CTS-V Side Skirts
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, CTS-V Side Skirts in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Has anybody installed the CTS-V side skirts on CTS-6? I have prices and part numbers but I have no idea ...
    RobertCTS's Avatar
    RobertCTS is offline Cadillac Owners 10000+ Posts
    Automobile(s): Black the Darkside
    May 2004
    Central Ohio
    22,418
    CTS-V Side Skirts
    Has anybody installed the CTS-V side skirts on CTS-6? I have prices and part numbers but I have no idea how they are mounted to car. Any help?
    muzik9 is offline Cadillac Owners Member
    1
    Re: CTS-V Side Skirts
    Have you asked a dealer to install the kit?
    RobertCTS's Avatar
    May 2004
    Central Ohio
    22,418
    Quote Originally Posted by muzik9
    I would have a paint shop paint them. But I'm a DYI guy, so why pay the dealer if it's easy. I think they are clips or double side tape. Some of my CTS parts are held on by double sided foam tape from the factory.
    RobertCTS's Avatar
    May 2004
    Central Ohio
    22,418
    Quote Originally Posted by RobertCTS
    Miscreant, I read in another thread that you installed the skirts? I remember you said it was a "bolt on"? I've looked at my door jambs and fender wells and can not figure out how that is done. Advise please?
    miscreant's Avatar
    miscreant is offline GM Connection
    Feb 2004
    Norman, OK
    44
    1,286
    No, I *plan* to sometime...but not yet.
    Molding Replacement - Rocker Panel
    Removal Procedure
    -Open the front and rear doors.
    Important
    New retainers are required for the installation of the rocker panel. The retainer clips will break upon removal.
    -Remove the front section of the rocker panel first.
    -Pull the bottom edge of the rocker panel molding away from the rocker panel in order to disengage the retainers.
    -Use a flat-bladed tool and gently separate the front of the rocker panel molding from the upper retainer clips.
    -Carefully remove the front rocker panel molding from the body.
    -Remove the rear section of the rocker panel second.
    -Use a flat-bladed tool and gently separate the rear of the rocker panel molding from the upper retainer clips.
    -Carefully remove the rear rocker panel molding from the body.
    -Remove the lower retainers by using a pair of needle nose pliers. Pinch the tabs on the clip together and pull away from the vehicle to disengage.
    -Remove the lower retainers from the rocker panel.
    Installation Procedure
    -Install the lower retainers on the rocker panel.
    -Install all new retainers into the molding.
    -Position the rear rocker panel molding first to the body.
    -Press the upper retainers into the rocker panel in order to secure the molding.
    -Secure the molding to the lower plastic retainers.
    -Press the molding inward in order to secure.
    -Position the front rocker panel molding to the body.
    -Close the front and rear doors.
    2004 Cadillac CTS (**SOLD** ): http://www.ctsowners.com
    2004 Pontiac GTO: http://www.myyellowgto.com
  8. Remove Advertisements
