AC Delco Battery replacement
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, AC Delco Battery replacement in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello to all. I'm a newbie who just bought a 2006 Cadillac CTS - 2.8 L. The existing AC Delco ...
    Enthralled is offline Cadillac Owners Member
    Automobile(s): NONE
    Sep 2009
    4
    The existing AC Delco battery is 4 years old and with winter just around the corner here in frigid Manitoba, I would like to buy a non-Delco replacement battery because I just don't like paying a GM dealership $250.
    The problems: The existing Delco battery has a battery blanket with the top cover tied down to its front side with a velcro strip. The location of the battery is at the top left corner just under the hood. The battery has its two terminals on the front of the battery facing me and not at the top like most car batteries. I'm not sure if I bought a non-Delco battery if the:
    (1) existing cable connectors to the terminals are long enough for a top connection rather than a side connection, and
    (2) top terminals of the brand new battery might touch the underside of the metal hood thus 'shorting' the battery.
    Can anyone here see any dangers in what I am proposing to do?
    Thank you.
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    Re: AC Delco Battery replacement
    first off, welcome to the forums...
    now there are many threads on this same topic. a few people have been able to but a new battery in with the top terminals connected and everything just fine. i am not positive which batteries they went with, but it is possible. but to let you know, there are other battery brands out there that also have side battery terminals that are non AC Delco...
    erik soelseth is offline Cadillac Owners Fanatic
    Automobile(s): CTS 2,8 l
    May 2009
    Norway
    56
    230
    I haven't measured the clearance, But GM didn't put this battery in for fun. I Expect that you run the risk of shorting yore battery using one with top poles. And that wouldn't be fun. The battery can explode or you get a fire.
    Erik
    cabbagepatchelvis is offline Cadillac Owners Member
    Automobile(s): 05 CTS
    Apr 2009
    Long Island, NY
    36
    26
    I don't know what state you're in, but by me you can buy delco batteries from certain parts stores without having to go to a dealership.
    Automobile(s): NONE
    Sep 2009
    4
    Quote Originally Posted by cabbagepatchelvis View Post
    Thank you to all for your responses and for welcoming me as a newbie here.
    I phoned all the battery stores and none of them carry AC Delco. It seems that GM has a stranglehold monopoly here in Winnipeg, Manitoba, Canada.
    OK, being that the hood has practically zero clearance between its underside and the top surface of the new battery terminals, I must go with a non-Delco battery with side terminals (which are hard to find). The Sears Diehard batteries are also terminals. The Wal-Mart Eveready batteries I was told by the Wal-Mart guy won't do for a Cadillac 2006 CTS.
    txbest1980's Avatar
    Dec 2008
    36
    6,414
    dont let them tell you a certain battery will or wont work over the phone. you should probably go and look at it and verify for yourself. a few other people have been told that certain batteries wouldnt work, they bought them anyways and the battery worked like a champ...
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,124
    So the moral of this thread. If the shoe fits, wear it.
    If the replacement battery is the same dimentions, within a certain tolerance, side terminals and above 660CCA. Then it will work.
    KOT
    jonboy193 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    6
    yea I went to walmart and crappy tire and eyeballed up a few "group 78" side terminal batteries, they are a very close size ( there's no reason to buy a top terminal one) , it installed perfectly and the car starts better than ever, don't overcomplicate this, it's just a battery.
    Sammy Z's Avatar
    Sammy Z is offline Cadillac Owners Connoisseur
    Automobile(s): CTS 03
    Jan 2008
    Chicago, IL
    1,765
    Maybe it was just my car, but I needed a battery with about 800 CCA. When the engine is hot and you try to start it the 660 CCA was giving me intermittent start problems.
    mjs0202 is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Jan 2009
    303
    I prefer to let the battery die and get the AAA battery service to replace it. They only charge about $40 more than picking one up yourself: and they come to your house, change it, replace corroded leads and give a 6 year warranty.
    viking2's Avatar
    viking2 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS Sport
    Dec 2004
    N. E. Ga
    68
    94
    CoolRe: AC Delco Battery replacement
    Quote Originally Posted by Enthralled View Post
    Thank you.
    After posting on this forum about a battery replacement, i decided to go with the Die Hard gold. Had it installed Sun. fit is perfect except for the cover. battery and install $130.00.
    freddo213 is offline Cadillac Owners Member
    Automobile(s): 05 CTS SPORT/LUXURY PACKAGE
    Feb 2008
    SOUTH GATE
    i bought an AC DELCO battery for $135. couldnt find any other replacement battery at the moment. went to kragen (chucks) and autozone and they both told me it was unavailable. called every auto parts in town and had to special order.
    McPolo is offline Cadillac Owners Member
    Automobile(s): 04 CTS
    Aug 2009
    48
    36
    Auto Zone now has a replacment batt for the cts, its part no 101DLG price is 129.00 They charge that high price because its Cad CTS specfic, the good news is they have another batt thats the same exact size, but even a better batt, for less money part no 78DLG 89.00 Three year free replacment, 1000 CCM 800CCM at 0 degrees, and 110 Reserve Power.. Fantastic Batt, better that AC Delco..
  16. #14
    corpsemangler is offline Cadillac Owners Member
    Automobile(s): '05 CTS, '97 Z24
    Sep 2009
    Winterpeg
    32
    17
    Thank you.
    hey man im from winnipeg too! winter sucks... anyways i was thinking about getting an optima battery for my CTS they have both top and side posts so aslong as the battery isnt too tall i think thats what im gonna replace the AC Delco one with... i've got an optima redtop in my cavy right now and its been a great battery although i dont drive the cavy in winter, i did have a yellow top in my old cavy and it worked great in winter even when i forgot to plug the car in...
  17. #15
    gruncle is offline Cadillac Owners Member
    Automobile(s): 2003 CTS; 1993 allanta
    Sep 2009
    74
    7
    I replaced the original with a Exide TrailBlazer 75-2A, side mount, 910amps, 730cc. It's not as wide, but a hair higher than stock so I didn't use the cover. Purchased at Tractor Supply. Don't remember the price, maybe around $80.
    Steve
  18. Remove Advertisements
