Retain DIC with Double Din wiring? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Retain DIC with Double Din wiring? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Open the hood, remove the fuse box cover, look for the two fuses. Choose a fuse, or both remove it, ...
  1. #16
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,158
    Re: Retain DIC with Double Din wiring?
    Open the hood, remove the fuse box cover, look for the two fuses. Choose a fuse, or both remove it, move over to the left or right one peg. You'll see what I mean.
    KOT
  2. #17
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    Quote Originally Posted by Kingoftypos View Post
    You know what, there are two other power sources.....
    The power outlets..... Remember fella's the fuses for these power outlets that are under the hood can be switched. From their factory default of always on, to on with ignition. Heck, that might even be just exactly like a RAP. Where the opening of the door turns it off. Best part, is that you could control the front from separate from the rear one.
    I know that ya'll would like "duh" just like I was a minute ago when I thought of those fuses.
    KOT
    ^true except for the part about opening the door. Even after you open the door, close it, lock the doors and engage the alarm; RAP stays active for 10 minutes after you turn off the ignition. No matter what. Only the radio shuts off when you open the door.
  3. #18
    LS6TT's Avatar
    LS6TT is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac CTS
    May 2007
    Fort Worth, Texas
    33
    299
    I wouldnt mind if it shuts off when the car turns off, i just want to make sure it doesnt lose all settings etc.
  5. #19
    Dec 2006
    42
    37,302
    Quote Originally Posted by LS6TT View Post
    that is why devices that store settings (like my parrot kit) also use a constant 12v+ lead.
  6. #20
    J W
    J W is offline Cadillac Owners Enthusiast
    Automobile(s): CTS /CTS-V / Escalade EXT / Coupe
    Jun 2009
    583
    I tried that in my 05 cts, i even added the extra relay needed. When i put the fuses in the altenate slots the cigarette lighters did not work at all. Could there have been something i did wrong or does it not work for all models.
  7. #21
    Dec 2006
    42
    37,302
    If it didn't work for you, it is hard to say. Are you sure you moved the fuses correctly?
  8. #22
    J W
    Jun 2009
    583
    Yes, i switched the positions to the alternate slot. They just went dead. Could ther be a wire in the dic harness i could use since it still functions properly.
  9. #23
    Jhayzhone's Avatar
    Jhayzhone is offline Cadillac Owners Member
    Automobile(s): Custom 2007 cts
    Jan 2012
    Canada
    74
    Awesome.. I was looking in this thread..
  10. #24
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS
    Dec 2006
    South Carolina
    49
    2,296
    Quote Originally Posted by Hinnenk1amp View Post
    I want to keep my DIC and know how to install it
    then search "retain DIC" and start reading. there are plenty of threads.
  11. #25
    Brh2 is offline Cadillac Owners Member
    Jan 2015
    38
    Is there anyone who can help with the wiring part of this mod... when I unplug the audio connector my dic wont come on... got power just no sound or dic if audio connector left unplugged...
  12. #26
    Invisible@Night's Avatar
    Invisible@Night is offline Cadillac Owners Member
    Automobile(s): 06 CTS Black on Black
    Nov 2011
    Denver,CO
    35
    46
    What do you mean by your audio connector? When you unplug from the factory radio or from the new aftermarket radio?
  13. #27
    Jan 2015
    38
    Quote Originally Posted by Invisible@Night View Post
    The middle plug on factory radio... I followed darkwing mod to retain dic got everything working but sound
  14. Remove Advertisements
