Just got "LOW OIL PRESSURE..Stop Engine" on DIC
Results 1 to 10 of 10
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Just got "LOW OIL PRESSURE..Stop Engine" on DIC in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Was about 2 blocks from my house and got this error.... OMG.... Anyone know what would cause this???? Only thing ...
    mprest99's Avatar
    mprest99 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS
    May 2007
    Cyperss, TX
    137
    Was about 2 blocks from my house and got this error.... OMG.... Anyone know what would cause this???? Only thing I know that just happened on the way home was I drove through a lot and I mean A LOT of water.. only about 3 inches deep... and the speed was about 20mph or so.. don't think I would have sucked any up or anything .. and if so, I don't think it would give me an Oil Pressure error.. then again, what do I know..
    Since I was turning on my street, I came straight home and parked it.. After sittinga while, I checked the oil and it is fine and there is no water in it... I also checked to see if it threw any codes but there are none... the check engine light did not come on. Just the oil light and what flashed on the DIC...
    Any thoughts or ideas?
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    Re: Just got "LOW OIL PRESSURE..Stop Engine" on DIC
    My best advice is to PRAY.
    Locate ewill3rd here. He is always very helpful.
    Sammy Z's Avatar
    Sammy Z is offline Cadillac Owners Connoisseur
    Automobile(s): CTS 03
    Jan 2008
    Chicago, IL
    1,765
    Was it a one time thing or is it on constant now? It sounds like the oil pump may be malfunctioning.
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,220
    Quote Originally Posted by Sammy Z View Post
    Either that, or the oil pressure sensor's connections got wet from the splash of water. I've had this problem in an 04 Grand Prix, and it turned up being the oil pressure sensor. Pretty cheap item, around $20 to $30.
    I haven't looked to see where this sensor exact location is on our cars. But normally it's right above the oil pan.
    KOT
    bronsonllh's Avatar
    bronsonllh is offline Cadillac Owners Fanatic
    Automobile(s): '03 CTS White Diamond
    Nov 2005
    Chester, IL "Home of Popeye"
    152
    The oil pressure sensor is located at the front lower base of the engine block, so it could be very posible that water got in the connection.
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    i can tell you that if the oil pressure sensor is not connected you will NOT get a error message... when my belt broke a few weeks ago it snapped the wire off and broke the clip on the sensor, i have a new one ready to go in just havent had the chance.
    so i dont think water on the connection would cause this error but i could be wrong, try to disconnect it and fire up the car. but be carefull it is just plastic it could easily break
    jcdas's Avatar
    jcdas is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS 3.6 Black Raven Sport
    Oct 2006
    Mississauga, ON, CA
    109
    Might be a coincidence. First thing to check is the oil level. Pull the dipstick on level ground, and make sure it's OK. If it's low enough, you will get the warning message.
    mprest99's Avatar
    May 2007
    Cyperss, TX
    137
    Well after letting it dry out for the weekend, I checked the oil level and it was maybe a qt low.. Worries me though since I did not do my last oil change since it was in the shop and they changed the valve cover gaskets and oil pan gasket.... I just added a little bit and drove it some yesterday and the warning never came back on.. not sure if it was due to it being a little low on oil or being wet from driving through deep water..
    I am guessing it was water related since the repair work was done about 3 months ago...
    I am going to go to the parts store today and get my ususal oil changing stuff and change it myself.. the oil life is at 28% so it is almost due anyway...
    Thanks for the replies...
    sammyy is offline Cadillac Owners Member
    Automobile(s): cts
    Sep 2012
    1
    Quote Originally Posted by Kingoftypos View Post
    KOT
    whats a good place to take cadillacs and get work done on it
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,308
    Holy random thread bump, Batman!
    Quote Originally Posted by sammyy View Post
    [W]hat[']s a good place to take [C]adillacs and get work done on [them][?]
    Hmmm... Maybe the Cadillac dealer?
  13. Remove Advertisements
