Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS First Generation Forum - 2003 - 2007
Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
cadillac-cts
Cadillac Forums: CTS anti theft or imobilizer system
Old 07-19-09, 09:26 PM
Cadillac(s): 2004 CTS
View stephenray5252's Photo Album
Casino Cash: $285
My wifes 2004 CTs will not start. The theft light comes on solid and locks the key in the cylinder. You have to use the manual release in the steering column to get the key back out. It is no time related. We waited 24 hours to see. We have a second key but I am not sure we have ever tried it. We bought the car from family and only she drives it. The battery is OK. I pulled it and had it tested a two different locations. I have tried the lock the vehicle and then unlock with a key with no success as well as the unlock with the wireless remote.
The system seems normal otherwise. The anti theft lights blinks until you put the key in and start to turn it. Then it goes on solid and all other lights on the instrument panel go off. After manual extraction of the key it goes back to blinking. There are no blown fuses realted to the theft system.
I am guessing both keys are bad or the sensor in the cylinder has failed but would like to get a second opinion before having it towed.
Steve
  #2 (permalink)
Old 07-19-09, 10:03 PM
Cadillac(s): 05 CTS
View Bluehaze07's Photo Album
Casino Cash: $3211
Re: CTS anti theft or imobilizer system
Try using the instructions for programming a new key. hopefully it works. Here you go.
IF NO OTHER WORKING KEY FOR THE CAR IS AVAILABLE:
1. Put the newly cut Master key into the ignition and turn it to the ON (RUN) position. A "Security" indicator light on the dashboard will stay on for 10 minutes.
2. Within 1 minute after the indicator light goes off, turn the ignition to "OFF" then return to the ON (RUN) position. The indicator light again will stay on for 10 minutes. (DO NOT REMOVE THE KEY)
3. Again, within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON (RUN) position. The indicator light again will stay on for 10 minutes. (DO NOT REMOVE THE KEY)
4. When the light goes off for the third time, the new key is programmed into the computer and will start the car. Remove the key and then re-insert it into the ignition lock and start the car.
All previously stored codes will be erased. To stop the process at any time, simply remove the key and use an existing key to start the car.
  #3 (permalink)
Old 07-20-09, 12:25 AM
Casino Cash: $285
Thanks for the input. I tried this on both of the existing keys with no luck. The first time I had left the door open and the security light had not gone out after 12 plus minutes.
However; if I close the door and insert either existing key and switch to on (accessory; I can not get the starter to go) the security light goes out after about 5 seconds. However the car still will not start and as soon as I try the security light comes back on solid.
I will see if I can get a new key in the morning to try. However it seems to me the problem is the sensor unless both keys are dead.
Is there any system to test the keys to see if the transponder is responding?
I am a technical person and have test equipment like spectrum analyzers available.Ii assume the car emits a magnetic field that powers the transponder in the key similar to controlled door entry systems. Basically a RFID system.
Steve
  #4 (permalink)
Old 07-20-09, 02:25 AM
Cadillac Owners Enthusiast
Cadillac(s): 06 CTS Sport/Luxury package
View Kingoftypos's Photo Album
Casino Cash: $5960
Here is a question, does the car have a remote starter installed?
If it does, and that works. Then you must find the key that is allowing it to start. I should be in a black box under the steering wheel area.
KOT
  #5 (permalink)
Old 07-21-09, 10:17 PM
Casino Cash: $285
Just for an update this vehicle is now at the dealer. They towed it in Monday morning and it would start when it got there.
Today the technician came back after lunch and got the same errors I had and is trying to figure it out. They evidently have a 2008 Cadillac in the shop that has the same problem.
  #6 (permalink)
Old 07-22-09, 12:27 AM
Casino Cash: $5960
If I were you, I'll ask them to do it for free or at a cheaper rate. Since basically they don't know and such. Specailly since they have an 08 with the same problem and trying to figure it out.
Also, ask them to tell you what they did to fix it.
KOT
  #7 (permalink)
Old 07-24-09, 09:54 PM
Casino Cash: $285
Re: CTS anti theft or imobilizer system update
It apparently was the ECM module or "the computer". It amazingly is still under warranty. It was ready this afternoon and we will pick it up in the morning.
I am sure there are labor charges plus we had the oil changed etc.
If it runs for six months without a lockout I will know they were correct. I work on electronics systems and there is nothing more frustrating than an intermittent like this.
  #8 (permalink)
Old 07-25-09, 04:33 AM
Casino Cash: $5960
I work on electronics as well, slot technician to be exact. With over 8,000 slot machines and to have one have an intermittent problem, really bugs me. :-/
But there shouldn't be any labor charges, because it's the ECM and still under warranty. The reason why it's still under warranty is because the ECM is apart of the emission control. Which by federal law is either 80,000 or 100,000 miles. I forget which.
KOT
  #9 (permalink)
Old 07-30-09, 06:50 PM
View travelinman's Photo Album
Casino Cash: $275
I too am having theft deterrent problems with my 2005 CTS. I backed the car out of the garage and shut it off on the driveway; a couple of hours later, I went to put the car back in the garage and it would not start or let me pull the key out of the lock and the theft deterrent icon appeared on the dashboard. At first I thought it was a dead battery and called out AAA who found the battery to be in good condition. I am looking for a solution to get my CTS started without towing the car to the dealer. Any ideas? Thanks.
  #10 (permalink)
Old 07-30-09, 07:48 PM
Casino Cash: $5960
well it sounds like you have the same problem. question is, how many miles is on the car? because the warranty for the ecm should 8 years or 80,000 miles.
  #11 (permalink)
Old 07-30-09, 08:09 PM
Cadillac(s): Sedan de Ville, CTS
View z06bigbird's Photo Album
Casino Cash: $5019
Similar symptoms if your battery is dead or weak.
  #12 (permalink)
Old 07-30-09, 11:37 PM
Casino Cash: $275
Thanks for the reply King. I tried a method suggested in an earlier post where you turn the key to the "on" position for 10 minutes three consecutive times and it worked. Then the radio/info panel remained blank but after sitting for a couple of hours it came back on. So, hopefully, I am back in business. I did not realize the ECM had that long of a warrantee. My 2005 CTS has 26,500 miles on it so I had better look into how the ECM is covered. Thanks.
Art (Travelinman)
  #13 (permalink)
Old 09-13-09, 06:25 PM
txbest1980's Avatar
Cadillac(s): 2003 CTS "Ebony Maria"
View txbest1980's Photo Album
Casino Cash: $7865
question for some of you guru's out there...
if your anti theft light is on and the car will not turn over to start and you cant get the key out, what do you do. better yet, how do you unlock the anti theft system? could this be done with the OBDII or what?
~TxBest~
  #14 (permalink)
Old 09-13-09, 09:16 PM
Casino Cash: $5960
From what I read somewhere, there is a hole under the steering column that will allow a small screw drive in. Which unlocks the igintion switch to allow the key to come out. As far as the anti thief, something to do with the ECM and or battery not being charged good enough. So if I were you, change the battery first.
KOT
  #15 (permalink)
Old 09-13-09, 09:31 PM
txbest1980's Avatar
Casino Cash: $7865
battery is fully charged...
Tags: , , ,
anti, cts, imobilizer, system, theft
