3rd Brake light fix with pix(redeux) - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 66
Like Tree5Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 3rd Brake light fix with pix(redeux) in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey Tommy, I have been reading and re-reading your post just to make sure I have my mind in the ...
  1. #16
    rugburn's Avatar
    rugburn is offline Cadillac Owners Member
    Automobile(s): 03CTS
    May 2006
    Silverdale, Wa
    25
    Re: 3rd Brake light fix with pix(redeux)
    Hey Tommy,
    I have been reading and re-reading your post just to make sure I have my mind in the right place to do this and I have a question. Your second freehand drawing that includes the second transformer and the resisitor you received with the "Lost" transformer. I intend on using a single transformer so I understand this should not be a problem, however, just to be sure, I wll want to include this resistor, correct ? As long as I mirror your drawing minus the second transformer ?
    Thanks !
  2. #17
    tommy compton's Avatar
    tommy compton is offline Cadillac Owners Connoisseur
    Automobile(s): 06 CTS-V
    Mar 2007
    tha peg
    2,497
    if you get the same transformers as me, get 2. and you only need to hook up one resistor. i had originally used one transformer but noticed a small dead spot in one tube, and if your battery voltage drops it will get dimmer. 2 is optimal, just a bit of trial and error on my part.
  3. #18
    rugburn's Avatar
    May 2006
    Silverdale, Wa
    25
    Thanks !
  5. #19
    Mar 2007
    tha peg
    2,497
    no prob if you need help when you get them jusk ask.
  6. #20
    MDH20s is offline Cadillac Owners Member
    Automobile(s): CTS
    Mar 2009
    Decatur, Alabama
    43
    95
    Ok... Where did you get the slotted cover for your reverse lights? I want one! Will it work on an 05? I think my reverse lights are different.
  7. #21
    Mar 2007
    tha peg
    2,497
    i can't remember where i got it, i think us speed has em and so does wood dash experts. they'll fit all 03-07.
  8. #22
    j_blackwell1 is offline Cadillac Owners Member
    Automobile(s): none
    Jun 2009
    28
    how did u get the entire unit out? I took the 5-6 bolts off the back side but i cant seem to get it out and wanted to make sure i didnt miss anything.
    thanks
  9. #23
    Mar 2007
    tha peg
    2,497
    you mean the bolts on the back of the trunk lid? under the liner. once all the bolts are off it will pull out, once you get the bezel off, just make sure you undid the wire harness. you might just have to pry it abit, i'd try with your finger tips first, before potentially scratching your paint with a screw driver. it should come off with little force. i think there is 6 or 7 nuts to undo but i can't remember.
  10. #24
    Automobile(s): none
    Jun 2009
    28
    ok thats what i was guessing but wanted to make sure before i went and started pulling. thanks for the help!
  11. #25
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,117
    Jack this.
    It make no sense to attempt to repair the neon setup. The neon stuff is junk.
    The lamps need to be converted to LED.
    See www.ledfix.com
    Logan Diagnostic LLC
    www.ledfix.com
    www.airbagcrash.com
    www.logandieselusa.com
  12. #26
    sparktite is offline Cadillac Owners Member
    Automobile(s): 2006 CTS Luxury
    May 2009
    26
    93
    Hey i really really like the way your 2 white reverse lights look. Whats that housing thing covering the lights called, and where did you get it? Thanks
    Also to Logan, i checked your link out and when i found the tail light for a cts on ur link, it says,
    "Mail in LED lamp conversions available. We will convert your lamp to a more reliable LED lamp. Currently have model year 2003 unpainted panel versions available. This is a neon lamp and not LED. Call for details."
    Does that mean that the light is LED like the beggining of what they says implies. Or is it a neon lamp?
  13. #27
    Mar 2007
    tha peg
    2,497
    Quote Originally Posted by Logandiagnostic View Post
    Jack this.
    See www.ledfix.com
    www.ledfix.com
    www.airbagcrash.com
    So you charge 200.00 for an LED fix, what makes it better than the LED strips that I could buy for less than 50.00, and do it myself?
    I guess it's a viable option for the non DIYers.
    I would never pay it, if i were to go LED.
    IMHO neon looks better.
    Quote Originally Posted by sparktite View Post
    A few places have them, wooddashexperts.com and us speed to name a couple. It's called a rear bezel.
  14. #28
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    this thread needs to be a stickey or posted somewhere easier to find lol
    subscribed!!!!
  15. #29
    vlbasten is offline Cadillac Owners Member
    Automobile(s): CTS
    Aug 2009
    53
    tommy, how do you take the red lense from the black cover? i tried today and prid 4/5 i think, only the middle part left and i don't think i can make it.... is it just glued or what... why so hard to take it apart....
  16. #30
    Mar 2007
    tha peg
    2,497
    Yup it's just glue. Keep heating it up and keep prying slowly, it will eventually come apart, just have patience.
  17. Remove Advertisements
