3rd Brake light fix with pix(redeux) - Page 4
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 66
Like Tree5Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 3rd Brake light fix with pix(redeux) in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Those LEDs look good too, I dont think putting in the transformer is any harder. the hard part is getting ...
  1. #46
    Randle Todd is offline Cadillac Owners Member
    Automobile(s): 2003 CTS
    Dec 2010
    Re: 3rd Brake light fix with pix(redeux)
    Those LEDs look good too, I dont think putting in the transformer is any harder. the hard part is getting the housing apart. What was your secret?
  2. #47
    drknt03 is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac CTS , Sport Package
    Nov 2010
    Kansas
    93
    I would like to thank you on your write up. My third brake light went out also done the reasearch and found your write up. This hellped me alot. Thank you again.
  3. #48
    rkspaint is offline Cadillac Owners Member
    Automobile(s): CTS
    Dec 2010
    Kansas
    18
    Hi Tommy, Great fix, and I am trying to do the same. I am having trouble removing the lens from the back cover. What is holding the top of the back to the lens? I have removed all of the glue around the bottom but the lens is still held firm.
    Thanks,
    rkspaint
  5. #49
    Automobile(s): CTS
    Dec 2010
    Kansas
    18
    Thanks,
    rkspaint
  6. #50
    Shadowf is offline Cadillac Owners Member
    Automobile(s): CTS
    Nov 2012
    1
    Thank you guys, it was a breeze, $13 Heat gun, $35 HighQuality Waterproof LED strip, 1 hour total task ...
  7. #51
    rcalderman is offline Cadillac Owners Member
    Automobile(s): CTS
    Feb 2013
    1
    Tommy,
    what was the P/N for the transformers from the above link that you used i'm in need of this repair now. i have the light apart and will order the transformers on Monday. also did you place the other transformer on the opposite side?
    Thanks,
    Bob
  8. #52
    tommy compton's Avatar
    tommy compton is offline Cadillac Owners Connoisseur
    Automobile(s): 06 CTS-V
    Mar 2007
    tha peg
    2,497
    Neonxa is the ones I used. I just stuck them side by side if I remember correctly.
  9. #53
    cmjohnson is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS luxury package
    Nov 2003
    300
    So, is the third brake light always neon (as original equipment) on a first gen CTS? Mine is out (both sides) on my 2004. There is some visible moisture in it.
    Well...as it turns out, more than just a little. How nice of Cadillac to carefully design the brake light housing in such a way as to ensure that the neon transformer will be cooled in a water bath
    that completely immerses it!
    The neon tubes are intact so I guess it's worth trying to fix it. Transformer should be here any day now.
    There's so much damage to the transformer receptacle in the plastic frame, including big cracks in it caused by rusting screws
    expanding in the plastic, that this might not actually be repairable. I'm debating whether to buy a working unit off of ebay and just call it a day.
    I decided to go with LED strips due to the fact that the housing is so damaged that there's no way to guarantee I could fully seal it against moisture The LEDs look fine, anyway.
    My 3rd brake light housing cracked along the edge of the "window" in the display surface. That's where moisture got in. I'll have to (eventually) get a replacement. But odds are
    that this is a design flaw (stress risers in the plastic due to the sharp internal corners) so most of the failed ones probably have the same crack.
  10. #54
    rush3 is offline Banned
    Automobile(s): 2005 Cadillac CTS
    Sep 2011
    Arnold, MO
    47
    This guy can fix it cheap with out all the work. Thought I would mention it. He did mine and it came with a lifetime guarante
  11. #55
    CBCadi06 is offline Cadillac Owners Member
    Automobile(s): Cadillac CTS 2006 3.6
    Sep 2012
    Virginia
    26
    I just wanted to say something I thought was wierd that happened to my cadillac o6 cts the other week,
    My 3rd brake light hasnt been working for about 2 years, I always put off the fix, (in Ut they didnt care about having a 3rd.)
    Couple weeks ago I got rear ended in the ugly Virginia traffic by some rubberneckin blondie(she admitted she was looking at the side of the road..)and the brake light started working again.
    Not sure how that all worked out but I'm happy I have it working again!
  12. #56
    mistertwoturbo is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Aug 2013
    31
    Thanks for the walkthrough, Tommy Compton!
    Sorry to revive this thread, but could someone give me some insight as to how to make the third brake light shine brighter? I have installed the Neonxa transformer in series just as Tommy suggested, but it doesn't seem to shine that bright. When I touch a screwdriver to the electrode it shines brighter but only the one side. Am I installing it incorrectly?
    I encountered the same problem that njgliderider1 did in post 36. After trial and error, I ended up using the white wire coming from the left neon tube (when looking at the brake light) and connected it to the white lead on the transformer. The center two wires coming off the tubes I soldered together to make it run in series. I grounded the red wire coming from the right neon tube along with the black lead from the transformer and the black wire from the harness.
    Any help is greatly appreciated!!
  13. #57
    Xtant12's Avatar
    Xtant12 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS-AWD DI ( Hot Lava Edition )
    Oct 2012
    Island Lake IL
    33
    123
    Congrads on this project. This happened to me on my 04 CTS and they wanted like 700.00 for the entire back pannel. They told me it was all one piece. I broke mine open just like you did but I replaced it all with a 12 12 or 16 inch red LED strip from ebay for 3.25 shipped. It was a long project but glad i got it done. The light never worked when I bought the car. Anyways, Good work!!
  14. #58
    Mankalas is offline Cadillac Owners Member
    Automobile(s): CTS
    Jan 2014
    Madrid(Spain)
    Hello,
    I have bought recently a cadillac CTS, and the third brake light is off. It was bought the first time at december of 2007, so i think that it is 2008 model, but im not sure, i have the option nav+bose 5.1(This is why i think it is 2008 model) and i was wondering if this walkthrough works for my car or not.
    In case that this does not work for my car, how can i fix this problem?
    Thanks in advance for the answers!!!
    And hapy new year!!!
  15. #59
    Ahill3265 is offline Cadillac Owners Member
    Jan 2014
    1
    I know you posted this repair a few years ago, but I'm hoping I can reach you through this forum. I did the repair you posted on the Cadillac center brake lamp and only one side works. Can you direct me on What I may have done wrong with the repair. Please help, my name is Allen Hill my email is ahill_1@charter.net
    Thanks in advance
    Allen
  16. #60
    LanciaPaul is offline Cadillac Owners Member
    Jun 2006
    39
    I used the 5kV transformer another poster recommended. Got it from Fire House Neon:
    http://firehouseneon.biz/items/neon-...wce-detail.htm
    I had two wires from the distal ends of the tubes as well. Probing the fried transformer showed that they were grounds so I wired it as shown below.
    Works good so far.
    Quote Originally Posted by njgliderider1 View Post
    I have a couple of questions:
    1) You say to "wire a length of wire to each of the outside electrodes". There are 2 wires coming out of the plastic pieces on the far ends of each of the tubes - white & black from one, red & black from the other. Can I simply cut the white & black wires, twist them together and solder another length of wire to the joined wires? And then do the same with the red & black wires on the other tube? . Are those blue & black plastic pieces on the far ends of each tube removable? I'm afraid to mess with them for fear of breaking a tube.
    2) Any problem, as far as you can tell, with just leaving the old transformer where it is ... thereby not having to disturb anything and again risk breaking a tube?
  17. Remove Advertisements
