Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS First Generation Forum - 2003 - 2007
Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
cadillac-cts
Cadillac Forums: Need help, the "key stuck no gas gauge" problem
Old 03-24-09, 11:54 AM
Kael's Avatar
Cadillac(s): The Mighty Kael, 2004 Black CTS, Every Option
View Kael's Photo Album
Casino Cash: $6232
Alright, yes I got the key out, I found the little hole underneath and I am able to do that.
2004 cadillac cts 3.6L
Symptoms:
Traction control light is on,
No temp or gas gauge,
Service anti-theft comes on.
Most of the INFO screen information is toast "--:--"
The shift gear indicator light is out and so are the sports and winter buttons (no effect when pushed)
No secondary gear shift actions (locks don't unlock when you put it into park).
Other than that the car drives fine.
Alright fellows. Give me options.
What to check, what to fix.
If its the ecu don't just go "dude, ecu"
go "dude, you need a new passenger side ecu unit, and then you need to take it to the dealer to have it flashed for your car"
Freaking bad ground (i think, its fixed now)
  #2 (permalink)
Old 03-24-09, 01:27 PM
Kael's Avatar
Casino Cash: $6232
Re: Need help, the "key stuck no gas gauge" problem
I meant the ground is fixed now.
Still having all the other entertaining issues.
Weird point:
The battery voltage is reading around 15.3 - 15.4.
it used to be lower than that on average.
So any fuses that I should check first?
Should I wait and do the twenty cycle thing before ordering a new ecu from the parts yard?
Oh, gmpartsdirect.com
and monsterpartsonline.com both have the powertrain control module (ecu) for around 230-250. monsterpartsonline has cheaper shipping.
  #3 (permalink)
Old 03-24-09, 02:27 PM
dkozloski's Avatar
Cold Soaked
Cadillac(s): 2006 STS AWD, '95 Ford Ranger
View dkozloski's Photo Album
Casino Cash: $20307
Disconnect the battery. Let the car sit for a few minutes. Reconnect the battery and see what you get. This reboots all the electronics and cures 95% of electrical problems.
Don't mess with Binky Bear!
  #4 (permalink)
Old 03-24-09, 04:07 PM
Kael's Avatar
Casino Cash: $6232
Did that while fixing the bad ground last night.
I will try it overnight tonight.
  #5 (permalink)
Old 03-24-09, 08:55 PM
Sammy Z's Avatar
Cadillac(s): CTS 03
View Sammy Z's Photo Album
Casino Cash: $9600
remove the battery cables and measure the battery with no load. You may have a bad battery.
  #6 (permalink)
Old 03-25-09, 12:59 PM
Kael's Avatar
Casino Cash: $6232
okay, pulled the battery positive over night, reattached it this morning.
still the same behavior.
Sammy, wait.. you are saying a battery going bad could cause this?
The car IS a 2004 with 100k on it, original battery.
  #7 (permalink)
Old 03-26-09, 04:25 PM
Kael's Avatar
Casino Cash: $6232
Alright, so lets say I have to get a new ecu.
is the correct part number:
12592124
Thanks for any help guys
  #8 (permalink)
Old 03-26-09, 04:59 PM
GT!'s Avatar
GT! GT! is offline
Cadillac(s): Blue CTS 2003 5-speed MT
View GT!'s Photo Album
Casino Cash: $2909
Sounds about right for battery replacement. Don't know if this is the actual problem, but I can tell you that your battery's days are numbered
-GT
  #9 (permalink)
Old 03-26-09, 09:47 PM
Sammy Z's Avatar
Cadillac(s): CTS 03
Casino Cash: $9600
If the battery is 5 years old and your getting strange reading, I'd start there. or if you have access to another battery, like a friend or relative try a temp. swap and see if the symtom changes. Like GT said, its days are numbered anyway, so invest the $100 and eliminate it as a posibility
  #10 (permalink)
Old 03-26-09, 11:12 PM
Cadillac(s): Sedan de Ville, CTS
View z06bigbird's Photo Album
Casino Cash: $5019
Don't let anyone sell you an alternator and a battery. They never go out at the same time. (almost)
  #11 (permalink)
Old 08-12-09, 03:15 PM
Cadillac(s): Cadillac
View allday's Photo Album
Casino Cash: $435
hey i have the same problem with car did u ever have any luck fixing your car
  #12 (permalink)
Old 08-12-09, 04:09 PM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $16917
It is likely the ECM when this happens.
Some essential data is lost and the ECM seems to be the guy dropping the ball when this happens.
It has to be programmed and coded for the theft system if it is replaced.
Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group.
  #13 (permalink)
Old 08-12-09, 06:34 PM
Casino Cash: $435
ok thanks for your help. im going to try this out and hope that it works
  #14 (permalink)
Old 08-13-09, 01:45 AM
RoyalFlush's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2004 3.6L v6 cts lux
View RoyalFlush's Photo Album
Casino Cash: $695
I had a similar issue and dkoz is correct. also check if the negative is making any contact. I found that the "teeth" on the cable attatched to the battery was not touching the battery node at all since movement from the battery caused the teeth to eath through the node. The rubber covering over the ends of the wires were creating a little bit of a gap just enough to prevent contact. key would get stuck and lights on the dash were bugged out. so i scrapped at the battery terminal until it was flat again and just tightened it as much as i could when reconnecting. if thats not the prob you might want to check your fuses
  #15 (permalink)
Old 08-13-09, 09:08 AM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
Casino Cash: $16917
Please notice I said "likely".
It certainly isn't the only cause.
You could have a communication issue caused by something else that could be at fault here.
As with most things it should be properly diagnosed before you go throwing parts at it.
My suggestion was just that... a suggestion.
Good luck.
Tags: , , , ,
key stuck no gas gauge, problem
