Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: P0341 Code 2004 CTS
  1. #16
    GT!'s Avatar
    GT! is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 SRX AWD Platinum Ice/2010 CTS Sedan 3.6 AWD Silver
    Jun 2005
    Montreal
    53
    643
    Re: P0341 Code 2004 CTS
    Quote Originally Posted by Rekkid View Post
    "P0341 - Camshaft Position Sensor Circuit Range/Performance" is the generic code. More specifically for the CTS it means:
    DTC P0341 Intake Camshaft Position (CMP) Sensor Performance Bank 1
    DTC P0346 Intake Camshaft Position (CMP) Sensor Performance Bank 2
    DTC P0366 Exhaust Camshaft Position (CMP) Sensor Performance Bank 1
    DTC P0391 Exhaust Camshaft Position (CMP) Sensor Performance Bank 2
    The exhaust banks are on the far left and right on the front of the engine and the intakes are on the inside front, closest to center. Bank one is the right (or when standing in front of the car looking at the engine, it's on your left.)
    Here in Canada, I was quoted $68 for a sensor.
    Anyone have any pics of this (Intake Camshaft Position Sensor bank 1), or a more precise description of where to find this? Also, is this an easy DIY? Mine is a 3.2L (2003).
    Thanks.
    -GT
  2. #17
    agahnim is offline Cadillac Owners Member
    Automobile(s): 2004 CTS 3.6L
    Jan 2009
    Ontario, Canada
    32
    36
    Did you get this fixed? The code just started poping up on my 04, 3.6L.
    How much did it run you?
  3. #18
    WickedGoat's Avatar
    WickedGoat is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS 3.2/2004 GTO/2004 GMC Yukon
    Mar 2009
    Columbus, NJ
    42
    324
    More or less, this means that cam sensor may be on its way out the door. You can check the connector harness to make sure it is fully seated and not damaged in any way and you can also check to make sure that the wiring itself is not damaged in anyway. You can also test resistance in the sensor to make sure it is within spec, if not, replace it. If you are going to pull it off to attempt cleaning it, you may as well replace it. Most auto parts stores you should have this in stock or be able to order it if you want to avoid the dealership. For the DIY guy, repalcing it is probably the best bet.
  4. #19
    s_tharsan's Avatar
    s_tharsan is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS Sport
    Aug 2009
    Toronto, ON
    29
    260
    I had this exact same code on my 04 CTS 3.6L. I felt jerking in my car and the check engine light kept coming on with the P0341 code - Intake Camshaft Position (CMP) Sensor Performance Bank 1. I replaced the sensor but the problem still came back. Then I received a MSG from another forum member stating that the CTS sometimes puts out a camshaft sensor error when there's no or low engine oil, and sure enough I had no oil in my car. I filled the oil and the problem and codes disappeared.
    So start with checking your oil, I know it sounds stupid and basic but illuminate that. If your oil is full then post back and I'll send you a diagram of exactly where the sensor is and how to replace it.
    Good Luck,
    Tharsan S.
  5. #20
    Jun 2012
    21
    Re: P0341 Code 2004 CTS -- didn't need to change my CMS
    I hope this helps and saves some money for someone here: I've had the P0341 code and thought I'd have to replace the CMS but I also had the oil leak caused by the cold weather PCV problem which I didn't upgrade. So once I changed that AND cleaned up all the oil around the spark plugs and dried off the coil pack springs that fit into the spark plugs, I didn't get the P0341 code again ever. I had read on another forum for some other GM car (can't remember what model) and someone had mentioned that oil on the coil packs can cause shorts that will give the P0341 code. Sure enough, it worked for me in my CTS.
  • You may not post replies
