Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS First Generation Forum - 2003 - 2007
Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
cadillac-cts
Cadillac Forums: Thread for DIY mods
  #61 (permalink)
Old 07-02-09, 03:13 AM
Cadillac(s): Raven Black '05 CTS
View makdaddy386's Photo Album
Casino Cash: $385
Re: Thread for DIY mods
^^^try just using a heat gun on factory lettering/badges that have been out in the sun for a couple years. Not only will you not be able to remove all the foam tape, but it will leave discoloration or residue that will be extremely difficult to remove. This isn't the quickest way to do it but the proof is in the pictures for how clean it turns out. To each their own...
  #62 (permalink)
Old 07-02-09, 05:06 PM
Bluehaze07's Avatar
blue is the new black!!!
Cadillac(s): 05 CTS
View Bluehaze07's Photo Album
Casino Cash: $3001
You are probably right. I haven't debadged my vehicle or any vehicle for that matter. I saw a friend debadge his new YUKON with a heatgun and he rebadged it with "YUK" LOL. Your results do look good though.
  #63 (permalink)
Old 07-03-09, 11:23 PM
Cadillac Owners Enthusiast
Cadillac(s): CTS 05
View afterdigital's Photo Album
Casino Cash: $2309
Originally Posted by Bluehaze07 View Post
I was gonna make you a offer you couldn't refuse but you said it was a cd changer not a NAV unit.
Bluehaze.....Phadin to Black
@JimmyH - do you have 2 caddy's - one CTS and one CTS-V?
  #64 (permalink)
Old 07-07-09, 07:58 AM
Bluehaze07's Avatar
Cadillac(s): 05 CTS
Casino Cash: $3001
Re: Thread for DIY mods (Hid Install/Headlight Polishing)
I've been checking out this DIY. I will be doing this in a month.
DIY
  #65 (permalink)
Old 07-07-09, 08:04 AM
Bluehaze07's Avatar
Cadillac(s): 05 CTS
Casino Cash: $3001
Re: Thread for DIY mods (Clear Fog lights)
DIY – Clear FOG Lights
Items needed:
2 – 11x14 or 11x17 sheet of LEXAN (1/4" thickness) – use your judgment about the thickness and size.
2 - Silverstar 3157A/4157A ST Amber Park and Turn bulb
2 - Silverstar 9005 ST fog light bulb
4 packs per housing - Silicone Adhesive/ 2 Clear epoxy (Home Depot should have this item)
Sandpaper (usually comes in a pack or roll)
8 to 10 - 30 x 20 Centimeter clips (amount depends on how paranoid you are)
1 – Flat head Screw driver or paint can lid remover tool
1 – Dremel w/cutting tool or a plastic cutting tool or a circular/band saw (you decide the best tool)
OVEN and/or heat gun
Instructions:
1. Remove the FOG Light housing from Vehicle (http://www.cadillacfaq.com/faq/answers/stsvfogs/index.html)
2. Preheat oven to 300 DEG for 10-15 min. TURN OFF YOUR OVEN.
3. Use a wet towel and place the housing in the oven on top of the towel, lens side down. Leave for at least 10 min.
4. Use the flat head (or similar tool) to pry the lens from the housing. (FYI: some ppl have used heat guns while prying the lens after heating)
5. If your lens is not damaged, use it as a template to trace onto the Lexan and make the cut with the cutting tools (you can measure and create a template of your lens before removing it if paranoid).
6. Clean off the old adhesive/plastic or other crap from the adhesion area using sand paper. Be careful not to damage the inner part of the housing (sanding that area down should roughen the adhesion area enough to create a good hold).
7. Use the silicone adhesive and place on ONE side of the housing at the adhesion point. Be Liberal. Use the clips to clamp that side down. Repeat this step for the other three sides and DO NOT REMOVE THE CLAMPS while doing the other sides.
8. Wait for 2-4 Hours (depends on your paranoia and type of adhesive/epoxy you use).
9. Sand down any rough edges around the completed housing and place some more silicone adhesive around those edges to make sure you have a water tight seal (use the quick set epoxy for this).
10. Repeat steps 1 – 9 for other housing.
11. Install bulbs and housing. Then go check your work out!!!
**Optional Steps**
**See step 6 and step 9. Step 6 is strongly suggested.
**You may place the cut lexan in some boiling water for 2 – 3 min (or use a heat gun) and then place on top of the old lens. Clip the lexan to the old lens to curve/shape it.
**Use plastic polish to shine the lens.
FINALLY you are at the end. Hopefully I have not forgotten anything.
FYI - LOWES will cut the lexan for free if you you have a template or measurements. you just have to pay for the size lexan you use.
  #66 (permalink)
Old 07-15-09, 12:05 AM
Bluehaze07's Avatar
Cadillac(s): 05 CTS
Casino Cash: $3001
HELLPP!!!!! I am worried that my clear lens will open up on me. I completed the DIY and I removed the clamps on the housing/lens. I came back after class and the corners lifted up from the epoxy on the housing (1"). Did i do something wrong or what?
I did add a good amount of epoxy on the Lens. Now i added more epoxy to those corners.
  #67 (permalink)
Old 07-16-09, 01:13 AM
Cadillac(s): Cadillac CTS
View cdudeman's Photo Album
Casino Cash: $475
Great thread guys. This is exactly what I was looking for as trying to find the right key words to put in the search box can be confusing.
Thanks
  #68 (permalink)
Old 07-17-09, 12:31 AM
Cadillac(s): White '04 CTS 3.6L,Two JL 12w7 + Bose/ Boston Tweets
View Cad4life's Photo Album
Casino Cash: $3390
This diy is just awesome lol
http://www.cadillacforums.com/forums...dic-color.html
  #69 (permalink)
Old 07-17-09, 01:58 PM
Cadillac(s): CTS 05
Casino Cash: $2309
Originally Posted by Cad4life View Post
i came close to doing that DIY but my desire wasn't strong enough to push me into taking action...great write up though...
  #70 (permalink)
Old 07-18-09, 12:12 AM
Casino Cash: $3390
but its only 16 led's if you have a nav!!! lol i will give it a try blue of course and for each button im wondering if i should o blue or white, idk why the buttons arnt pure white like our dash, but this is all in the future for me...and yea its a great write up...
  #71 (permalink)
Old 07-18-09, 11:09 AM
Cadillac(s): CTS 05
Casino Cash: $2309
here's another DIY:
CHANGING THE SPARK PLUGS
EDIT: could someone contact SDMARINEGUY to reload pictures on that post - they appear to be missing...
  #72 (permalink)
Old 07-18-09, 11:43 PM
Cadillac(s): 04 CTS 3.6L
View guinsdan's Photo Album
Casino Cash: $2565
Great site (brakes, spoiler, etc.):
http://www.jon04ctsv.com/tutorials.php
  #73 (permalink)
Old 07-18-09, 11:48 PM
Casino Cash: $2565
Sound System Upgrade:
http://rarcangel84.googlepages.com/
Door speaker replacement (off of his work server):
http://www.novustechnic.com/cadillac..._web/index.htm
  #74 (permalink)
Old 07-19-09, 12:04 AM
Casino Cash: $2565
Cadillac Faq (usually listed by submenu, not index):
http://cadillacfaq.com/faq/index.html
  #75 (permalink)
Old 07-22-09, 08:07 PM
Bluehaze07's Avatar
Cadillac(s): 05 CTS
Casino Cash: $3001
completed the FOG Light DIY. Results
TIPS:
1. Get a cutting wheel or let "LOWES" cut the lexan if you have a template or measurements. 10X13 sheet worked great for me. It was almost perfect on one side. I think the cut size is 10X10.5 (don't quote me on that though).
2. don't tighten the clamps too much. when you loosen the clamps, the lens will try to go back to it's original shape and mess up your whole world.
3. use a sander or the cutting wheel to shave the edges as close to the housing as possible, So they fit properly in the bracket.
4. you only have to remove the front 3 tabs in the wheel well and one the is kinda in the back of the wheel well and the under body shield from the bumper. easy access after that.
Tags: , , , ,
diy, diy or faq, mods, section, thread
