Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
 | Cadillac Forums: i think my ecm gone bad
11-18-09, 01:37 PM
| | Cadillac Owners Member Cadillac(s): cts 04,3.6L | | | | | i think my ecm gone bad hello everyone im new to this forum,please help.
i change battry on my cts,what i did was stupid  ,i got a battry with side poles and poles on top,cut off the poles on top,didn't put any kind of protection because i didn't know better,drove the car for weeks no problem.
1 day it stopped with me while driving,and a messge came up on the display starting disable remove key,when i checked under the hood i saw where it had a little burn under the hood,i changed it to the right baattry,the only way i get the car to start is turning on the key for 10 mins 3 times,but i notice the car sometimes shut off after been driven a while, oh and sometimes it reads on the display 0% engine oil,0% transmission oil,since this had happen,
can anyone help me?  |
11-18-09, 01:58 PM
| | Cadillac Owners Member Cadillac(s): cts 04,3.6L | | | | | Re: i think my ecm gone bad  apic of my caddi,hope to get it running soon |
11-18-09, 07:28 PM
|  | Cadillac Owners Connoisseur Cadillac(s): CTS 03 | | Join Date: Jan 2008 Location: Chicago, IL | | | Re: i think my ecm gone bad Do you have the correct battery in there now? I'd recommend the OEM battery or a battery that has 800 cca or more.
Try removing the cables for ten min and reconnect. Reset your oil indicator by holding it down for ten seconds. You may have to reprogram the auto up windows( down then up, hold the switch up for three extra seconds) |
11-19-09, 09:07 AM
| | Cadillac Owners Member Cadillac(s): cts 04,3.6L | | | | | Re: i think my ecm gone bad so the starting disable remove key,if i change the battry,it will allow me to start the car??? |
11-20-09, 09:35 AM
| | Cadillac Owners Member Cadillac(s): cts 04,3.6L | | | | | ewill 3rd anyone out there can help me? ewill3rd , |
11-20-09, 09:51 AM
| | Cadillac Owners Fanatic Cadillac(s): 2003 CTS | | | | | Re: i think my ecm gone bad Jemile, definately get a different battery in there if it's making burn marks. As to the turning off while driving, how fast are you driving when this occurs? If it turns off and you keep it in gear while driving on the highway, does it restart itself at all? Mine used to turn off for a split second only while on the highway, but would restart itself if I left it in gear, and the same message would appear. I didn't really look into it further because it seemed to have stopped... What year is your car? You may be able to find a trouble code or two in your car's computer without having to go to a dealer or autoparts store (let us know if you need help with getting the codes). Also, try typing in "starting disabled remove key" in the search box of this forum and see if you find anything, and keep us posted. |
11-20-09, 01:46 PM
| | Cadillac Owners Member Cadillac(s): cts 04,3.6L | | | | | Re: i think my ecm gone bad thank to those of you that replied, it didnt start back by itself ,when i try to start it back starting disable remove key appeared, and the theft dettrant light appeared on the dash also, i was told it was the ecm,so when i install it over the weeknd ill let you know,thanks again. |
11-20-09, 05:33 PM
| | Cadillac Owners Member Cadillac(s): cts 04,3.6L | | | | | Re: i think my ecm gone bad hi guys i changed the ecm and the car started right up fine,the proble is when it starts up it says driver one they blinks off to starting disable remove key,and the anti -theft light is just blinking,any one can help me???? |
11-20-09, 06:35 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: i think my ecm gone bad If the ECM is replaced it has to be programmed with the proper calibrations, also the VTD (theft) password must be learned between the ECM and the VTD module.
The Passkey module sends a coded password to the ECM for fuel continue. If the ECM is not programmed to recognize the coded password it will go into theft mode and shut the engine off.
You will just have to get the car to a dealer and have them to the SPS and VTD programming procedures.
I am not sure that a battery condition like that would cause all this but... who knows?
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
11-20-09, 11:14 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2003 CTS "Ebony Maria" | | Join Date: Dec 2008 Location: Wherever Uncle Sam sends me Age: 29 | | | Re: i think my ecm gone bad Quote:
Originally Posted by ewill3rd The Passkey module sends a coded password to the ECM for fuel continue. If the ECM is not programmed to recognize the coded password it will go into theft mode and shut the engine off. | ewill3rd...what if you disconnected the battery, then disconnected the ECM and then reconnected the battery to do something else, after you did that the anti-theft comes on and you get nothing? then you put it all back together, would you need to have the ECM reprogrammed/relearned? i think this somewhat of the issue i am currently having...thanks for any and all help you can provide...
OP...sorry for the thread jack...
__________________ ~TxBest~
Reason: fixed quote
11-21-09, 08:27 AM
| | Cadillac Owners Member Cadillac(s): cts 04,3.6L | | | | | Re: i think my ecm gone bad the ecm did come programmed, had a mechanic put a comp. on it and it said lost communication pcm. |
11-21-09, 10:25 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: i think my ecm gone bad Jemile, I am confused, what is the current status of the car?
txbest, once the password has been learned both modules will retain memory for fuel enable and continue even after loss of power.
You can take the ECM out and put it back in and also the VTD module with no effect.
It will give you a fault message when you restart after a power loss but on the next ignition cycle it will be fine. |
11-22-09, 12:53 PM
| | Cadillac Owners Member Cadillac(s): cts 04,3.6L | | | | | Re: i think my ecm gone bad sorry if i confused you,when i turn the ignition on starting disable remove key appears and the anti theft light.when you try to start you get nothing. |
11-23-09, 09:46 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: i think my ecm gone bad It sounds like you are saying that the ECM is programmed with the necessary calibrations, but it still has to be programmed with a separate programming for the theft system.
There are two programming events that must take place.
One to install the software and VIN for your specific vehicle, the other to match the ECM and VTD passwords.
If this has not been done the car will never start. |
11-23-09, 10:29 AM
| | Cadillac Owners Member Cadillac(s): cts 04,3.6L | | | | | Re: i think my ecm gone bad can u email me ur no. i'll like to tlk to u about the situation | | Cadillac Discussion Tools | | |
Censor is ON | | | |
