2003 CTS 3.2 Serpentine Belt DIY
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Like Tree2Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2003 CTS 3.2 Serpentine Belt DIY in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; DIAGRAM To replace the serpentine belt on the 3.2 1. Reference the Diagram and locate the tension pulley ( top ...
    AmerLux's Avatar
    AmerLux is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS
    Mar 2007
    Athens, GA
    37
    1,059
    DIAGRAM
    1. Reference the Diagram and locate the tension pulley ( top most pulley on the passenger side, #4/the arrow A )
    2. A ratchet is preferable however I used a 15mm wrench on the bolt in the center of the pulley.
    3. Push like hell clockwise toward the driver’s side of the car to release tension and remove belt.
    4. Use caution! Don't get your fingers caught between the belt and pulley.
    5.. Like another member said if you’re doing the belt you may as well replace the tension pulley also. It was $8.00 and easy to replace.
    5.. Using a ratchet or wrench loosen the bolt in the center of the tension pulley ( left-y loos-e ) , remove the old pulley while keeping the hardware.
    6. Attach the new pulley using the hardware from the old ( right-y tight-e )
    7. Reference the Diagram before attaching new belt. Notice where the belt goes on the pulleys.
    8. Starting on the lowest pulley on the drives side attach the new belt.
    9. The belt goes on the top or bottom of all the pulleys except #8 and #7 notice the "S" orientation you'll use to attach the belt here.
    10. Leave the belt off #6 pulleys.
    11. Push like hell clockwise toward the driver’s side of the car to release tension and attach the belt to the last pulley (#6 )
    12. You’re finished. Congrats on saving hundreds of $$$
    Ikera and scooter05 like this.
    alconk is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Dec 2009
    49
    119
    Re: 2003 CTS 3.2 Serpentine Belt DIY
    AWESOME!!! Thankyou!!
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    amerlux did you copy that pic out of one of my threads or do you have the access to the GM database? lol
    temmons is offline Cadillac Owners Member
    Automobile(s): 2003 CTS
    Dec 2009
    12
    Does anyone know what hardware the tension pulley would have from the factory? I'm attempting to replace my pulley but when I put it on it becomes very tight and I'm wondering if there is suppose to be a "washer" of some kind.
    Thanks!
    Sammy Z's Avatar
    Sammy Z is offline Cadillac Owners Connoisseur
    Automobile(s): CTS 03
    Jan 2008
    Chicago, IL
    1,765
    I had a similar problem, I took it back to Autozone and explained it. They had a bearing from another vender and it worked fine. It seems these are common in GM engines.
    03cts86monte's Avatar
    03cts86monte is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS black on 20" Falken aviators, 1986 Monte Carlo.
    Dec 2009
    Chicago. IL
    27
    103
    i went ahead a change my belt and tensioner pulley, i went with all good year. goodyear gatorbelt, and goodyear pulley, there is a metal washer that bolts up to the pulley with the bolt. like i said i went with all goodyear, havnt heard a noise or havent had a problem since... im not so sure with the autozone crap. eventho i have 2 autozone mangers in my faimly, there parts are not the best. ACdelco all the way
    chico is offline Cadillac Owners Connoisseur
    Automobile(s): 03 Caddy CTS
    Dec 2006
    Toronto
    33
    1,028
    interesting...
    Dec 2009
    12
    I ended up having to go to Advanced Auto Parts and talk with one of their guys. They had the pulley but had two different brands that Auto Zone did not offer. In the end, we found that the hole in the middle of the pulley was slightly to big on both the auto zone item and one of the advanced parts. I ended up purchasing the one that fit perfectly with the factory hardware and had no problem getting it back on.
    vlbasten is offline Cadillac Owners Member
    Automobile(s): CTS
    Aug 2009
    53
    Quote Originally Posted by temmons View Post
    is factory hardware the name of the store where u got it? thanks
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    vlbasten...Advanced Auto Parts is where he bought his parts from...and he was saying that the stuff he bought fit perfectly with the OEM (factory hardware)
    Automobile(s): CTS
    Aug 2009
    53
    thanks tx...
    is this tension pulley the same as the ones for timing belt?
    Automobile(s): CTS
    Aug 2009
    53
    Hi, i found two different pulleys on advanceautoparts web, could you please which one fits? thanks a lot
    http://shop.advanceautoparts.com/web...S_285386501___
    http://shop.advanceautoparts.com/web...S_542620458___
    GT!'s Avatar
    GT!
    GT! is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 SRX AWD Platinum Ice/2010 CTS Sedan 3.6 AWD Silver
    Jun 2005
    Montreal
    53
    643
    I could have used this a couple of weeks ago, except I would have needed tips on how to do it on the side of the highway with no tools . Was able to limp to the nearest garage that changed it within an hour for $120, so I can't really complain.
    Cause of my failure (other than old age) was the bearing in the tensioner had seized, so definitely suggest you change that at the same time.
    -GT
  16. #14
    Automobile(s): CTS
    Aug 2009
    53
    Amerlux, in your step 3 "Push like hell clockwise" you mean to turn it right?
  17. #15
    WickedGoat's Avatar
    WickedGoat is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS 3.2/2004 GTO/2004 GMC Yukon
    Mar 2009
    Columbus, NJ
    42
    324
    Quote Originally Posted by vlbasten View Post
    Yes, as you are facing the car, put your socket or wrench on the tensioner bolt and turn it to the right, towards the driver side of the car. The tensioner will swing and relieve the belt so you can remove it.
  18. Remove Advertisements
