Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS First Generation Forum - 2003 - 2007
Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
cadillac-cts
Cadillac Forums: Changing Rear Wheel Bearing (Hub Assembly)
Old 09-08-09, 10:37 PM
gaugeguru's Avatar
Cadillac(s): Cadillac CTS
View gaugeguru's Photo Album
Casino Cash: $5545
Hi All,
I have been attempting to replace the Passenger Rear Wheel Hub Assembly and have have not been able to remove my rotor. It appears to be rusted to the hub assembly.
I have removed the single torx screw through the rotor and the brake caliper but the rotor is just stuck. I sprayed it with liquid wrench to dissolve the rust and I've been hitting it with a hammer to break the rust free but no luck. I even went back a day later after letting the liquid wrench sit in but it still is not working.
Am I missing something? Do I need to do something with the parking brake too?
Any help or advice would be really appreciated!
  #2 (permalink)
Old 09-08-09, 11:18 PM
Cadillac(s): 06 CTS
View BadAV's Photo Album
Casino Cash: $3475
Re: Changing Rear Wheel Bearing (Hub Assembly)
Keep soaking it with penetrant as it takes some time to work all the way through if it's rusted really hard; I like PB Blaster because I've always had good luck with it. Keep smacking it with a hammer as close to the hub/rotor junction as you can. The parking brake should be off. You could also try heating things up with a propane torch - it might do the trick. Stuck rotors can be very persistent.
  #3 (permalink)
Old 09-09-09, 12:54 AM
ghettomike's Avatar
Cadillac(s): 03 Cadillac CTS
View ghettomike's Photo Album
Casino Cash: $11305
is your e-brake on?
the cts has a drum style e brake inside the disk
my jimmy is similar, i couldnt get it off so i used a 3 hook puller and got it off in about 5 min...you just have to get a big enough one...i found 1 that was almost the right size but not quite so i used 2 hooks insted of 3 and used the links from the 3rd to make the other 2 links longer..this made the puller perfect but you have to hold it from tipping...not that hard, just have 1 person hold it as you crank it.
also i dont want to state the sometimes not-so-obvious but there is a scrue that holds on the rotor as well
  #4 (permalink)
Old 09-09-09, 02:00 AM
gaugeguru's Avatar
Casino Cash: $5545
Thanks for your quick response...
I hit the rotor with a hammer in the rusted area for over 1 hour. I'm really tempted to just wack the rotor from behind really hard but I know that's not recommended.
I wonder how GM would do it.
  #5 (permalink)
Old 09-09-09, 08:24 AM
Cadillac(s): 06 CTS
Casino Cash: $3475
It does sound like your e-brake shoes may be holding the rotor in place. I've not looked at the e-brake on the CTS but from ghettomike's description it sounds like the one on my Avalanche (which sucks, btw). If it's like regular drum brakes you should be able to see a star wheel through an access hole on the back side of the rotor backing plate that you can use to can back off the brake shoe clamping if that's what the issue is.
  #6 (permalink)
Old 09-10-09, 04:53 PM
View Rekkid's Photo Album
Casino Cash: $505
It does sound like your e-brake is grabbing it. I'll second the notion of using a three hook puller, within 30 seconds you'll have it off. Of course if your e-brake is grabbing, you may have to reassemble it afterwards. A 6" three hook puller here in Canada cost me $25 at Princess Auto.
  #7 (permalink)
Old 09-10-09, 04:57 PM
ghettomike's Avatar
Casino Cash: $11305
Or you can do the free loner tool at part source...you just leave a creditcard deposit.
That's a really good price for the one you got at princess auto..I may go buy one.
  #8 (permalink)
Old 09-10-09, 05:54 PM
josney's Avatar
AA is for quitters
Cadillac(s): CTS
View josney's Photo Album
Casino Cash: $13345
yep...gear puller.
18 inch Detata Wheels: V-Grille, lower mesh grille, HID Low beams 6000K , HID Fogs 6000K, rear spoiler,
LED exterior and interior lighting, Pioneer AVIC-D3(BT and Ipod control) 8 inch Amplified Bazooka, 35% tint, tinted side markers.
  #9 (permalink)
Old 09-10-09, 06:21 PM
Spyke's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2005 Cadillac CTS 3.6L VVT
View Spyke's Photo Album
Casino Cash: $16723
gauge, i had the same conclusion than others and you didn't replied to this one: is your e-brake on?
Dont use your e-brake otherwise you'll do everything to take off the rotor and it wont move a bit
  #10 (permalink)
Old 09-11-09, 12:55 AM
gaugeguru's Avatar
Casino Cash: $5545
Hi, Thanks for all the replies but I made sure the E brake was not engaged.
Tags: , , , ,
assembly, bearing, changing, hub, rear, wheel
