Timing belt replacement on '03 - what else to do?
Results 1 to 4 of 4
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Timing belt replacement on '03 - what else to do? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; If I'm having the timing belt replaced (it's almost that time), should I be asking them to replace anything else ...
    GT!'s Avatar
    GT!
    GT! is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 SRX AWD Platinum Ice/2010 CTS Sedan 3.6 AWD Silver
    Jun 2005
    Montreal
    52
    643
    If I'm having the timing belt replaced (it's almost that time), should I be asking them to replace anything else while they're in that part of the motor?
    -GT
    Cartdawg's Avatar
    Cartdawg is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS
    Jan 2008
    VA
    36
    434
    Re: Timing belt replacement on '03 - what else to do?
    Maybe the water pump....usually that's done at the same time since their right near each other.........but with a Caddy..I'm really not sure if it's the same way. I'd think it would be. Someone else will have to chime in...or you could just ask that...they'll tell you. But the water pump most likely
    tommy compton's Avatar
    tommy compton is offline Cadillac Owners Connoisseur
    Automobile(s): 06 CTS-V
    Mar 2007
    tha peg
    2,497
    i'd do the water pump, idler pulley, i'm not sure but maybe the tensioner pulley also, i'm not sure if you can just replace the bearings for the tensioner or not? . if they have to remove the intake manifold i'd get them to replace the thermostat too. might save you the hassle later.
    Sammy Z's Avatar
    Sammy Z is offline Cadillac Owners Connoisseur
    Automobile(s): CTS 03
    Jan 2008
    Chicago, IL
    1,765
    Don't forget the plugs.If you're at 100K miles. If you like DIY projects, you can do it your self, but it's a few hour job.
  7. Remove Advertisements
