From a previous post; I am starting a new thread because it has gotten much worse, and the dealership fails to assist
. ... first the sunroof opens and closes on its' own. It will not close in the close position, and when it does, it will start opening and closing the vent, dozens of times in rapid succession. ... I will be driving along, anywhere from 35-65mph and the Nav screen says service [COLOR=blue ! important][COLOR=blue ! important]engine[/color][/color]
soon, then the car acts likes it's slammed into Traction control, it stops accelerating, slows down but rpms remain high; it's like the drivetrain is disconnected. I will pull over and turn off the engine start it right back up, and except for the instrument panel [COLOR=blue ! important][COLOR=blue ! important]engine [COLOR=blue ! important]light[/color][/color][/color] now being lit, runs like normal. Prior to these symptoms and the car shutting down, I would get a message on the nav screen "Service Stability System", then I would get on the instrument panel the Traction Control OFF light, the air bag light, the ABS light and the stability light on. Again, it would go away just by turning off the key. By the way, it certainly did and you could tell that it did shut off the stability system, the abs braking and the T/C... I found a recall notice on the computer but my dealership has said BOTH that my VIN did not qualify, and it was done before I purchased the car; huh, which one? Also they say it is impossible for this to be happening, since there is no computer record (codes) of it occuring. Ok, if it is the computer wouldn't it make sense that it may not be recording incidences/codes correctly? By the way, now that my car is out of warranty, they have found an issue that will cost $750.00; it was a grinding noise that turns out to be the hub. Now my dealership has a very high customer satisfaction index, but I am very frustrated. This is a very dangerous issue; since the car will just stop accelerating with out warning, I can't confidently on ramp to a highway, and since it makes the car go from 75 mmph to 30 rapidly without brake lights, I could be rear ended. So I understand the recall. Thoughts?
