| Re: Service Charges If you follow your maintenance that is written in the owners manual, its a pretty easy DIY job.
When the OLM calls for an oil change, I do maintenance number 1. On the next OLM oil change notice, I do maintenance 2.
Everytime I do an oil change on my car (I do it myself and it takes 20 minutes to do it, dont even need to jack the car (search in the forum and you'll have step by step instruction and check on youtube, someone posted a video on how to do your oil change and oil filter change)). Next, I check the air filter (takes 5 minutes to take the filter, inspect, clean if needed or change it and put it back on).
Usually, every 2 oil change, I change the air filter. Every spring, I change the cabin air filter. For the transmission, go to your dealer for that (my opinion). For the fuel filter, wait until you reach 100k miles and my suggestion is again the dealer for that if you dont want any mess in your garage.
For the throttle body, I clean it at maintenance number 2 so once every 2 oil changes, thats it. For the fuel induction, if the car is running great, dont do it. I have an 05 with 112k + miles on the odo and never did the fuel stuff and it still runs great!
All the rest is visual inspection (hoses and stuff). Lube what you need to lube by reading the owner manual.
You'll save plenty of money and you can by yourself a case of beers and cheers my friend! |
