2003 CTS Rough Idle
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2003 CTS Rough Idle in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hi; I have a 2003 CTS with 52k original miles. It has a very rough vibration at idle and cant ...
    komobu is offline Cadillac Owners Member
    Automobile(s): cts
    Feb 2009
    55
    7
    2003 CTS Rough Idle
    Hi;
    I have a 2003 CTS with 52k original miles. It has a very rough vibration at idle and cant figure out why. When driving, its fine. It has all the power on passing that you can want. Just vibrates real bad when stopped. The MIL is not illuminated and there are no diagnostic codes in memory. Any idea what it may be?
    Thanks
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    Re: 2003 CTS Rough Idle
    have you changed the oil recently? or had any maintenance done to it lately?
    Sammy Z's Avatar
    Sammy Z is offline Cadillac Owners Connoisseur
    Automobile(s): CTS 03
    Jan 2008
    Chicago, IL
    1,765
    I think most of them do that. I complained to the dealer and he sat me in another 2003 3.2 and it had the same rough ideal. The dealer said there is nothing they can do.
    I cleaned the injectors and replace the plugs and nothing helped. Someone said there is a service bulletin on this but what it does is raises the RPM to around 800 at ideal. That doesn't fix it, it's a work-around. I've gotten used to it. The car runs great on the road.
    Spyke's Avatar
    Spyke is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac CTS 3.6L VVT
    Sep 2007
    Montreal, QC
    1,062
    do you run your car on premium gas or regular? Did you try an injector cleaner? Try the GM system cleaner for the injectors twice with premium gasoline. one tank with cleaner+ premium... another tank with cleaner + premium nd see if it helps.
    Rolex's Avatar
    Rolex is offline Super Moderator
    Automobile(s): 2008 Nissan Titan, 1996 Jeep Wrangler
    Arkansas
    41
    12,034
    The above post is my 2 cents....nothing more.
    AmericanMuscle is offline Cadillac Owners Fanatic
    Mar 2005
    260
    Rolex is right - it may just be the throttle body. He has provided very good directions on cleaning it DIY.
    bigboycaddy is offline Cadillac Owners Member
    Automobile(s): 2004 cts
    Jan 2009
    38
    42
    i had the same problem on my cts 04 everytime i stop i get a rough idle and sometime it felt like my car was gonna shut off , so i took it to the dealer and they found what was the problem was.They told me it was the timely chain belt and they had my warranty check it out and they cover the cost , and that was the last time i had that problem , hope this info help u
  10. Remove Advertisements
