| Re: CTS Has problems starting sometimes Odds are 99% that it's the Crank Position Sensor. 03's and 04's had that problem. Do a search on CPS. You can do it yourself, it's about $70.
The CPS is under the car located near the oil filter, you need a torx socket(female)to remove it. The connector is on the center of the fire wall near the top.
BTW, what type of battery did you put in the car? I had the same problem and did the same thing you did and I installed a 600CCA battery, well that created a new problem because the car wouldn't crank when it was hot. I needed a battery that is 800 CCA or higher. So once I got the right battery and the CPS changed, the car has been perfect.
