Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
 | Cadillac Forums: Convert High Beams to DRL's
04-12-09, 12:22 AM
|  | Cadillac Owners Member Cadillac(s): 2006 CTS 3.6L | | Join Date: Mar 2009 Location: Mill Creek, WA Age: 51 | | Convert High Beams to DRL's History:
Original when I switched to HID's I wanted to have my high beams and fog lights match (6000k) So I tried using High output LED's, the color matched great but the actual light output sucked even though they claimed to be a replacement option.
Current:
I replaced the Fog Lights with a set of HID's and they look great, but I had two set of LED's I couldn't use. So I got the idea, since my standard HID's and Fog Light's give me all the lighting I need Why not convert the high beams and use them as DRL's.
With a second DRL module and some wiring and Presto............ HID/LED DRL's, with the lower light output no worries about blinding anyone and they look great........... |
04-12-09, 07:08 AM
|  | Cadillac Owners Connoisseur Cadillac(s): CTS 03 | | Join Date: Jan 2008 Location: Chicago, IL | | | Re: Convert High Beams to DRL's So now, what lamps do you have in the brights? Did you use the wire from the DRL's? If so, do they blink when you turn on the signals/emerg flashers? |
04-12-09, 12:27 PM
|  | Cadillac Owners Member Cadillac(s): 2006 CTS 3.6L | | Join Date: Mar 2009 Location: Mill Creek, WA Age: 51 | | | Re: Convert High Beams to DRL's The high beams have been swapped out for High Out-put LED's which are wired separately to a second LM458 DRL Module. The new module (water proofed) has been placed and wired to the fuse box. The DRL input is now running to the new module (left a connector in line so that I can use Both New lights and old yellow DRL's if I want to). Since the new High/DRL's are on a separate circuit they aren't effected by any of the working flashers or blinkers, and I have open relay's to add other light options if I get an itch. |
04-16-09, 12:59 PM
| | Cadillac Owners Fanatic | | | | | Re: Convert High Beams to DRL's Are you telling me that you can run the high beams, low beams and foglights all at the same time... If so I would like a picture this sounds cool! |
04-16-09, 01:23 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 CTS 2.8L | | Join Date: Nov 2006 Location: Westlake, Ohio Age: 25 | | | Re: Convert High Beams to DRL's That looks weird, not sure if i like or not. Need more pics, possibly night time. |
04-16-09, 01:46 PM
|  | Cadillac Owners Member Cadillac(s): 2006 CTS 3.6L | | Join Date: Mar 2009 Location: Mill Creek, WA Age: 51 | | | Re: Convert High Beams to DRL's The Yellow DRL's have been rewired to the High Beams which are high out-up HID LED's (doesn't blind on-coming traffic)with the use of a second DRL module. I don't have the need for high beams because the output from both HID fog's and head lights give off more light then they did anyway (mine's just a city car).
Like the BMW my lights /DRL only run during the day and auto shut off when the headlights come on, I haven't change any of the functionality of the DRL's just using a different light in a different location.
Plus I still have the option to switch the old yellow DRL's on and use with the converted LED/DRL -highs. |
04-16-09, 01:51 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 CTS 2.8L | | Join Date: Nov 2006 Location: Westlake, Ohio Age: 25 | | | Re: Convert High Beams to DRL's Yeah, I disabled my high beams so i could wrap electrical tape around my bulbs (so the headlight looks black from the reflection).
Still want night pics though.. -_- |
04-16-09, 10:53 PM
| | Cadillac Owners Fanatic Cadillac(s): 2005 Cadillac CTS Every Option | | Join Date: Jul 2008 Location: Tyler, Texas Age: 21 | | | Re: Convert High Beams to DRL's I like it. Good idea. |
04-18-09, 01:01 PM
|  | Cadillac Owners Member Cadillac(s): 2006 CTS 3.6L | | Join Date: Mar 2009 Location: Mill Creek, WA Age: 51 | | | Re:(New Photo's) Convert High Beams to DRL's New Night photo's of my DRL's and HID's plus a one of my LED Blue interoir........ |
04-20-09, 09:54 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 CTS 2.8L | | Join Date: Nov 2006 Location: Westlake, Ohio Age: 25 | | | Re: Convert High Beams to DRL's That's pretty neat. |
04-20-09, 11:57 PM
| | Cadillac Owners Enthusiast Cadillac(s): Generation 1 CTS | | Join Date: Mar 2007 Location: Greensboro, N.C. Age: 29 | | | Re: Convert High Beams to DRL's whoa! cool blue... |
05-14-09, 01:36 AM
| | Cadillac Owners Member Cadillac(s): 2006 CTS Luxury | | Join Date: May 2009 Age: 19 | | | Re: Convert High Beams to DRL's Hey sorry to be reviving an old thread but i woulda just made a new one other wise.
Anyways i just got my car a little while back and was curious about setting up LEDs and different combinations of head lights but i havent the slightest clue about all this modding and wiring. Would any one be so kind as to let post some links where i can get started researching this or could some give me some info on how to do something similar to this. Thanks. |
05-15-09, 12:25 PM
|  | Cadillac Owners Member Cadillac(s): 2006 CTS 3.6L | | Join Date: Mar 2009 Location: Mill Creek, WA Age: 51 | | | Re: Convert High Beams to DRL's Just doing a basic yahoo search well give the best results. This site http://stores.shop.ebay.com/MotoringMax__W0QQ_armrsZ1 is the best that I've personally found and has the the numbers for conversion .  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
