    Apr 2013
    San Antonio
    68
    143
    Quote Originally Posted by s_tharsan View Post
    Just take your vin number to the parts counter at GM and ask for transmission fluid, pan gasket and filter.
    seems like the most sensible and the quickest way. of course, it may cost you a few extra bucks - but you're getting OE parts... always worth it to me.
  7. #111
    cmerrell is offline Cadillac Owners Member
    Apr 2014
    1
    Right now my automatic 2004 3.6L is having gearing trouble. I know cars but this is my first Cadillac. I'm understanding that there is no transmission dipstick on this vehicle...if I'm wrong please help! The main problem is when I go into any gear (r) or (d) and hit the gas the car does not accelerate, it revs, and Rpms jump....I need some advice? Thank you
    Sent from AutoGuide.com Free App
  8. #112
    HawkzillaCTS is offline Cadillac Owners Member
    Automobile(s): 2006 CTS 3.6L
    Oct 2013
    Iowa
    60
    When I bought my 06 back in August, it had some rough shifts on occasion. So I loosened the tranny drain on the bottom of the pan, just enough to let an ounce of fluid out. It was BLACK, but didn't smell burnt. Obviously needed new fluid ASAP. So first step for newbs would be to very slowly loosen your pan drain bolt until the fluids starts to drip out and catch it in a small white plastic cup. this way you can inspect the condition of the fluid. If it has never been replaced it will be dark brown to black, but the key is if it smells burnt. If it does you may be in for some bad news. if you're not sure, take it to a local tranny shop and let them smell it.
    Okay then I ordered my own replacement filter kit (I prefer to buy my own parts when possible) and called up my Caddy service center and had them drain the pan and drop it. NOW THIS IS KEY: Very clearly instruct them NOT to empty or clean the pan once they have it off. You want to be able to inspect it. If it has noticeable shards of metal floating in it or the magnet look like a metal porcupine, your tranny has been grinding and do NOT have anyone flush it, just replace the filter and put the pan back on and have them top it off (4-5 quarts). Then just drive it normal and perhaps have the pan drop procedure done again every year or so (it's only around $50) to get the remainder of the metal out. The reason is, if you have evidence that your tranny has been grinding then you don't want to flush it as forcing fluid through can easily force metal shards into places that you don't want them to go and it can kill your tranny in a hurry.
    Now, if you have your pan dropped and you don't see any metal shards or debris, you're in luck. Have them put in the new filter kit and replace the pan and top it off. The only thing now is you're CTS holds like 9-12 qts of ATF (this seems to be different depending on whom you ask), and replacing the pan only cleans up 35% of it. So what i did was I took it down to Amco Transmission and had them replace the rest. I did this because I my research revealed that having a transmission only shop do a replacement fluid procedure is the safest bet. They didn't have to drop the pan so what they did was run the car and pop a hose off and let the natural flow of the fluid pull the new ATF until the old stuff coming out was bright red... booyah, your ATF is completely new, without being forced. This part cost me $100.
    So in the end I paid $150 + the cost of a filter kit ($40 I believe I paid). $190 was a small price to pay to know it was done right, see the old pan myself, and know the fluid was fully replaced. My CTS shifts like a new car now and should be good to go for another 50K before I have the same procedure done again.
    My only regret is I didn;t have them put Dex6 in there. I don't trust that anyone will use the higher end stuff when you pay for it or provide it, so I might end up buying a 12 pack of Dex6 and finding a tranny place that allows you to watch while it's done. Dex6 sounds like the Mobil1 of the ATF world.
    You can do it yourself but know if you just drain the pan and drop it and replace the filter, you will only be replacing 35% of the fluid, not to mention you are dinking around with the second most expensive part of your vehicle. For me it was a no brainer to invest a couple hundy to make sure my tranny was protected properly.
    Just my experience, hope it helps.
  9. #113
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    684
    I hope it is just low on tranny fluid for you. I would check the tran cooler lines from the rad for any leaking first then check the tranny fluid, No dipstick sorry.
  10. #114
    FixCTS is offline Cadillac Owners Member
    Nov 2014
    32
    12
    So did you ever find the supply line or which one it was? I want to do the very same exact thing but not want to have a considerable amount of prior transmission fluid. I also have to repair the lines today as well due to crumby work that was done on the vehicle previous to purchase.
  11. #115
    seDan is offline Cadillac Owners Member
    Aug 2013
    56
    41
    I have the 2006 CTS 3.6 on the ramps up front and the stands in back. It's draining out overnight largely because I'd rather have a drink now. I freaked out about the gasket I'd purchased having 22 holes instead of 20 but I've seen that on pictures here so....
    Edit: the fill hole plug was installed by a trained gorilla on steroids. Someone here warned about stripping the T45 hole and mine sure wanted to so I dropped the exhaust and beat the driver into the hole with a ball peen hammer and then put a flex on it and prayed. I think the car knew I'd weld a bolt to it if I had to and it came free.
    To reinstall the plug I used this assembly:
    It allows you to run the extension above the exhaust, through the box end wrench and into the plug. Then you can push on the end of the extension and tighten the plug to somewhere between 15 ft/lbs and the original factory setting of "gorilla wants a banana...twist...."
    With 118,000 miles and the original transmission fluid, I was happy that the pan was clean and the magnet had a light coating of extremely fine material - like clay, really - present and though dark the fluid didn't smell that bad.
    I must say it was worth the effort. The transmission had become noisy...whirring sounds...sloppy shifts. Though it in no way matches the joy of hammering the pedal of my wife's 2013 CTS coupe, the seDan has returned to a competent and firm shifting unit that is vastly quieter.
  12. #116
    SuperDaveSTS's Avatar
    SuperDaveSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS Sport 3.6
    Sep 2014
    Antioch, IL
    35
    246
    When i removed my fill plug i replaced it with a standard plug to make the next service a breeze.
    Argent likes this.
  13. #117
    Marksgoddess's Avatar
    Marksgoddess is offline Cadillac Owners Member
    Mar 2016
    22
    Excellent post. Really appreciate the time. Will be doing this soon. Having slight hard shifting hopefully this helps it.
  14. #118
    Mar 2016
    22
    Just had some service done. Complete fluid and filter change engine and transmission. Did not improve the hard shift. I guess it is on to sensors?
    Sent from my SM-G930P using Tapatalk
  15. #119
    Mandrake's Avatar
    Mandrake is offline Cadillac Owners Fanatic
    Automobile(s): 04 CTS 91 Aristo
    Jun 2016
    MN
    32
    423
    I'm not sure which sensors you would be referring to but you should probably make a new thread.
    Marksgoddess likes this.
  16. Remove Advertisements
