Trans cooler lines pulled out of radiator??? - Page 9
Page 9 of 10 FirstFirst 12345678910 LastLast
Results 121 to 135 of 139
Like Tree15Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Trans cooler lines pulled out of radiator??? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Originally Posted by SHORTSTACK I don't take pride in being a prick but all that stuff he mentioned is in ...
  1. #121
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    Re: Trans cooler lines pulled out of radiator???
    Quote Originally Posted by SHORTSTACK View Post
    I don't take pride in being a prick but all that stuff he mentioned is in the FAQ's as a critical repair/ recall. Then he wants to bash GM/ Cadillac for it, when its his own negligence that caused the issues. It just pisses me off. People like this leave bad reviews but never fix the issues at hand. I have 85k on my car. All recalls have been fine, all critical replacement parts have been installed, catch can, trans cooler etc. I've had no problems.
    i gotta say... GM dropped the ball when it came to the rad and tranny cooler lines.
    there is no service bulletin or recall notice for them.
    these aftermarket "fixes" yes will solve the issues, however they are not gm approved, so if by some chance you have a 07 and under warranty then you do any of these mods they void your warranty for the parts of the car that the mods are affected by.
    its like buying a hockey stick cutting it too short then trying to return it because you screwed it up.
    they designed the car, they should be liable for all common issues, especially the tranny cooler lines.
    now, mine is a 03, generally there is a 10 year statute of limitations on most legal clauses, so im sol either way.
  2. #122
    Wojciech is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac STS 3.6 DI 2009 RHD with Performance Pkg
    Feb 2014
    Southampton, UK
    166
    Hi,
    Had similar problem.
    My car is from 2009. Is the problem occur in this models?
    I parked my car and I smell oil.
    Look under the hood and I noticed little bit of oil in the left corner.
    I wipe it and took the car for cruising. I drove in few modes, easy driving, kick down, manual mode.
    Trans works fine. I opened hood and I haven't notice leaking.
    It is possible for temporary leaking because of high pressure (run hard from junction, spin the wheel a bit)
    Steering fluid and coolant looks good.
  3. #123
    holsgo is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts
    Apr 2011
    143
    Check the 2 lines at the rad. If there is fluid, the lines are leaking. No if, ands, or buts.
  5. #124
    Feb 2014
    Southampton, UK
    166
    OK,
    Today I also spent some time with my Caddy
    What I realized, that wasn't trans fluid that was coolant !!!
    But there is no leaking any more.
    But one thing. There is kind of coolant hose joint. I noticed one clamp is broken only 60% of clam cover the hose.
    I think the coolant gone there when I stopped in traffic and temperature increased. (No signal about it on dash board) So I have to replace clamps anyway.
    But is anyone can explain the coolant hoses connections? The join what I'm talking about has two hoses. One is going to the cooler second one to the plastic cover (is this thermostat?) and from the cover to the cooler.
    EDIT:
    Ok I know it is Auxiliary Water Pump mounted for LLT engines
  6. #125
    Apr 2011
    143
    Can you post a pic or post one elsewhere and point us to it?
  7. #126
    Maryscott is offline Cadillac Owners Member
    Jun 2014
    1
    Mine is - 2006 and this has happened twice!!!
    1st time cost 1,200 this time 300.00
    Plugged the year old radiator n bypassed with a tranny cooler !!!
    Hope tranny didn't blow!!! No warnings or leaks
    And yes while driving up hill
  8. #127
    cadi1bar is offline Cadillac Owners Member
    Automobile(s): 2007 cadillac cts
    May 2015
    5
    Just had the trans cooler line break on me. Just like many others I was at a red light and when it turned green the cadi wouldn't go.Stepped outside the car trans fluid every where. The radiator isn't leaking coolant.
    DO I NEED to by a new Radiator or can I just buy an external tranny cooler and refill the transmission? Thx
  9. #128
    Jferg216 is offline Cadillac Owners Member
    Automobile(s): 04 CTS Sport
    Jan 2014
    Cleveland
    25
    26
    Just buy a trans cooler. Literally just had this happen to me, was fortunate that nothing more severe happened. Hayden 1240 is what I went with, it has the OEM dimensions for the lines and everything. Also get a trans filter kit. You'll need a fluid pump to put tranny fluid back in. GL man, message me if you need anything. Literally just did this yesterday.
  10. #129
    May 2015
    5
    Ok thx for the feedback. I have a fluid pump but how do you refill the transmission? I pumped about 2qts and it started overflowing. The car is off and I know I lost more than 2qts. Does the car HAVE to be on?
  11. #130
    Mandrake's Avatar
    Mandrake is offline Cadillac Owners Fanatic
    Automobile(s): 04 CTS 91 Aristo
    Jun 2016
    MN
    32
    423
    You can add me to the list however mine broke while trying to reinstall the line after flushing the tranny and not on the road. So I already have it up on jackstands. I guess we saved the environment from a bunch of ATF on the road and saved me a tow. I'm thinking about doing the external cooler instead of just replacing the radiator.
  12. #131
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Quote Originally Posted by Mandrake View Post
    I'm sorry to hear that. I'm still shocked that it has happened to this many people! Hasn't Cadillac issued a recall on this? It seems dangerous to spew ATF all over and leave people stranded. I had my elderly grandfather with me when it happened.
  13. #132
    Argent is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS
    Nov 2015
    107
    Mine failed internally, no sign of a leak. Therefore it filled the tranny with coolant, the engine with Dexron.
  14. #133
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Quote Originally Posted by Argent View Post
    Ouch, that would be the worst kind of failure! Did it destroy the transmission?
  15. #134
    Nov 2015
    107
    Oh ya. It probably happened gradually, as there was no indication, so it was mixing unbeknownst to me, until I noticed a slight overheating, then it started slipping.
    I opted for a reman trans. Thousands of $$$
  16. #135
    feinspa is offline Cadillac Owners Member
    Automobile(s): 2006 CTS base 3.6
    Nov 2009
    NYC
    19
    Just happened to me. 2006 with 112K miles. On the passenger side, trani fitting broke clean from behind the Hex nut. Looks very rusty on the rear of that nut. It also was leaking anti-freeze from the same general area. Fluid pissing all over the exhaust caused quite the smoke show. I got the car parked, but not before the car stopped moving on its own. I shut it off immediately after is started to rev and go no where. What's the chances of the trani being permanently damaged from lack of fluid? I'll replace the rad tomorrow
  17. Remove Advertisements
