is everybody running a 38mm offset on 20" rims?
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Like Tree3Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, is everybody running a 38mm offset on 20" rims? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; hey just got my taxes back and and im buying rims this week ik the bolt pattern is 5x114.3 or ...
    CadillacKid12 is offline Cadillac Owners Connoisseur
    Automobile(s): '04 3.6L, Clear Fogs, 20" TV, Tints, Streeglow, V Bumper
    Oct 2008
    Goshen, CT
    2,501
    ik the bolt pattern is 5x114.3 or 5x115, really doesnt make a difference does it?
    but what i'm wondering do i have lead-way on the offset or should i stick with a firm 38mm some say you can go to 40mm all tho i dont think anybody has
    thanks guys
    mulescrote is offline Cadillac Owners Member
    Automobile(s): 03 CTS
    Oct 2009
    26
    Re: is everybody running a 38mm offset on 20" rims?
    I owe taxes this year, but would like to know the same thing
    Oct 2008
    Goshen, CT
    2,501
    seems most common, but i think the 2 bolt patterns dont matter
    since not alot of rim companies make a 114.3 the just go to 115
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    The .7 difference does make a difference. It will put strain on the wheel parts. Get them exactly for your size. Not for nearly close to your size. If you do decide to get them, get hubcentric rings.
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    we have 5 x 115 and it does matter a lot. like the above stated, the 5 x 114.3 can and will eventually snap your studs right off without hubcentric rings. as far as offset, it all depends on the size of the wheels you want. you can get away with pretty much anything in the +35 to +42 range
    Oct 2008
    Goshen, CT
    2,501
    they are 8.5 all around.. never understood the offset and how it works and dont know where to find a 20x10 rim for back and 20x8.5 for the front
    so TX ur saying get 114.3 if i can?
    Adam3882's Avatar
    Adam3882 is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Mar 2010
    35
    53
    "Offset is the distance from a wheel's mounting surface on the hub to the center-line of the wheel, in millimeters. Negative offset means the mounting surface is towards the inside of the wheel. With positive offset, this surface is biased towards the outside. Typically, wider tires require more positive offset to avoid contact on the inner fender well."
    I have 20in by 8.5 with a +40mm offset...i have no rubbing on the inner fender at all...but i did have to roll my fenders front and rear, mine is as low as it can go with that size rim and tire (245/35ZR20)
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    Quote Originally Posted by txbest1980 View Post
    Very true about studs breaking, but then again, op will have three other wheels to support vehicle. lol
    Real tire shops will refuse to work on your wheels/tires if they recognize that you have wrong wheels (vs bolt pattern).
    Oct 2008
    Goshen, CT
    2,501
    so then 5x115 is the way to go..... and my offest really should be with in 38-42mm
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    5x115 is the proper pattern, especially when getting into a 20" rim.
    I'm puttin hub rings on my 20s just have to pick them up, they ordered the wrong ones 2 weeks ago.
    I'm also running on 245/35/20 fit and ride perfect.
    Oct 2008
    Goshen, CT
    2,501
    thats wat size the tire comes with 245/35/20... mike are u running staggered or u 8.5 all the way around
    ghettomike's Avatar
    Apr 2008
    off the grid.
    33
    7,872
    Same all around...I didn't want staggard, don't want to mess with wheel speed sensors.
    txbest1980's Avatar
    Dec 2008
    36
    6,414
    caddykid...i would run 5 x 115 if i was you
  16. #14
    The Raven's Avatar
    The Raven is offline Cadillac Owners Enthusiast
    Apr 2010
    Fleetwood, PA
    36
    825
    There are alot more 5x114.3 wheels out there since that is and has been the Ford Mustang's bolt pattern. Only thing is that most of those wheels are musclecar-ish and not really flattering to a luxury sedan.
    I've been over this many times on other forums in the argument "is it safe" etc. Naturally you are taking a small risk no matter what, but i've had 5x120 wheels on my LPE WS6 (5x120.65 stud pattern) for 5 years now. I've had the car up to 150mph, and run her through at least 8 SCCA sanctioned events with ZERO problems of any kind. I check my lugs every three months just out of good habit, and have never encountered a loose lug.
    From an engineering standpoint, you are looking at a difference of less than 0.1mm per lug hole, and the deflection of aluminum at even 80lb/ft is more than 0.1mm. In english this means that your wheel lug holes will deform before the studs flex at all.
    So it's certainly not as "safe" as the correct bolt pattern, but modern bridges have been built with looser tolerances and you drive over them every day and don't question it.
    Ikera and ClassyCaddys like this.
  17. #15
    74chvy glasshouse is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.6 , 74 chevy caprice
    Jan 2012
    California, desert empire
    395
    22's fit or will they rub??
  18. Remove Advertisements
