I just talk to the wheel shop and they told me
Results 1 to 8 of 8
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, I just talk to the wheel shop and they told me in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Wheels i ordered won't work (19"x8.5 5x114.3 w/hub centric ring) with my car. There might still be vibrations even with ...
    Devil_concours is offline Cadillac Owners Connoisseur
    Jan 2003
    Alexandria, VA
    34
    3,684
    Wheels i ordered won't work (19"x8.5 5x114.3 w/hub centric ring) with my car. There might still be vibrations even with the ring due to width
    miscreant's Avatar
    miscreant is offline GM Connection
    Feb 2004
    Norman, OK
    44
    1,286
    Re: I just talk to the wheel shop and they told me
    Quote Originally Posted by Devil_concours
    "There might still be vibrations even with the ring due to width" - read as "there might still be vibrations and we don't want to be responsible"...
    8.5" is on the small side of wheels that people use hubcentric rings on...I've seen as high as 10.5". The fact of the matter is the hubcentric ring does NOT support the wheel, it only assists on mounting the wheel center on the hub and then is bolted down with normal lugs. That's why most hubcentric rings are soft aluminum or plastic.
    2004 Cadillac CTS (**SOLD** ): http://www.ctsowners.com
    2004 Pontiac GTO: http://www.myyellowgto.com
    Neoflex is offline Cadillac Owners Fanatic
    Oct 2003
    NY NY
    40
    164
    ORDER THEM ANYWAY! My wheel guy wanted me to order true 5x115 wheels too and fought me on getting 5x114.5s for fear of me having vibration problems. Problem is the wheel choices for that lug pattern are far and few between and most of the wheels did nothing for me so I assured him that if I had vibrations I would not hold him responsible and sure enough he ordered the wheels for me, and everything is FINE! I am running 20x8.5s with a hub centric. I have had the car up to 100 with no problems.
    MY CAR: http://members.cardomain.com/whitediamondcts
    fallen99angel is offline Cadillac Owners Member
    Automobile(s): cadillac srx V6
    Aug 2003
    sweden
    45
    89
    this is not really the the sts forum, but Im in the process of getting the cts instead, anyway I mounted 114,3MM on my sts and had the centerrings ordered to fit tight, I have never felt any vibrations in the car, just make sure to get the right measurement on the wheel and the hub, and you are good to go. The reason why you will have a risk of vibrations, is if the wheel do not fit the hub and the bolts and wheels will loosen a little, then the vibration will go right through the steering, the centering will make sure the wheel wont be loose and bumb around on the hub
    regards
    henrik
    Sweden
    Jan 2003
    Alexandria, VA
    34
    3,684
    This is the wheels that i bought but canceled. I'm kinda disappointed since it was suppose to be here by tomorrow
    http://cgi.ebay.com/ebaymotors/ws/eB...category=43959
    what other measurements do i have to worry about?
    so far i have 19"x8.5" 40mm offset 5x114.3
    Jan 2003
    Alexandria, VA
    34
    3,684
    will this wheel fit in my car?
    http://cgi.ebay.com/ebaymotors/ws/eB...tem=7913814080
    19x8.5" front 19x9.5" back
    5x114.3 w/35mm offset
    S10xGN's Avatar
    S10xGN is offline Cadillac Owners Fanatic
    Automobile(s): 2016 CTS VSport
    Feb 2004
    Port Neches, TX
    63
    260
    Wow, those are mighty FINE! I'd be concerned that the wheels would stick out past the fender lip with that small an offset. I'd be looking for 50mm or greater... My 18 x 7.5's have 45mm offset and fit just right.
    miscreant's Avatar
    Feb 2004
    Norman, OK
    44
    1,286
    Quote Originally Posted by S10xGN
    No, not 50mm. I wouldn't go over 45mm with 8.5" wide wheels, because you'd be smashing them into the upper steering knuckle (they'd be too far in).
    35mm offset is probably too low. I even thought 38mm was pushing it. Try to stick around 40mm offset.
  11. Remove Advertisements
