How to: change the outlets l from being on all the time, to being on with the key. - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
Like Tree3Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, How to: change the outlets l from being on all the time, to being on with the key. in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; This does not work for me. Pepboy search for "R3109" yielded a result with nothing that can be purchased. GMPartsDirect ...
  1. #31
    agp's Avatar
    agp
    agp is offline Cadillac Owners Connoisseur
    Automobile(s): Ex-CTS owner
    Mar 2009
    SE Michigan
    1,229
    Re: How to: change the outlets l from being on all the time, to being on with the key
    GMPartsDirect search for "12177234" yielded no result.
    Autozone search for "19263" yield lots of results:
    http://www.autozone.com/autozone/cat...rchText=19263+
  2. #32
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    there have been a handful of guys over the years who this did not work for. I have no answer for y'all.
  3. #33
    Bluehaze07's Avatar
    Bluehaze07 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS
    Apr 2009
    Honolulu, HI
    1,395
    Quote Originally Posted by agp View Post
    tell the autozone rrep to check the oem number for a match. That's how i got mine.
    They will be looking in the misc relay area for the part.
  5. #34
    96_Pimpin_Deville is offline Cadillac Owners Member
    Jun 2006
    6
    Hey All, I just wanted to say that I have an 06 STS 1SG. I recently put another amp and subs in my car with the Bose system. needless to say I looked for an amp turn on lead for quite awhile to no avail. Finally I figured I would use the power point in the back seat and change the fuse over. I found the fuse trick doesn't work in my car. Put the relay in and found that the ground was missing on the coil side. I grounded it with a jumper and found it works, but is still battery direct. After trying to take the fuse block apart to jump it underneath to avoid a mess of wiring on top, I found the the panel is a sandwich if metal traces much like a circuit board. Total waste of time. So I put it all back together and just ran a jumper wire from the normally open side of the ignition relay to the dead terminal of the fuse for the front outlet as I wanted that to shut off with the car as well. Works well!
  6. #35
    Tony Dehnke is offline Cadillac Owners Member
    Automobile(s): 2003 CTS
    Sep 2012
    Abbotsford, BC, Canada
    1
    Thanks for sharing this tip! Picked up a 2003 CTS last night and that was one of the things I didn't like! Such a no brainer way of being able to customize a vehicle to each user, surprised more manufactures have not done it too!
  7. #36
    concorso is offline Cadillac Owners Master
    Dec 2007
    5,630
    What is the benefit of doing this?
  8. #37
    Dec 2006
    42
    37,302
    In case you leave something plugged into one of the sockets, it doesn't drain your battery.
  9. #38
    silver bullet is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS Lux/Sport
    Dec 2003
    Torrance Cal.
    79
    348
    Page 3-24 of my 2004 owners manual explains the whole process. It should be in all the years.
  10. #39
    jcornv15's Avatar
    jcornv15 is offline Cadillac Owners Member
    Automobile(s): 2007 CTS 3.6 Base
    Jul 2013
    San Fernando, Ca
    30
    38
    2007 cts luxury package. Switched and doesn't work. Relay and switched, doesn't work. I understand this thread is probably dead but did anyone ever figure anything out?
  11. #40
    sharward's Avatar
    sharward is offline Cadillac Owners Member
    Automobile(s): 2012 CTS Premium Sport Wagon (Touring/19"), 2006 CTS (Luxury/17")
    Mar 2011
    Sacramento (Natomas), CA, USA
    24
    I would love to know too. I have 2006 CTS with luxury package, and I too tried switching the fuse position and added the relay, and it no workie (no power to outlets at all in that position).
  12. #41
    Jim's 06 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2006
    191
    I have the same problem: outlet works with the fuse in one position, but not in the other position (with engine running or key off). Or sometimes the outlet is dead in either position. (This issue exists for both outlets.) So I removed the fuse (for the 50th time), wire-brushed the terminals, and sprayed them with electrical contact cleaner. Inserted fuse, had power in one position, but not the other. Both outlets are working for now. I quit while I was ahead.
    PS- during the diagnostic process, I started the engine, removed the fuse, tested the fuse box contacts with a properly-set voltmeter, and got no readings. Ideas?
  13. #42
    Lunti1's Avatar
    Lunti1 is offline Cadillac Owners Member
    Automobile(s): 2005 CTS w/ Luxury & 17" Sport Packages
    May 2014
    Leipzig/Germany
    50
    2005 CTS Europe,
    new relay + fuse repositioned - not working
    Solution: tinned jumper wire (14-16 gauge) from accessory sparefuse to relay socket port to fuse.
    Tobias
  14. #43
    highonchai's Avatar
    highonchai is offline Cadillac Owners Fanatic
    Automobile(s): '85 Seville Commemorative, '69 Sedan deVille, '06 CTS Sport
    Feb 2004
    Lansing, MI
    31
    424
    Quote Originally Posted by Lunti1 View Post
    Tobias
    This works great for those who the standard fuse move and relay add does't work, like my '06 sport/lux.
    Thanks Tobias!
  15. #44
    sharward's Avatar
    Mar 2011
    24
    I ended up hard-wiring a relay, splicing into the power that feeds the climate control module as its trigger. I also hard-wired a multitude of cigarette lighter power adapters that are all tucked into the area behind the ashtray to supply power for a variety of doodads -- Bluetooth adapter, scanner, dash cam, backup camera, and smartphone. Look, ma -- no dangling cables!
  16. Remove Advertisements
