Transmission Fluid Change - Page 3
Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 31 to 45 of 116
Like Tree11Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Transmission Fluid Change in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Originally Posted by Gaetano04 lol if you managed to do the tranny the diff shouldd bee a breeze for you ...
  1. #31
    s_tharsan's Avatar
    s_tharsan is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS Sport
    Aug 2009
    Toronto, ON
    29
    260
    Re: Transmission Fluid Change
    Quote Originally Posted by Gaetano04 View Post
    lol if you managed to do the tranny the diff shouldd bee a breeze for you buddy
    yea for sure, I'm curious to see if I would notice a huge difference in performance like I did when I did the tranny fluid change.
  2. #32
    smoke20 is offline Cadillac Owners Member
    Feb 2010
    Illinois
    34
    88
    Just did my diff a few weeks ago. Dont really notice a difference but it is super easy to do. The bolt will be on there pretty snug
  3. #33
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    lets see some pics of the diff change
  5. #34
    s_tharsan's Avatar
    Aug 2009
    Toronto, ON
    29
    260
    No prob, pics will be up. If there's any advise on the fluid change I'd appreciate it. I believe slip additive is required if I remember right. I'll be placing the whole order with my buddy at the GM dealership and I guess he'll know what is required.
    What I'm also curious about is why differential needs slip additive but transmission doesn't? or does it?
  6. #35
    Gaetano04's Avatar
    Gaetano04 is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 cts sport
    Mar 2009
    GTA, Canada
    30
    856
    you only need a slip additive for you diff if you have the limited slip differential.. no additive is needed for the tranny, though you could put some if youd like
  7. #36
    s_tharsan's Avatar
    Aug 2009
    Toronto, ON
    29
    260
    How would I know if I have a limited slip differential? thanks
  8. #37
    Gaetano04's Avatar
    Mar 2009
    GTA, Canada
    30
    856
    depends on the model you have... check your spare tire cover build code.. it should be G80 i beileve for the LSD
  9. #38
    s_tharsan's Avatar
    Aug 2009
    Toronto, ON
    29
    260
    Thanks, I'll check that. if not the parts department at GM should know if I give them my VIN number.
  10. #39
    s_tharsan's Avatar
    Aug 2009
    Toronto, ON
    29
    260
    Hey guys, I'm gonna do the differential fluid change right now but I can't find how tight to tighten the drain and fill plugs using torque wrench specs. If someone can tell me the accurate amount in ft lb, I'd really appreciate it!!! thanks!!!
  11. #40
    GTA CTS's Avatar
    GTA CTS is offline Cadillac Owners Member
    Automobile(s): CTS
    May 2010
    N/A
    45
    Quote Originally Posted by s_tharsan View Post
    Tighten the fill/drain plug to 39 N·m (29 lb ft).
  12. #41
    s_tharsan's Avatar
    Aug 2009
    Toronto, ON
    29
    260
    Quote Originally Posted by GTA CTS View Post
    Wow thats a lot compared to the 15 ft lb for the transmission fill/drain bolts. Thanks.
  13. #42
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    ive never used a torque spec on a diff check plug, usually just put it snug then 1/4-half turn and a spot of primer spray paint to seal it....stops it from spinning and make it more visible for any leaks.
    so was there a drain plug and a fill plug on the cts diff? how did you get the old fluid out, i want to do mine, se use to use a vacuum tube to get it out but i dont have that equipment anymore...it was at the lube shop i worked at.
  14. #43
    s_tharsan's Avatar
    Aug 2009
    Toronto, ON
    29
    260
    Quote Originally Posted by ghettomike View Post
    Sorry I didn't end you changing the fluid today because I was having difficultly with my jack. I will be doing it sometime this week but I'll post a DIY as soon as I finish.
  15. #44
    Gaetano04's Avatar
    Mar 2009
    GTA, Canada
    30
    856
    mike whenever you wanna do it let me know lol but not thiss weekend im working days today and toorrow and gotta work mississauaga tonight
  16. #45
    ghettomike's Avatar
    Apr 2008
    off the grid.
    33
    7,872
    Ya in a couple weeks,workin right now and have a birthday up north next weekend to go 2. Still waitin on that job, but I've been told I'm gettin interviewed..they picked 9 out of over 65 applicants, and then cancelled 2 when they talked to them on the phone to book a interview, they must have been really dumb to mess up a phone call just to book a appointment...so its me vs 6 others,but I have a bad feeling they already picked some girl just haven't announced it,but I dunno if she even applied, otherwise she's gotta get the f outa my new office!! Lol.
  17. Remove Advertisements
